Old 06-30-2005, 06:15 PM   #1 (permalink)
Skankhair's Avatar
Member Number: 30114
Default New Owners FAQ
I'm a new SRT-4 owner, and the SRT-4 is my first car of this level of performance and rawness. Thus, a lot of the sensations of the car are new to me, and this has lead me to ask many "is this normal?" questions. To help other new SRT-4 users, here are those questions and answers as well as other common questions.
I am no SRT-4 expert, so bare in mind these answers are not my own. I will try to credit the people that gave me the answer where possible.
As of now, this is only for stock SRT-4s. If you would like to add FAQs for modded cars (such as "I installed a Stage 1 turbo, and now my car does this ______. Is this normal?"), post here and I will copy it to the first post. Additions for stock SRT-4s are welcome as well. Also let me know if you feel any of the answers I posted are wrong.
I don't want to step on the toes of the other stickies, so only submit questions/answers not covered by another sticky.
1) At low RPM and in 1st and 2nd gear, I can hear a faint rattling noise from the front of the car. It sounds a little like a rainmaker. You know, those tubes filled with sand that you turn over to make the "sound of rain". It happens when I am at parking lot speed and let off the gas a little bit (happening in conjuction with the pops from the exhaust), but also happens as I gain a little speed, going away at a certain RPM. As I gain a little speed, it sometimes comes in, goes away, comes back etc... rather than being linear with the RPMs. It only happens when I am in gear, not when coasting. Is this normal? What is it?
A) This is normal transmission noise (normal in the SRT-4) and nothing to worry about. (thanks DAN_3KVR4_SRT4 and neonsohc)
2) My last car was a basic economy car, and at parking lot speeds the car was smooth. The SRT-4 bumps and writhes while at parking lot speeds. I know I can fix this by using a little clutch, but I want to know if this is normal (I have heard reviewers say that cars such as the Lancer EVO act like this while moving very slow), or if I just suck with the manual and need to use more clutch at these speeds. In other words, should I use more clutch, or just deal with the bucking (I don't mind it)?
A) This is normal and happens a lot with high performance cars as the throttle is very touchy and the engine is not happy when not being pushed. Don't use the clutch to smooth it out, as this puts excess wear on your clutch. (thanks DAN_3KVR4_SRT4 and yourfate)
3) My car idles a bit rough. The RPMs don't move up and down, but the car shakes a little and feels like it is misfiring.
A) This is normal. It can be fixed by doing certain mods to the car (some claim it goes away with better sparkplugs), but it is normal for an SRT-4 to do this and nothing to worry about. Performance engines often have rough idles.
4) My car shakes after I turn off the engine.
A) This is normal. Make sure you have the clutch *all* the way in when you turn it off, as having it not in all of the way can make the shaking more noticable, but even with the clutch in, this will happen on virtually all SRT-4s.
5) My car's engine makes popping and burbling noises at low RPM when I give it less gas, and when I downshift.
A) This is not only normal, but awesome. This happens on most performance engines with low-restriction exhausts.
6) Does the SRT-4 really have no mufflers?
A) Yep. It does have 2 resonators, though.
7) My boost spikes at ___ and holds at ___.
A) Normal boost for a stock SRT-4 can vary a bit depending on the car (there is always a degree of variation with cars of the same model) and the climate. Stock boost is 14PSI, but it is normal to see peaks of anywhere from 13 to 15PSI and hold anywhere from 12 to 14PSI. If you are in that range, your car is normal. If you are a lot less, then you may have a boost leak, or are using lower-than-91 octane gas. If you put 91 octane gas in, the computer will notice this and change the settings so that you make full boost. My car peaks at 14PSI and holds around 12-13PSI.
Just remember that your boost is based on many conditions. So do not be scared if your boost is a little lower or a little higher than other people, or if it changes from day to day (12-15 peaks are what I call the acceptable range). Also, it is normal for the boost to change a little bit during full-throttle. For example, it will raise to 14, then fall to 12, then go back to 14, then fall again. This is just the engine controller trying to achieve the desired torque. However, if your boost gauge rapidly flutters it may be the sign of a boost leak. This is especially a problem if the car studders while this is happening. (thanks Dr. Who)
Some people say their boost raises to 14 (or so) then falls to 12 (or so) just before redline. This fall just before redline is also normal.
