Spun rod bearing? Way to check? - Dodge SRT Forum
post #1 of 21 (permalink) Old 07-07-2008, 11:51 AM Thread Starter
Roach's Avatar
Quoted: 0 Post(s)
besides a teardown, are there any sorts of tests that can be done with the engine in place to help see if there is anything fucked up with a rod bearing (spun)?
Thanks
2.0L SOHC - 400whp 11/11/04 - still shooting for 450whp+
Check out my mods and pics here
Roach is offline
post #2 of 21 (permalink) Old 07-07-2008, 11:55 AM
maxfastest's Avatar
Quoted: 0 Post(s)
If a bearing is spun, You can count on more damage
than can be bandaided back to health !
Plan a complete rebuild or replacement.
I've Been turning wrenches longer than most
of you have been Alive !
maxfastest is offline
post #3 of 21 (permalink) Old 07-07-2008, 12:17 PM Thread Starter
Roach's Avatar
Quoted: 0 Post(s)
hmm ok I dont thinnk its spun, however id like to be on the safe side. Im weighing out my options right now. If a bearing were spun would the car drive like crap? Would it make a loud ticking noise, and get louder as I rev? My compression is spot on and the car drives like normal. I do have some knock at 2800-3000rpms in all gears but thats been there for a little while now (getting aeroforce to update my sct flash with it to fight it)
Thanks
Roach is offline
post #4 of 21 (permalink) Old 07-07-2008, 12:25 PM
Thuper Moderator
STUDLEE's Avatar
Quoted: 0 Post(s)
tear it down. even if its not a rod, it sounds internal with the noise increasing with the rev. Im sure you will find something potentially deadly on the teardown even if its not spun. better safe then sorry.
SRTForums Member...
STUDLEE is offline
post #5 of 21 (permalink) Old 07-07-2008, 12:27 PM
Quoted: 0 Post(s)
give it some load in say 4th or 5th gear in low rpms. easiest way to hear for it...
it will sound like marbles in a tin can.
its distinct. if you hear it, you have a spun bearing. no way to miss it...
91PumpKing. is offline
post #6 of 21 (permalink) Old 07-07-2008, 12:29 PM
Scammer
onthedwnlow's Avatar
Quoted: 0 Post(s)
with out a tear down there is no real way to check......but spun rod bearings will make a sqealing noise......if the bearing was totally gone it will tap.....if the bearing was gone it would have a slightly lower compression than the rest.....but yes you need to tear down
onthedwnlow is offline
post #7 of 21 (permalink) Old 07-08-2008, 05:18 AM
maxfastest's Avatar
Quoted: 0 Post(s)
Could also be loose bolts on the flex plate / flywheel,
depending on clutch setup. Alternator problem, water pump
so it,s very hard to tell without being there.
post #8 of 21 (permalink) Old 07-08-2008, 05:45 AM
blackbird_R/T's Avatar
Quoted: 88 Post(s)
Used oil analysis. A bad bearing will easily set off a big red flag (and the analysis can help spot other premature wear issues and internal problems before they get too big, in addition to showing help well your oil is performing). Also if you can get an automotive stethoscope and listen while free revving the engine you should be able to pinpoint the noise. Rod knock will be very noticeable while listening to the lower end of the engine. You should also be able to connect a manual pressure gauge to the block (take off the stock oil switch and connect the gauge) to check what oil pressure is doing, but if you suspect a bad bearing I wouldn't run the engine much.
Eric H. - '04 Neon SRT-4 (eBlue/S2) - '04 SRT-4 (blk/stock & now sold)
'92 Dodge Daytona IROC R/T --- -- '91 Dodge Spirit R/T
plus a couple other turbo Dodges, a Cobalt, a couple Focus, big S/C wagon, and some other stuff...
blackbird_R/T is offline
post #9 of 21 (permalink) Old 07-08-2008, 06:39 AM
SRTie4k's Avatar
Quoted: 0 Post(s)
Grab a long screwdriver and place it between the runners on the top of the block and put your ear against the end of the screwdriver. You'll be able to find it fast if its internal.
