SRT-4 Clutch Problems. Report yourself here. - Dodge SRT Forum
post #1 of 185 (permalink) Old 09-05-2003, 08:07 AM Thread Starter
Project Blue
SRTforums Admin
Quoted: 0 Post(s)
Ok guys , it seems that we have 2 threads going about the clutch issues on the srt-4 ( although this doesn't surprise me though that the first thing to give away is the clutch. luckly its not the tranny)
I need you to report on this thread the following :
Your nick
Symptoms of the car
Times you taken it to the dealership
Has the problem been resolved
If you have a symptomatic feeling your clutch is going to be giving out.
Report the following :
What are the symptoms of the car now.
Has it gotten worst.
Now once we get about 15 cars or so. I will prepare a letter and reference it to this thread in specific.
I will sticky this for everyone.
FastAttack is offline
post #2 of 185 (permalink) Old 09-05-2003, 08:50 AM
dunny's Avatar
Quoted: 0 Post(s)
So far the clutch seems to be fine for me.......but it does make a slight "knock" when I change gears. It's weird, I engage the clutch, select gear, and when I release the clutch and it goes into gear there is a very slight noise I hear. I've never heard anything like this on my '96, and i've trashed the hell out of it and the clutch has lasted 107K miles (needs replaced now). This happens during any type of driving, ie, like grandma or very 'spirited'. Not sure if it's normal or what, but it happens 50% of the time. I have not yet taken it to a dealer (because most of them are ignorant about the srt4) but I might do it if the noise persists.
edit: oops, I forgot the format......
dunny
6K miles
clutch makes noise when shifting
0
N/A (not sure if it's really an issue)
dunny
'03 SRT-4 12.774@106.09 - sold
'96 DOHC SC 11.822@118.82mph
318whp/313wtq @ 16psi
SRT-4 turbo powered
'98 R/T coupe
'03 Solar Yellow SXT - 17.199@78.48
'04 SXT Dakota CC 4x4
dunny is offline
post #3 of 185 (permalink) Old 09-05-2003, 09:02 AM
SiCkTwiSTeDsRt4's Avatar
Quoted: 0 Post(s)
sorry to hear about your clutch problems guys...hopefully this will be fixed in the 04's...
SiCkTwiSTeDsRt4 is offline
post #4 of 185 (permalink) Old 09-05-2003, 09:29 AM
Quoted: 0 Post(s)
I have that same noise when i dis engage the cluth.
UPFD polished cold air intake
UPFD polished radiator piping
UPFD polished radiator overflow w/ braided lines
NITROUS EXPRESS N-Chiller Kit
TURBOXS Dual Stage Boost Controller
TURBOXS Type H-RFL Blow-Off Valve
AGP Wastegate Actuator
Motor Mount Inserts
fastest time stock 14.17 carlsbad
fastest time modified 14.3x fontana ( it was very hot and humid w/ chiller kit and intake kit only). actual 1/4 test in 2 weeks( aug. 23) for the real test with everything on!
GUSTAVO is offline
post #5 of 185 (permalink) Old 09-05-2003, 09:30 AM
Jeremy Smolik's Avatar
Quoted: 9 Post(s)
clunk during shifts. noise when engage/disengage in neutral. shifter rattles in 3rd. during somewhat hard driving, clutch pedal vibrates and feels different than normal when shifting. if i put it to the floor and let back off a few times, the vibration clears up.
took it to dealer once, they basically said i was nuts. said the vibration was the shifter's fault, sprayed it with wd-40 and gave me the keys back. i have since replaced it with the mopar short throw and it still vibrates.
problem is not resolved and feels as if it is getting worse. number of times that i have to engage/disengage clutch to clear vibration has increased. when i first noticed the vibration, it took a WOT run into third to show up. now it seems to do it even under moderately quick driving, ~10 psi of boost or so in any gear.
7800 miles. first noticed all this around 3000.
Jeremy Smolik is offline
post #6 of 185 (permalink) Old 09-05-2003, 04:49 PM
OvenMan's Avatar
Quoted: 0 Post(s)
Thank god I'm not the only one, I thought I was going nuts one day, my car too has that "knock" when I shift, even when I granny drive. My shifter does not seem to vibrate like your guys'. My shifter does vibrate but only if I like attempt to pull it out of gear without the clutch the shifter will slightly vibrate. I've had no problems with my srt, 2,000 miles and counting.
2003 Dodge SRT-4 - 13.50 @ 108.51
1997 Neon Coupe - 15.1 @ 91
OvenMan is offline
post #7 of 185 (permalink) Old 09-05-2003, 04:52 PM
Quoted: 0 Post(s)
have you had that noise when you turn the car off then release the clutch?