Keep in mind the stock boost gauge is not perfectly accurate. It is a good guide, but don't think of it as the Bible. If your friend's SRT-4 gauge says he boosts at 15 PSI, but you only boost 14 PSI, that doesn't always mean you are making 1 PSI less boost than he is. You may even be boosting more. So don't get too hung up on what the gauge says. (thanks Dr. Who and Bacardi 151)
8) As the weather changes, is it normal for my boost to change?
A) Yes. While colder air is denser, and thus, most cars make more power when it is cold, the SRT-4 computer will compensate for this. So when it is colder, you will make *LESS* boost since the computer is lowering the amount of boost to maintain the same horsepower (since the colder air naturally gives you more power).
This does not apply if your using a manual boost controller or aftermarket/ modified wastegate. (thanks noTe)
9) What octane gas should I use?
A) The higher the octane, the better the performance. For normal use, 91 octane is recommended. If you use 89 or 87 octane, the computer will compensate and simply lower the boost. You will make less horsepower. The driver's manual says using a lower octane won't harm your engine, but most people say otherwise, and that it will put excess wear on your engine. If you do not experience spark knock, then it is probably okay but not recommended. If you do experience knocking, then it is not okay. Opinions do differ on this. I would never use anything lower than 91 in my SRT-4, but it's up to you. If you put in 87 by accident, it's nothing to worry about. For more powerformance, you can use a higher octane gas and high octane mode (HOM) on the computer. (can someone expand on this?)
10) What oil should I use?
A) Opinions differ on this, but Mobil 1 Synthetic oil is a favorite. Which viscosity you should use depends on the climate. (can someone expand on this?)
11) How often should I change my oil?
A) Opinions differ on this (again!). Some say every 3K miles, some say every 5K is fine if you use good oil. Some like to change their oil very often when the car is new, then every 3K miles after the first 3-10K miles. There are so many different opinions here that I can't say what is best, so it is really up to you. Personally, I plan on changing my oil every 3K miles and using Mobil 1 Synthetic.
Most people say to leave the break-in oil in the car for the first 1500 miles then to switch to a fully synthetic oil. Some change their oil at 500, or even as low as 50 miles, but they replace the break-in oil with more traditional "dino" oil, not switching to synthetic until 1500 miles.
12) What should my boost gauge read when I am not boosting?
A) When idle, your gauge should read around -20PSI. I say "around" because it depends on many factors. Even pushing your brakes down harder while at a stop will move the gauge a little bit. -19, for example, is fine too. It might read -19 one day, then -18 another day. When the car is off, it should read "0". (thanks neonsohc)
13) In my SRT-4, the driver side window control has a small blue light in it. However, the passenger-side control on the driver-side door, the window control on the passenger side door, and both power lock controls (both doors) all have the same LED-looking thing in them, but they do not light up. Is this normal, or is only my driver-side window control light working? In other words, all of the window and power lock controls use the same little switch. They all have what looks like a little LED. But only the switch for my driver-side window actually lights up. Are the other LEDs not working?
A) As strange as it seems, this is normal. Only the driver-side window switch lights up. The power sun roof switch also lights up if you have that option on your car. The locks, and passenger window switches do not light up. (thanks neonsohc)
14) What is the proper way to break in the SRT-4 engine?
A) Opinions differ on this as well. Some say go easy on it, some say drive the hell out of it. But most people say (and the driver's manual agrees) that you should be fairly easy on the car for the first 300 miles, but that during that time, some wide-open-throttle (WOT) fun is actually good for the engine. After 300 miles you can start pushing the engine a little harder, but still go a little easy on it until the 1000 mile mark. You don't want to red line the engine a lot during the first 300 miles, so shift a little earlier than you would if it were a rental car. Some WOT and boosting is good for setting parts of the engine. The bottom line is to go a little easy on the engine during break in, but that some WOT fun is actually good for it. Some even say trashing the engine is best for it. Some still maintain going easy on it is the best. So it's really up for you to decide. I prefer to go a bit easy on it for normal driving, but give it some WOT runs now and then.
15) My milage is horrible! WTF?
