Old 06-21-2008, 08:04 PM   #1 (permalink)
cz3ch's Avatar
Member Number: 64786
Default No coolant in the system?
Ok, I just picked up an 03 SRT-4 and everything is running fine. My temps are staying at about 200F or less when Idle and 210 when idling on a hot day. One thing I noticed is when I look at the tank in the back by the firewall, I can't see any coolant at all.
This is my first SRT-4 so I'm a bit new here, but I read the service manual and I should see the fluid in the fill tank. But I don't see any at all. The thing I did notice is my tstat, the cap was loose, apparently I was driving like that. So I tightened it up.
Could my coolant have evaporated some and I'm just low? Or is it just hard to see? When I shine the light back there the bottle looks empty though when I feel the coolant line it's pliable but feels like something is flowing through it.
I know this is a pretty stupid post, but I would like some sage advice.
Thanks guys!
cz3ch is offline   Reply With Quote
Old 06-21-2008, 08:08 PM   #2 (permalink)
Ghowie's Avatar
Member Number: 33090
Trader Rating: (55)
fill it to the fill line and keep a eye on it,then go from there
Originally Posted by dansrt4
For a shop thats so behind maybe you should catch up on orders before you catch up to me.
Ghowie is offline   Reply With Quote
Old 06-21-2008, 08:10 PM   #3 (permalink)
cz3ch's Avatar
Ok, stupid question #2.... Fill it when it's hot or cold?.. And what do you recommend I use? I was going to use Prestone, but would like to know what everyone is running.
Thanks!
Old 06-21-2008, 08:18 PM   #4 (permalink)
Ghowie's Avatar
Trader Rating: (55)
Thanks!
fill it when its cold,use the recomended mopar fluid.
Old 06-21-2008, 08:20 PM   #5 (permalink)
cz3ch's Avatar
Thanks, I'll give it a shot.....
Old 06-21-2008, 11:49 PM   #6 (permalink)
my_little_srt's Avatar
Member Number: 41179
Might want to make it a mixture of coolant and water..............And sonce your in H-Town, might want to go with more water than coolant...........
my_little_srt is offline   Reply With Quote
Old 06-21-2008, 11:52 PM   #7 (permalink)
cz3ch's Avatar
I don't disagree there. There's no where that I know of to buy Mopar coolant on a Sunday (dealerships are closed). Any other thoughts of what other coolant/antifreeze to use?
Old 06-22-2008, 12:44 AM   #8 (permalink)
Fischy's Avatar
Member Number: 20133
Most auto parts stores stock Zerex G-05 Coolant, which is compatable with our stock fluid.
Read the directions on how much water to mix in. If the coolant level continues to drop you might have a bad head gasket or coolant hose.
G-05® Antifreeze/ Coolant
Steve
'04 Silver SRT-4, Hotchkis TVS, MannyZ rear arms
Fischy is offline   Reply With Quote
Old 06-22-2008, 01:07 AM   #9 (permalink)
cz3ch's Avatar
Steve
I'd been searching on "coolant leaks" and I saw the info on the bad head gasket/tstat. So I will start with the fluid tomorrow and see how that goes. From what I read about the G-05 it's pre-mixed 50/50, looks to be pretty decent stuff, we'll give it a whirl, and thanks!
Old 06-22-2008, 10:44 PM   #10 (permalink)
cz3ch's Avatar
Update:
I got some zerex G05 and mixed it as directed and filled the system. Running temperature stayed about the same, I think the loose cap on the tstat had the coolant going bye bye... I think I put a bit too much in the overflow tank as when I shake the bottle it comes out the drip pipe. I'll keep an eye on it and update as needed, so far I think I solved the problem.
While I was at it, went ahead and did an oil change with mobile1 and the car purred
Page generated in 0.17141 seconds with 11 queries
