» Tire Upgrade Garage
Old 02-17-2008, 09:20 PM   #196 (permalink)
RTShadow's Avatar
Member Number: 11888
I need to get the stinking 3rd gear problems fixed on mine. I'll probably take it up to Woodhouse and let them work on it. I don't know that I'll ever walk into Baxter here in Omaha again. A-hole liars.
Quote: Originally Posted by Bella Lugrossi View Post
good thing this isn't a race to see who's smarter.
RTShadow is offline   Reply With Quote
Old 02-24-2008, 11:38 AM   #197 (permalink)
camlifter's Avatar
Member Number: 3008
myth, the srt-4 has a weak trans. false, this trans was first used in a commercial van, it is very strong.
fact. the root cause of all of the srt's trans trouble is the poor desing of the clutch release system, the clutch never fully disengages, this causes the trans speed not to slow down enough for the gears to mesh when shifting. all of the bent shift forks, burned syncros, and exploded flywheels are a result of the clutch not being fully disengaged, it's like trying to shift without using the clutch.
everytime your setting at a stop light with the car in gear and the clutch pushed, it's draging ever so slightly, heating up the flywheel and clutch. if it gets hot enough, the flywheel breaks.
the clutch release arm literally eats it's self up at the 2 pivot points, after a short time the clutch can no longer fully disengage, causing drag and creating hard shifting, of course we then start jamming it into gear, breaking the snap ring, syncros and bending the shift forks.
the only cure for this is to go with a hydraulic throw out bearing, eliminating the release arm altogether. nemo sells a system like this, for those in the know, you can peice one together for yourself from stock parts from an early 90's jeep for a lot less money.
camlifter is offline   Reply With Quote
Old 04-07-2008, 08:23 AM   #198 (permalink)
marine3050's Avatar
Member Number: 63068
Thumbs up
silver= fastest! +100! what?
marine3050 is offline   Reply With Quote
Old 04-16-2008, 12:06 PM   #199 (permalink)
DaVinciSRT's Avatar
Member Number: 62664
Myth.... i was wondering if its true or false that the single side exhaust its better for our cars than the dual one... im not talking about looks i mean performance!!!
DaVinciSRT is online now   Reply With Quote
Old 04-16-2008, 12:08 PM   #200 (permalink)
DaVinciSRT's Avatar
Also Orange blast faster lol i had to say it ....LOL + w.e the number its
Old 04-16-2008, 12:55 PM   #201 (permalink)
SRToc Member
alpine's Avatar
Member Number: 5844
Several hundred WOT shifts later, still smooth as butter.
Fact: Red attracts other cars making them more likely to run into you or ding your doors in parking lots.
alpine is offline   Reply With Quote
Page generated in 0.12487 seconds with 11 queries