A) This is normal. As you break the engine in, the milage will improve. How long it takes depends on many things, but you should generally start to see decent milage around 3000 miles.
16) My A/C makes a lot of noise. Just after I turn it on, it makes a loud sound, and sometimes while it is on it will make periodic noises. What's wrong?
A) Nothing. The sound is just the A/C's clutch engauging. It just happens to be a lot louder than most cars.
BAD GRINDING NOISE!!!! LOOK LOOK LOOK! (thanks)
(thanks Dr Who. and planetb)
17) My oil is green! OMGWTFBBQ!
A) This is normal. The break-in oil that comes in the SRT-4 is green. I have heard this is because they dye the oil to help spot leaks, but have also heard that it is just because of the properties of the break-in oil. I don't know either way- but all that is important is that it is normal. Everyone's SRT-4 comes with green oil. If you change to new oil and it is still green, have your system flushed. If you do and it is STILL green, then you might have coolent leaking into your oil.
18) My SRT-4 takes a few extra cranks to start when it's cold. Is this a sign of a problem?
A) No. It is normal for the SRT-4 to be a little harder to start when it's cold.
19) What can I do to make sure my SRT-4 remains reliable and in good condition?
A) A book can be written on this, but to make it simple:
-The SRT-4 is designed to be driven hard, so do not be afriad to drive it hard. But be aware that the harder you drive it, the more wear and tear will occur.
-Most recommend using synthetic oil, and changing it every 3K miles.
-An oil catch can is a popular add-on that will prevent blow-by oil from getting into the intake and intercooler, which can hurt performance.
-Check your oil level fairly regularly to make sure it isn't low, as the SRT-4 can burn a fair amount of oil (this is normal, just don't let the level get too low).
-Do all of the regular maintainence as described in the maintainence handbook.
-Most recommend sticking to 91 or higher octane, even though the driver's manual says using lower octane will lower your boost but not hurt your engine.
-Let the car warm up before you drive it hard, and let it cool down before you turn it off if you have been driving hard. The warm up allows oil to get to the cylinders and to warm up from its cold, sluggy state. The cool down is for the turbo. Turning the car off while the turbo is hot can cause oil to dry in the turbo.
-Don't go full-throttle under around 3000 RPM outside of first and maybe second gear. The exact RPM is a matter of debate and depends on your mods. Some say 2800 RPM is fine, some say 3000, and some say 3500. Reguardless of what RPM you use, the point is that going full-throttle at too low of an RPM can cause detonation and compressor surge, both of which cause excess wear. If you have been going WOT at low RPMs (especially in higher gears), just change your driving habits and don't worry. Some detonation or compressor surge won't make your engine explode, but it isn't something you want to make a habit of. (thanks hercfe)
Some easy to miss stuff:
-The seatbelt height can be adjusted on the B-pillar.
-There is a trunk release button in the glovebox.
-The optional power sun roof not only opens slightly at an angel, but will also fully retract if you hold the switch again after opening it at an angle.
-The storage compartment near the armrest has slots for CD jewel cases. And if you flip it all of the way open, the underside of the top will serve as a cup holder for people in the backseat.
Tricks:
-Reset PCM Computer
To reset your computer, unplug the negitive batery cable for 3 minutes or remove the yellow #30 fuse from the fuse box for about a minute. This will reset all knock and timing settings in the PCM.
-Find codes for check engine light.
If you check a check engine light, to find the problem, then the car off, then turn the key to "on" and then back to "lock" three times quickly without starting the car. The codes should appear near the odometer, you can press your trip button to scroll through the codes if you have more than one. Go here to see what your code means:Trouble Code List
For more codes, scroll down a few posts to my post with the large list.
Popular and cheap mods and preventitive maintainence:
-Oil Catch Can
It is common on turbo and supercharged cars for blow-by oil to get through the PCV valve during vacuum. This oil gets consumed by the engine, and/or collects in the intake, intercooler, and other parts of the car. An oil catch can is a device that seperates the air from the oil, and collects the oil in a can, thus saving your engine from burning oil and preventing your intake and intercooler from getting gunked up. An oil catch can is not needed, but can improve the long-term health of your car and is a popular add-on. It is possible (and easy) to your make own catch can for only 20 dollars, so it is a good idea to do to save your investment. http://dodge-srt4.com/howto/catchcan.html
-Check Valve
The PCV valve on the SRT-4 can leak boost. Putting a 1-way check valve after the PCV and before the throttle body (either before or after your catch can if you have one) can prevent this leak.