Motor Mount Inserts
GUSTAVO is offline
post #8 of 185 (permalink) Old 09-05-2003, 05:04 PM
Quoted: 0 Post(s)
I have the vibration and the clunking as well. I took the car to the dealership and the technician drove it a couple of miles and said he couldnt fint anything wrong but they marked it as a concern. I have to take the car back next week for them to replace my CD player, so I am going to make them drive it again.
Mike Severn
8500 miles
Clunking when I release the clutch, small vibration in the pedal.
Been to 2 different dealerships and both say they cant find anything wrong.
No resolution yet
Redracer is offline
post #9 of 185 (permalink) Old 09-08-2003, 08:39 PM
pryme's Avatar
Quoted: 0 Post(s)
I posted this a while back - ever since I have owned my car, I have heard a 'clunk' when shifting from a stop or slow speeds. It's probably there at high speeds, too, but I can't hear it. I can sit with my car off and push in the cluth and hear it 'clunk' everytime.
Most people have come back saying it is nothing, just a mechanical noise of the metal tapping.
I do not get the vibration on the shifter that others are getting.
Pryme
6000 miles
Solar Yellow 2003 SRT-4
Rotora Extreme Big Brake Kit - The BEST Big brake kit available for the SRT-4!!!
pryme is offline
post #10 of 185 (permalink) Old 09-09-2003, 07:48 PM
Quoted: 0 Post(s)
Dupes
I have not taken it to the dealer.
817 miles as of 9/9/03
2003 SRT-4 Yellow
Purchased 8-26-03
57 Miles
Dupes is offline
post #11 of 185 (permalink) Old 09-09-2003, 08:00 PM
B4UTRUST's Avatar
Quoted: 0 Post(s)
B4UTRUST
Clutch burnt, possibly stuck in 1st or 2nd gear though unlikely. Dealership won't look at car to tell me.
Taken to the Dealership on the 16th of August.
Issue has not been resolved.
Mods: Burned out Clutch - 1, Dents - 1, Scratches - Many
Doubt - In a battle between you and the world, bet on the world.
Avatar pic courtesy of Pitchblack SRT
B4UTRUST is offline
post #12 of 185 (permalink) Old 09-09-2003, 10:32 PM
gotboost?'s Avatar
Quoted: 0 Post(s)
Vibration in pedal just like others, but only when I push in clutch slowly. Can feel it even when car is off. Feels more like a grinding.
No shifter vibration, no noise.
Dealer says it's some bushings in the clutch assembly that is causing it and I'm taking it in on thursday to have whatever bushings they are talking about replaced. They tell me it's not the clutch itself though. Hope it's fixed, cause I wanna start installing all the crap I have sitting here.
8300 miles.
gotboost? is offline
post #13 of 185 (permalink) Old 09-11-2003, 11:48 PM
SXY SRT-4's Avatar
Quoted: 0 Post(s)
I have had problems with my clutch as well. I do have the knocking noise, but once in a while when I go to shift the gears don't even line up and I get a horrific grinding until I reengage the clutch and try shifting again. At first I thought that I was crazy but then I had a witness in the car, he was driving. It also will have the tendency to stick between gears. I thought that it was just because it was brand new, but that excuse wore out a long time ago. I took it to the dealer, and after convincing them that it was my car, they basicly drove it around the block and said "well we did not have that problem, so it must just be you" So now I am just waiting for it to happen again so that I can keep taking it back.
Amber Ranstrom
9K
one trip and two phone calls to the dealer
No resolution
'03 Silver SRT-4 2.4 Turbocharged Stage I
www.totacc.com/user/glenzoni/
SXY SRT-4 is offline
post #14 of 185 (permalink) Old 09-12-2003, 06:10 AM
abubamsry's Avatar
Quoted: 0 Post(s)
Dupes
Ditto on all infor above (minus personal info). Mine does the same thing, except when I listen closely I can hear it in hight gears, just barely though. No vibration though.
AbuBamsry
I also have not taken it in.
No resolution if I haven't taken it in.
Over 12,000 miles
Remember Hitler was a Catholic, not an Atheist.
Muslim is a peaceful religion.
And the FSM promises a Beer Volcano and a Stripper Factory!
abubamsry is offline
post #15 of 185 (permalink) Old 09-12-2003, 06:13 AM
dymondboy2f's Avatar
Quoted: 0 Post(s)
Re: SRT-4 Clutch Problems. Report yourself here.
Your nick
Symptoms of the car
does quaffie (can't spell) make high performance clutches? i think i heard someone say they did, if so I'm pretty sure they'd fit our cars as i wanna look into this more
When it comes to envy y'all is green.
Originally Posted by Ultimateone
Lucas you crack me up
2004 Neon Mods: 435whp. Pump gas, nukka.
2006 GTO originally silver/red interior--full Holden Conversion, bolt ons+suspension+paint you probably hate.
2009 Pontiac G8 GT Black w/ red/black interior-Stock(Daily Driver).
dymondboy2f is offline
User Tag List
Linear Mode Linear Mode
