Old 05-11-2008, 09:40 PM   #1 (permalink)
Member Number: 60882
Default Only spiking 7psi?
I even turned the MBC nob all the way and nothing changed, boost is still spking at 7psi...what could be the issue? I don't have a stg 2 WGA or anything. Any other way to up the boost?
korean_evan is offline   Reply With Quote
Old 05-11-2008, 09:51 PM   #2 (permalink)
Member Number: 9221
you have to make sure your vac lines are hooked up right and that the MBC is hooked up right. The pic you showed me had no vac lines that i could see. Also you could have a boost leak a very big one
GO FAST PARTS
Stage 1
FM E1 turbo
FM WGA
Dtec FC
AGP returnline
PTP 55mm TB
PTP check valve
ED hardpipes w/ HKS BOV
Maddog STS 72%
AGP motor mounts
Zeitronix ZT2 wideband
NGK v power plugs .040
8.5 MSD wires
Needswings DP (no cat)
Quickwhips direct fit FMIC
180 thermostat
Bwoody H-brace combo
Bwoody Trans mount
AnotherNeon is offline   Reply With Quote
Old 05-11-2008, 10:24 PM   #3 (permalink)
pics of the car might help...
Old 05-11-2008, 10:30 PM   #4 (permalink)
lilmike0450's Avatar
Member Number: 56278
Did you check your ic pipes???
05 White ACR
lilmike0450 is offline   Reply With Quote
Old 05-12-2008, 12:07 AM   #5 (permalink)
nope, I don't know ANYTHING =/
Old 05-12-2008, 08:17 AM   #6 (permalink)
Member Number: 61736
I'm not an expert but if your boost gauge is spiking at 7psi and your car is pushing less than what it should which is around 13psi, then it's either a leak or can be your boost gauge. I had the same exact problem. Got a new boost gauge, problem solved.
arashfcb is offline   Reply With Quote
Old 05-12-2008, 08:55 AM   #7 (permalink)
silversrt487's Avatar
Member Number: 44033
probably a leak, check make sure all lines are tight, maybe get some twist ties or somethinn to keep em in place these cars are big for boost leaks
Mopar Stage 2 W/O............and more
silversrt487 is offline   Reply With Quote
Old 05-12-2008, 09:36 AM   #8 (permalink)
05BlackSRT's Avatar
Member Number: 31129
just pull the hose off of the wastegate and leave it...it will make plenty of boost..lol
-Tein S-Tech Springs
-AGP WGA
-Turbo XS MBC
-3" Cat-delete Downpipe
-K&N CAI
-Apexi Turbo Timer
-Greddy Type RS Blow off Valve and Charge Pipe
-5% Tint
-Xenon Visions 8000k HID's
05BlackSRT is offline   Reply With Quote
Old 05-12-2008, 09:38 AM   #9 (permalink)
STUDLEE1A's Avatar
Member Number: 54852
dude you cant tell that to a new guy.. he might do it!
S1, NeedsWings DP, AGP UPP w/HKS, WGA (17 Spike, 15 Hold), 55MM TB, Oil Modifier, Maddog 80% w/ Pizza Boy Ball, MM Race Inserts, MSD CP/Wires, Iridium Plugs (Stock Heat Range), 180*, Viper 791XV with Remote Start/Turbo Timer.
STUDLEE1A is offline   Reply With Quote
Old 05-12-2008, 09:53 AM   #10 (permalink)
b4christ15's Avatar
Member Number: 11213
No offense man, but if you don't know ANYTHING then the last thing you want to be doing is messing with the boost on your car. Find a local who knows some stuff. Also, I'd suggest doing plenty of research before making any changes to the car. Best of luck!
-Silver 04-
Mods: Injen SRI, Perrin Charge Pipe w/HKS SSQV, Prothane MM Inserts, MSD 8.5mm Wires, AGP WGA @16psi, 3" Catless DP, Mopar/Borla Catback, 17x7.5 Zen Rims wrapped in 225/45/17 Kumho Ecsta ASX, AeroForce Scan Gauge, Powerslot Slotted Rotors & Hawk HPS Pads
b4christ15 is offline   Reply With Quote
Old 05-12-2008, 10:31 AM   #11 (permalink)
yeah I know I know, but it's well below stock boost, almost HALF of stock boost...I just want to be able to enjoy the car at, at LEAST stock standards you know...I mean even spiking at 5psi, the car is still significantly faster than my old automatic tiburon, but 5 psi is like what, 1/3 of the stock standard...
Old 05-12-2008, 10:42 AM   #12 (permalink)
b4christ15's Avatar
Heres something to get you started.
HOW-TO: Test for Boost Leaks
IMO, if you want to raise the boost, make sure you have the proper monitoring tools and your car is up to date with maintenance. I would ditch the MBC and at least go for an aftermarket WGA. Read the stickies and browse through the how-to section and you'll have a lot of your questions answered.
Old 05-12-2008, 12:53 PM   #13 (permalink)
X2. I didn't know much about my car at the beginning either. Just take it to a performance shop and ask them questions. and keep reading the forums. lots of good stuff
Old 05-12-2008, 01:18 PM   #14 (permalink)
srt4mesir's Avatar
Member Number: 63269
take out the boostcontroller and blow air through it while adjusting it.....if the amount of air flow changes while adjusting chances are your BC is fine.
now the only way to test your wastegate is to buy mine off me
jk..... No but seriously i have an aftermarket for sale.
what did you do with the stock vacuum lines?
Caliber =
03 Solar Yellow
-Agp stage 4 -turbonetics hp-61 -Turbosx BOV -AGP FMIC (race) -Mopar CAI -Built 2.5l (800hp rating)-Hahn portfueler -stage 1 (complete) -Emanage blue -Greddy E0-1 EBC -Exhaust Depot 3 inch -Coldside pipe (SOON)-And some other goodies
srt4mesir is offline   Reply With Quote
Old 05-12-2008, 01:32 PM   #15 (permalink)
wasn't a boost leak, the moron who owned the car before me installed the MBC backwards so the raise boost is lower boost and the lower boost is raise boost, and be it me the moron who never bothered to reverse them -_-. Now the main issue is I can't quite find the spot where stock is...so let me get thsi straight
1st gear spike at 18
2nd gear spike at 15
3rd gear spike at 13...stock (at 3500 rpms)
is this correct?
I really really don't want to over boost and damage by engine.
Page generated in 0.33553 seconds with 11 queries
