Old 03-26-2008, 09:59 PM   #1 (permalink)
Member Number: 60248
Default Running Low Boost??
Hey guys I've been looking to trade my Civic Si for an SRT-4 for a little bit now. I think I found one I really like. Its black with 21k miles and its wicked clean. The only problem i found was that it is boosting 9 PSI. I'm almost positive from reading around here that stock boost should be around 14.5 right? Car is bone stock except for the Mopar blow off plate. Does do you think could be wrong??
Luca88 is offline   Reply With Quote
Old 03-27-2008, 04:39 AM   #2 (permalink)
blab10's Avatar
Member Number: 6648
Trader Rating: (13)
Could be as simple as a boost leak or something much much worse.
310hp/324tq - SAE
blab10 is online now   Reply With Quote
Old 03-27-2008, 06:30 AM   #3 (permalink)
rrmike1's Avatar
Member Number: 55729
Temperature has an effect on boost as well. If it's really cold outside, the pcm will lower the boost to offset the denser air.
Stage 2 w/o toys, FBM pnp'd turbo/mani., Rage 55mm T/B, AGP WGA, AGP CAI, MPx 3" O2, Maxxfab 3" DP no-cat, Mopar Exhaust, AEM UEGO, SprayItRacing BOV, Crane 8.5mm wires, Champion RE10pmc5's, 180 thermo, RFR check valve, Prothane race MM inserts, Autometer 30/30, SCT Tuner, Tein H-techs, Proparts dual-gauge pillar, Fuel pump re-wire.
rrmike1 is offline   Reply With Quote
Old 03-27-2008, 10:36 AM   #4 (permalink)
Mr.srt-4's Avatar
Member Number: 52154
^^ True and if u tried to boost right at the start of the test drive it wont boost any higher than like 7-9 lbs. The computer controls exactly whats going on so as not to hurt the motor at start up.
I wana Go fast......
ZIP TIES FTW!!!
Mr.srt-4 is offline   Reply With Quote
Old 03-27-2008, 11:06 AM   #5 (permalink)
RSchyns's Avatar
Member Number: 2019
Trader Rating: (17)
I believe 1st and 2nd are boost limited.
Wind it up in 3rd... and report back.
RSchyns is offline   Reply With Quote
Old 03-27-2008, 11:09 AM   #6 (permalink)
Member Number: 24062
Second should have full boost. If you are looking at a dealer, they may have put reg unleaded in, which will pull boost. Thats what the dealer I bought mine from did...
joesstripclub is offline   Reply With Quote
Old 03-27-2008, 11:17 AM   #7 (permalink)
hardcore's Avatar
Member Number: 30646
Check to ensure the boost gauge is sitting at 0 when the car is shut off. It is fairly common to have the stock boot gauge break. From what I remember when mine broke, it read 11in-hg when shut off and only boosted to 7-8psi.
Also, as MRSRT said, the PCM will not allow full boost until the car is warmed up. To be safe, make sure the temp gauge is at 200°F.
At low temperatures, the lowest boost the PCM will give is roughly 11psi. The manual says it will vary between 11 and 15 psi in stock form depending on a variety of parameters. The lowest my car ever saw in winter was 11psi on stock bost control.
----The Old----
Stock Turbo+fuel/tuning+boltons.13.37@110(2.2 60')
---The New----
GT3071R
13.1 @ 117 (2.3 60' on Ventus RS2's) with new tune
Dynoed 333 whp & 337 wtq (13.3 @ 114)
hardcore is offline   Reply With Quote
Old 03-27-2008, 02:29 PM   #8 (permalink)
rrmike1's Avatar
That's a good one!! Those cheap motherfuckers aren't gonna pop for the right gas...
Old 03-28-2008, 10:50 AM   #9 (permalink)
Hey guys thanks for all the input. The dealer let me actually take it home for the day so I got a few things to report back on.
1) I let the engine warm up and did pulls in second and third and never made it past 9 PSI.
2) Boost gauge is not sitting at 0 when idling/is at 0 when car is shut off
3) Dealer said boost ranges from 9 to 14.5? I said ok but I never make it past 9 and they did not really have a better answer.
4) Went and put 93 Octane gas in it before the pulls
Last edited by Luca88 : 03-28-2008 at 10:55 AM. Reason: *Forgot to say i went and added premium (93 Oct.) myself..Car had no gas!
Old 03-28-2008, 12:20 PM   #10 (permalink)
Mr.srt-4's Avatar
Well if the boost gauge sits at zero when its off it should be ok. When its idling it should be around 18-21 vac or so. So my guess is you have a vacuum leak. I think you said that it had the mopar BOV plate. Check there, and i believe there is a how to on how to check for vac leaks.
Another thing.... bring it to a trusted mechanic that u know and let him or her check it out for you and give u the low down on it.
Old 03-28-2008, 12:35 PM   #11 (permalink)
Member Number: 30178
It probably won't make a difference but you could try reseting the computer.
FYI The boost gauge should sit at 0 when car is off and approx 22"hg while at idle.
Overall, It's probably a bad boost leak. You need to do a leak check. I bet the mopar blow off plate is leaking...
JC
Mods: Mopar BOV, AGP 3" CAI, Mopar Stage 2 w/ Toys, Mopar Cat-Back, Prothane Race motor mount inserts.
jaredcarini is offline   Reply With Quote
Page generated in 0.17901 seconds with 11 queries