Oil in airbox & intercooler - PCV issue
PCV valve leaks under boost so get Check Valves
-Spring Mod
A simple (and cheap) spring in your wastegate can increase your boost. After a while, the PCM will catch on and pull timimg, but you can reset the PCM to get the boost back.
spring mod pic req.
Just did spring mod. WOW!!!!!
-Onmiphil mod
Hold more boost at higher RPM. Similar to the spring mod. Omniphil Free Wastegate Mod...
-Rolled Bumper
This is a virtually free mod to change the look of your rear bumper cover. See what it looks like and how to do it here: Rolled my bumper, and cleaned my exhaust (new thread)
Rolled my bumper, not the best pics, but what you think?
-Ziptie Lines
When increasing the boost of their SRT-4, it is rare but not impossible for some of the hoses to become disconnected under boost. Some SRT-4 owners ziptie all of their lines as an extra layer of protection. This is mainly important when using high levels of boost, but it might be a good idea to do it while stock as well. More about this later.
-Eyelids
Eyelids are an easy and cheap mod that is very popular. See the head light lids and buy them here: http://www.srt4designs.com/
-Relocated brake switch wiring harness
The brake switch wiring harness is located under the clutch pedal and gets stomped on when the clutch is pushed all of the way in. It isn't really a problem, but over time it can cause wear to the wires, and some even claim it prevents the clutch from fully disengauging. It is very easy and quick to move the harness to a safer place. Better safe than sorry. Found Potential Factory Wiring Problem!
-Coil pack/plug wires heat shield
Over time and with hard driving, the heat from the turbo can melt the plug wires. Modern Performance makes a heat shield to protect your plug wires and coil pack from the heat of the turbo. Does it actually help that much? I am not sure, but it's very inexpensive and gets you some piece of mind. Again, better safe than sorry. (thanks RSchyns and noTe) http://www.modernperformance.com/dcx...ilshield.shtml
Common problems and fixes:
-If you are driving and your brakes feel like they stop working (they still work but the power assist is gone so you have to press down VERY hard), stop the car and turn it off (use the hand brake and downshift to come to a stop). Pop the hood and look for a disconnected line behind the battery. This line sometimes pops out under very heavy boost. If your car is stock you don't need to worry about this (though it can still happen to you). If you run higher boost you should ziptie all of your lines.
no brakes... ahhhhhhhh
-It is common for the sun roof to get stuck if you open it at high speeds. To play it safe, only operate the sun roof if you are stopped or going fairly slow. The driver's manual says not to use the sun roof if going more than 75 mph, but some people have had problems opening it even at lower speeds. If your sun roof gets stuck, go here: Help! Moon roof stuck open
-Boost leak... Pretty obvious. If you are not getting as much boost as you should, a leak is likely the cause. Boost Leak Discussion/Help Thread
-Another Common Problem is the TPS (Throttle Position Sensor) going bad (written by acemp87)
Symptoms: RPMs During Idle jump around, RPMs seem to stick while driving, RPMs raise suddenly by themselves. Any or all of these symptoms can mean a bad TPS.
This problem is not caused by the TPS sensor itself, but by the harness that connects to it. The wiring is too short and becomes worn by the natural movement of the car (kinda like bending a paper clip constantly until it breaks). To check if this is the problem on your car you need to look at the throttle body. There are two electrical components that connect to it. IAC (black connector) and the The TPS (white connector). If you wiggle the wire and your car's RPMs seem to go erratic, you have a bad TPS wire. Dealer fixes it with an extended TPS wire or you can DIY.
TPS: Bad Idle, High Idle, P0123 Code? We May Have a DIY Fix
In my experience, the dealer I took it to changed the actual sensor, not the harness, which did not fix the problem. If you decide to take it to the dealer, make sure they change the wiring. They have a bulletin (TSB?) about it. (thanks acemp87)
More to come.
I will also be editting in "thanks _____" for each answer as I find the threads that provided these answers.
