07-01-2008, 04:39 AM
#16 (permalink )
Member Number: 44525
Quote: Originally Posted by
94thunderchicken
Why are you running a Stage 3 PCM?
Car is a stage 3
07-01-2008, 07:49 AM
#17 (permalink )
Member Number: 1784
Jason300zxTT
OK UPDATE.
Car has brand new
plugs
wires
coil
turbo/wg/bov is all good no leaking.
vac is good
boost is turned down to 14psi and not 19psi
reset the ecu
Use to have MSD coil, but replaced it to oem
Stage 3 ecu
Still has same problem. 4500 still break's up.
WHAT ARE YOUR PLUGS GAPPED AT?!?!!??!!?
07-01-2008, 08:14 AM
#18 (permalink )
Member Number: 63229
Replace that upstream sensor.
07-01-2008, 09:55 AM
#19 (permalink )
Member Number: 1784
How does everyone know it's his upstream sensor when he didn't even tell us what his plugs are gapped at?!?!?! How do we know they are not gapped at like .38+... Let's not go throwing parts around to try and trouble shoot a problem... Let's start with the basics here folks...
07-01-2008, 10:59 AM
#20 (permalink )
good call, mine are at .038 as we speak.. but I tried them gapped at the stock .050 and they did it even worse... I have the same problem so i dunno.
07-01-2008, 11:22 AM
#21 (permalink )
Member Number: 36179
Jason300zxTT
Car is a stage 3
19psi on stock turbo might cause some issues, but not on stg3. I and many others are running 25-26psi on stg3 with no issues. What plugs are you using and are they gapped around .032 ?
Stage 3 FNF | Maxxfab Stg3 o2 | CTI Charge Pipe | AGP Stg3 WG | N2MB Toybox | Thermal 3" Turboback| JMB UPP | HKS SSQ BOV | JMB SRI | Mopar Wires | NGK 4306 Plugs | Maddog 72% STS / Rod Brake | BC Coilovers | QW BFMIC | B-Woody MM's | AEM WB | 30/30 Boost Gauge | Aeroforce Pro Scangauge | Pizza Ball|
Fro G's garage. When you want to be fast in the PNW
07-01-2008, 12:04 PM
#22 (permalink )
I wish someone could help my issue also >.<
all I have is agp wga around 17ish psi and the same thing happens. gapped at .038 w/ champion oem's
07-01-2008, 02:03 PM
#23 (permalink )
Member Number: 1784
Michigan_SRT
Get rid of the .038 gap... Gap it down to .030
07-01-2008, 02:07 PM
#24 (permalink )
Member Number: 53972
lol im running an msd coil, bitch works fine
07-01-2008, 03:01 PM
#25 (permalink )
Member Number: 65221
upstream o2? please tell me why?
my plugs are at .040" and it pops at 10psi
I also have a new Coil, Wires and Plugs
07-01-2008, 04:41 PM
#26 (permalink )
Member Number: 54645
will you please replace the upstream o2 sensor already!! they go bad from time to time specially if the fuel quality is not great! DO IT!
07-01-2008, 04:43 PM
#27 (permalink )
Jason300zxTT
OK UPDATE.
Car has brand new
plugs
wires
coil
vac is good
reset the ecu
Stage 3 ecu
replace UPSTREAM o2 sensor you can thank me later....
07-01-2008, 06:34 PM
#28 (permalink )
just for the noobies sake. uptream meaning o2 Sensor 1. The first one
07-01-2008, 07:23 PM
#29 (permalink )
yes its the first one by the turbo you can buy at an auto parts store just ask them for the upstream its like 23 bucks in my neck of the woods...
07-02-2008, 07:48 AM
#30 (permalink )
Member Number: 1784
SRTMIAMI
Let's not go throwing parts on left and right here... He still hasn't answered the question of what his plugs are gapped at...
Linear Mode
» Site Navigation
> Other Vehicles