2008 Mazdaspeed 3
- Cobb AP, CP-E Nano SRI, ETS 3.25" TMIC, SU Test Pipe, Progress RSB, Short Shift Plate, SU Solid Shifter Bushings, MSD Dashhawk, 18x8.5 Rota G-Force's, 235/40/18 Hankook Ventus V12's
1997 Suzuki TL1000S Naked Frankenbike
- Lot's o' custom stuff
SRTie4k is offline
post #10 of 21 (permalink) Old 07-08-2008, 07:12 AM Thread Starter
Roach's Avatar
Quoted: 0 Post(s)
im actually pretty confident my sound is coming from a pulley or access. belt. i overfilled my p/s resevoir and the next day i got a squeel. Ive since sucked a bunch out but it still will squeel for a few minutes when i first begin driving. no longer at idle just while rpms are up. it seems to be doing it for shorter and shorter amount of time.
im almost thinking the belt is impregrenated with the p/s fluid. or maybe the fluid got into one of the pulleys...
or maybe its not even related and was purely coincidence. anyhow i wanted to just keep an eye out for other things it could be (such as the rod bearing). I did make another post without any luck but i figure if i remove the access belt and no sound then its related to belt or pulley so.... ill do that but i cant seem to find the tensioner release.?
Thanks
Roach is offline
post #11 of 21 (permalink) Old 07-08-2008, 07:24 AM
maxfastest's Avatar
Quoted: 0 Post(s)
Thanks
Put car up on jack stands and pull the lower splash shield off
that is on the pass side of engine, you will see the tensioner there.
post #12 of 21 (permalink) Old 07-08-2008, 07:25 AM
mopar1's Avatar
Quoted: 0 Post(s)
I agree an oil analysis will tell you right away. If you spun a rod bearing you would hear it. I spun a bearing on my 70 Cuda and it sounded like someone was beating the car with a hammer and got worse every second. The oil filter was full of metal and the cam and oil pump were scared and that all happened in a few minutes!
Mopar Stage 2 w/ Toys
Mopar Strut Tower Braces
Mopar Stage 1 Sway Bars
Mopar Rear Tension Struts
Mopar STS w/ Boogers
Mopar Valve Cover
Mopar Sirius Radio Upgrade
Mopar BOV
Mopar Cat Back Exhaust
Mopar Gauges w/ Pod
Mopar Stage 1 Springs
Mopar CAI w/Splash Shield
DCR Oil Fow Modifier
Custom Seat Belt Pads
CLK Style Tail Lights
MSD Coil w/ Wires
SilverStar Lamps
ShowParts Injector Cover
1st Place Winner 2006/2007 All-Chrysler Nationals
mopar1 is offline
post #13 of 21 (permalink) Old 07-08-2008, 07:29 AM Thread Starter
Roach's Avatar
Quoted: 0 Post(s)
after a few minutes my car (idle or revving) has none of the original sound i get during startup. like i said, the spun bearing question was more of an extreme whatif that i wanted to think about just in case. but im guessing if it was bearing the sound wouldnt go away at all
Roach is offline
post #14 of 21 (permalink) Old 07-08-2008, 08:30 AM Thread Starter
Roach's Avatar
Quoted: 0 Post(s)
On the way to work I timed it. Took approx 2min before the noise went away. That is without any sort of waiting around in my driveway for warmup. In fact the tstat was at approx 150deg so the engine wasnt fully warm yet.
Regarding the tensioner, man that stinks. On my old 2.0L SOHC the adj knob was right under the power steering pump and easy access from the top of the engine bay. Oh well, cant have my cake and eat it too I suppose.
Any other thoughts?
Thanks guys!
Roach is offline
post #15 of 21 (permalink) Old 07-08-2008, 08:33 AM Thread Starter
Roach's Avatar
Quoted: 0 Post(s)
Whats an example of slightly lower? I checked it over the weekend and it was something like
165, 165, 165, 170
Ive gone off the 10% rule, in which this case would be +- 16. So mine would in fact be more like a diff of 3%
Just getting thoughts on this. Thanks
Roach is offline
User Tag List
Linear Mode Linear Mode
