Old 06-21-2008, 03:58 PM   #1 (permalink)
Member Number: 55098
Default New plugs, less boost? please help
I just changed my plugs to ngk iridium's (LZTR5AIX-13) some people told me they are pre gapped others said to gap them to stock specs. i dont have too many mods so the stock gap is fine with me. Under the hood the sticker sais the stock gap is .050 so i checked the new plugs and they were less than that , they were around .040 so i gapped them to .050 when i pulled out the old plugs which i think were the origional plugs they were not gapped to .050 more like .065 ... so i put the new iridiums in gapped at .050 and idle was very smoothe i took her for a rip and everything looked fine but it feels like the turbo is not as responcive, its like it needs ore throttle to get even up to 10 psi.. not sure whats goin on but any info/help would be great.. thanks guys
I think I need rehab, I'm addicted to speed
Street racing is like the special Olympics, even when you win you are still retarded!
Quote: Originally Posted by never2muchboost
"lol @ mopar having a wot shift feature....wtf are they thinking they have"
Mr Magna-Mopar Man is offline   Reply With Quote
Old 06-21-2008, 04:35 PM   #2 (permalink)
SRT4SINA's Avatar
Member Number: 30904
Trader Rating: (10)
you probably have a vacuum leak coming from the plugs since you installed them yourself. Did you change them with the engine being completely cold? Are you getting any codes?
BTW, You don't need Denso Iridiums; all you need are some NGK 4306s or some Champion 570s gapped to about .45 (which is what I run).
03 Solar Yellow SRT-4
Zero boost leaks and Some stuff under the hood.
Powered by: a.c.t. Energy
The healthiest and wisest choice in Energy Supplement Consumption.
actenergy. c o m/ act4abe (no spaces)
SRT4SINA is offline   Reply With Quote
Old 06-21-2008, 04:36 PM   #3 (permalink)
HCCAFan's Avatar
Member Number: 35768
Trader Rating: (18)
I don't think it's plug related.
HCCAFan is offline   Reply With Quote
Old 06-21-2008, 04:38 PM   #4 (permalink)
stxsrt's Avatar
Member Number: 37057
Trader Rating: (28)
just retourque the plugs, there probably loose. x2 you dont need denso's. I run 25 psi on my ngk's gapped @ .48
stxsrt is offline   Reply With Quote
Old 06-21-2008, 05:25 PM   #5 (permalink)
HCCAFan's Avatar
Trader Rating: (18)
He said he is using NGKs
Old 06-21-2008, 08:26 PM   #6 (permalink)
it wasnt fully cold, maybe this is the problem i know the engine was still pretty hot when i changed them.. what can this do? i tightend them right untill they were not turning anymore but not over tight.. i have never had any boost issues untill i changed the plugs
Old 06-22-2008, 09:10 AM   #7 (permalink)
so i put the old plugs back in and still feels like ive lost some power and some boost.. wont really go over 10 psi for some reason.. I always tighten plugs by hand without a torque wrench ... it seems like i can tighten the plugs by hand with the extension untill the point where it wont get any tighter, then i put the socket wrench on and tightend it a little more.. is this correct or are the plugs not tight enough they are to the point where they wont really get tighter without alot of force butnot too tight.. please help
Old 06-22-2008, 09:50 AM   #8 (permalink)
reddy's Avatar
Member Number: 9502
that is what I do...... get a cheap set of champions
dielectric grease (usually at the counter) and replace them.......
I have tried other plugs and had weird problems, so I always go back to those darn dependable champions
Stock 04' as far as u know!
reddy is offline   Reply With Quote
Old 06-23-2008, 12:32 AM   #9 (permalink)
SNOOPALOOP's Avatar
Member Number: 29605
Trader Rating: (17)
NGK or Champions.. either one should work. Boost leak test too
SNOOPALOOP is online now   Reply With Quote
Page generated in 0.15972 seconds with 11 queries
