Old 05-10-2008, 04:21 PM   #1 (permalink)
Member Number: 51998
Default Stage 2 wastegate
Hey guys. I was wondering what we have to do to adjust a stage 2 wg. Isnt there a specific spot that is key for it to work perfect? I took off my kinetic wg and put the stage 2 back on. Only problem is Im only hittin about 5 lbs of boost and with my mbc open Im only hitting about 10. Im stage 2 with toys. Im off of the pcm controlled boost with the DAB controll. I have the Needswings mbc. Any help is appreciated...
Thanks
linko is offline   Reply With Quote
Old 05-10-2008, 06:14 PM   #2 (permalink)
my_little_srt's Avatar
Member Number: 41179
You know you have to take off the arm off the manifold to adjust it right???
my_little_srt is offline   Reply With Quote
Old 05-10-2008, 08:00 PM   #3 (permalink)
Member Number: 9221
Trader Rating: (17)
you have to run a S2 WGA on PCM boost
GO FAST PARTS
Stage 1
FM E1 turbo
FM WGA
Dtec FC
AGP returnline
PTP 55mm TB
PTP check valve
ED hardpipes w/ HKS BOV
Maddog STS 72%
AGP motor mounts
Zeitronix ZT2 wideband
NGK v power plugs .040
8.5 MSD wires
Needswings DP (no cat)
Quickwhips direct fit FMIC
180 thermostat
Bwoody H-brace combo
Bwoody Trans mount
AnotherNeon is offline   Reply With Quote
Page generated in 0.15475 seconds with 11 queries
