06-30-2008, 10:03 AM
#1 (permalink )
Member Number: 44525
SRT4 Breaking up at 4500RPM under boost.
Car use to run solid as hell, now this issue came up. Under WOT, after boost comes in, around 4500rpm the car just starts breaking up/popping/back fireing, I thought maybe the plug's were fouled so replaced them. Same issue continued. Checked for vac leaks, cant find any. Any suggestion's? Car was on 19psi and now we have it turned down to 15psi and still is breaking up.
thanks
Jason
06-30-2008, 10:30 AM
#2 (permalink )
Member Number: 50755
when you replaced the plugs did you notice if the wires in good shape? bad wires and bad connections can cause that too. make sure you use di electric grease any time you change wires or plugs.
06-30-2008, 10:43 AM
#3 (permalink )
Yup, plugs/wires are new and are done correct. Any idea's?
06-30-2008, 10:59 AM
#4 (permalink )
SRT-4 Discussion Moderator
Member Number: 24437
coil?
* Disclaimer...The above post may or may not have misspelled words ...deal with it...
**Sold**
Best E/T 12.699 @ 108.97
Best MPH 12.856 @ 110.32
06-30-2008, 11:09 AM
#5 (permalink )
Member Number: 63229
i have to use di electric grease once a week on the plugs and wires.. wtf is up with that?
06-30-2008, 11:13 AM
#6 (permalink )
Member Number: 1784
what are the plugs gapped at?
06-30-2008, 11:21 AM
#7 (permalink )
Member Number: 65068
mine is doing the same thing but at 7psi. i have granatelli wires on the way and just changed plugs. keeping fingers crossed
06-30-2008, 11:36 AM
#8 (permalink )
Member Number: 36179
Yeah check the coil and wires. And if you are running an MSD coil trash it and get a stock one.
Stage 3 FNF | Maxxfab Stg3 o2 | CTI Charge Pipe | AGP Stg3 WG | N2MB Toybox | Thermal 3" Turboback| JMB UPP | HKS SSQ BOV | JMB SRI | Mopar Wires | NGK 4306 Plugs | Maddog 72% STS / Rod Brake | BC Coilovers | QW BFMIC | B-Woody MM's | AEM WB | 30/30 Boost Gauge | Aeroforce Pro Scangauge | Pizza Ball|
Fro G's garage. When you want to be fast in the PNW
06-30-2008, 11:41 AM
#9 (permalink )
im gapped at .038 holding 17psi fade to 15psi
06-30-2008, 04:48 PM
#10 (permalink )
Member Number: 52533
mine is doing the SAME thing!! WTF! i thought it was plugs and wires 2, i havent got to get new ones yet, so i figured id look around here to see if any1 else was having the same problem...
let me know if you fix yours, and how
06-30-2008, 05:04 PM
#11 (permalink )
Member Number: 54645
1.) Replace upstream o2 sensor
2.) reset ECU
3.) enjoy!!
06-30-2008, 05:12 PM
#12 (permalink )
Member Number: 65076
Quote: Originally Posted by
SRTMIAMI
2.) reset ECU
3.) enjoy!!
I'm curiuos wouldn't the pcm throw a code on a bad o2 sensor?
06-30-2008, 05:56 PM
#13 (permalink )
Member Number: 65221
ehhh....depends. not always tho. my SRT4 does the same thing too
06-30-2008, 06:44 PM
#14 (permalink )
buzzfast
OK UPDATE.
Car has brand new
plugs
wires
coil
turbo/wg/bov is all good no leaking.
vac is good
boost is turned down to 14psi and not 19psi
reset the ecu
Use to have MSD coil, but replaced it to oem
Stage 3 ecu
Still has same problem. 4500 still break's up.
07-01-2008, 01:32 AM
#15 (permalink )
Member Number: 8706
Why are you running a Stage 3 PCM?
Linear Mode
» Site Navigation
> Other Vehicles
» Network Links
