Old 10-31-2009, 04:03 PM   #1 (permalink)
LmSRT4's Avatar
Member Number: 56504
Question only boosting 5 lbs please help
ok so I used realtune's diagram for the vacuum lines the one for the rice plate and I zip tied all the lines but when I go to boost I only get 5 - 7 psi I checked my intercooler pipes and they are all tight idk what to check next any advise is helpful thanks guys
"I went to WOT shift from 3rd to 4th, but I accidentally slammed into 2nd gear and tacked out at 8,000rpms..."
"it is to possible! i did it one time to but i have a black srt so nothing happend......"
LmSRT4 is offline   Reply With Quote
Old 10-31-2009, 05:19 PM   #2 (permalink)
LmSRT4's Avatar
by the way my car is an 04 with a mopar stage 2 wastegate with the mopar rice plate i just got my car put back together cuz i had to replace the rod bearings and it ran fine boosting 18 lbs but now its not...i tried to search for a similar case on the threads but i couldn't find anything close
Old 10-31-2009, 08:32 PM   #3 (permalink)
SRTforums Junior Admin
stowaway's Avatar
Member Number: 3286
you ocan only do the vacuum line reroute if you have a non-mopar wga. Since you do have a mopar one the most you can boost is the spring rate in thet wga which I believe is 7psi for the s2 wga. You need to be on pcm controlled boost with a mopar wga if you're expecting decent boost levels.
Old 10-31-2009, 08:59 PM   #4 (permalink)
LmSRT4's Avatar
but i dont get it, i was boostin 18 before the rebuild
Old 10-31-2009, 09:14 PM   #5 (permalink)
Member Number: 69074
Do a complete boost leak test?
04 Silver SRT-4
Stage 1, FM WGA @ 18/15, Catchcan w/ CV,
MM Inserts, iridiums, Gratenelli Wires,
Mopar STS, Injen SRI,
JMB uppipe w/ Greddy Type S,
marthastricycle is online now   Reply With Quote
Old 10-31-2009, 10:27 PM   #6 (permalink)
LmSRT4's Avatar
i just looked up on how to make one so i need to do that but if i zip tied all the lines it should be sealed unless there is a crack or something in the middle of the lines somewhere
Old 10-31-2009, 10:34 PM   #7 (permalink)
hercfe's Avatar
Member Number: 19255
if you JUST rebuilt the motor, you may want to do a comp/leakdown test. could be more problems than just low boost.
hercfe is offline   Reply With Quote
Old 11-01-2009, 06:14 AM   #8 (permalink)
stowaway's Avatar
Member Number: 3286
with the same wga and the same vacuum line setup?
Old 11-01-2009, 07:44 AM   #9 (permalink)
Member Number: 69186
You WILL NOT get 18 psi out of the stage 2 wastegate without the pcm boost control solenoid or some other manual boost controller. You need to hook your vacuum lines back up like stock.
If you get an agp/ptp/etc adjustable wastegate you can do it how realtune says but that is only because those have like 12 psi springs and are adjustable.... the stage 2 waste gate has like an 8 psi spring and is non adjustable so without a boost controler of some sort you will only ever get 8psi.
DoodEdge is offline   Reply With Quote
Old 11-01-2009, 12:50 PM   #10 (permalink)
LmSRT4's Avatar
any1 have the stock setup diagram for the vacuum lines? i will try that before i go any further, or should i just buy a better wastegate like agp or sumthing?
Old 11-01-2009, 01:03 PM   #11 (permalink)
The First Ghost's Avatar
Member Number: 47649
the stock vac line diagram is printed under the factory hood..
The First Ghost is offline   Reply With Quote
Old 11-01-2009, 11:16 PM   #12 (permalink)
Just hook it back up like stock. Search stock vacuum line diagram or things like that
Old 11-03-2009, 04:32 AM   #13 (permalink)
lil_hub_cap's Avatar
Member Number: 75014
man has a point. boost leak the entire car.
lil_hub_cap is offline   Reply With Quote
Old 11-03-2009, 02:51 PM   #14 (permalink)
m4ster_chef's Avatar
Member Number: 74316
What'd that guy get b& for?
Also, what they said about having to be on pcm controlled boost. Without having the vac lines like they were stock, you won't make diddly with the mopar wga.
2004 NSRT
Full S3 w/o toys
Spiking 24, hold 22
AEM Wideband & Pyrometer
Mopar Short throw shifter
Motor Mount Inserts
Prothane LCA bushings
COMING SOON: N2MB toybox, DSP, scangauge & SOLID MM's.
m4ster_chef is offline   Reply With Quote
Page generated in 0.15863 seconds with 13 queries