Skankhair is offline   Reply With Quote
Old 06-30-2005, 08:07 PM   #2 (permalink)
DAN_3KVR4_SRT4's Avatar
Member Number: 28874
Awesome man way to get into the records and do the research! Great info and keep it up!
DAN_3KVR4_SRT4 is offline   Reply With Quote
Old 07-01-2005, 09:11 AM   #3 (permalink)
neonsohc's Avatar
Member Number: 12969
Trader Rating: (10)
Great thread.
Maybe this will prevent so many threads being started about these topics as well as help the new guys find a good information source when they should search.
neonsohc is offline   Reply With Quote
Old 07-10-2005, 11:59 PM   #4 (permalink)
Skankhair's Avatar
Thanks guys. Just made some updates. Submissions welcome.
Old 07-11-2005, 05:40 AM   #5 (permalink)
Johnny Rocket's Avatar
Member Number: 29826
Default SRT-4 Synthetic engine oil
Does anyone have a good idea what is usually a good mileage to break the motor in on hydrocarbon oil before switching over to synthetic?
Johnny Rocket is offline   Reply With Quote
Old 07-11-2005, 05:44 AM   #6 (permalink)
Skankhair's Avatar
I've heard 1500 miles from a lot of people. I'll add that.
Old 07-11-2005, 07:06 AM   #7 (permalink)
noTe's Avatar
Member Number: 43
Trader Rating: (28)
Does not apply if your using a manual boost controller or aftermarket/ modified wastegate.
noTe is offline   Reply With Quote
Old 07-11-2005, 07:28 AM   #8 (permalink)
Skankhair's Avatar
Thank you. Added.
Old 07-11-2005, 11:19 PM   #9 (permalink)
Skankhair's Avatar
Updated again.
HELP: I NEED INFO ON ZIPTIEING LINES!
What lines need to be ziptied? All of them? Okay, but where are they all and how do you ziptie them? Some of them are shaped very weird and I have no idea where to put the ziptie.
Old 07-13-2005, 09:19 AM   #10 (permalink)
Member Number: 30835
Thanx for the FAQ. Lots of helpful info there. I was a bit concerned about my gas mileage being so horrible. I feel reassured now. Also good to know that the idle issues are normal. Thanx again.
RedSRT05 is offline   Reply With Quote
Old 07-15-2005, 06:12 PM   #11 (permalink)
Skankhair's Avatar
You're welcome.
Thanks to MikeCrowsoft for this expanded list of engine codes.
To get your car to display your OBD II Trouble code. Cycle your ignition switch from "off" to "run" 3 times. Do not crank or start the car! On the third time, leave it at the run position, and your OBD II Code will be displayed in the odometer window as : P0123 (or whatever code you have) , Besure to press the trip button, it will allow you to scroll through if you have multiple codes, If you do not have a code or more after the one displayed before pushing the button it will say "done".
Please keep in mind, this is a GENERIC listing for right now. "Generic" Codes are P0xxx codes. "Vendor" Specific codes are P1xxx. If you have a P1xxx code take it to the dealer if under warranty.
ENGINE specific Codes
P0100 Mass or Volume Air Flow Circuit Malfunction
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0110 Intake Air Temperature Circuit Malfunction
P0111 Intake Air Temperature Circuit Range/Performance Problem
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0114 Intake Air Temperature Circuit Intermittent
P0115 Engine Coolant Temperature Circuit Malfunction
P0116 Engine Coolant Temperature Circuit Range/Performance Problem
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermittent
P0120 Throttle/Petal Position Sensor/Switch A Circuit Malfunction
P0121 Throttle/Petal Position Sensor/Switch A Circuit Range/Performance Problem
P0122 Throttle/Petal Position Sensor/Switch A Circuit Low Input
P0123 Throttle/Petal Position Sensor/Switch A Circuit High Input
P0124 Throttle/Petal Position Sensor/Switch A Circuit Intermittent
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
P0126 Insufficient Coolant Temperature for Stable Operation
P0127 Intake Air Temperature Too High
P0128 Coolant Thermostat (Coolant Temp Below Thermostat Regulating Temperature)
P0129 -=- Not listed.
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142 O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
P0143 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
P0144 O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
P0145 O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
P0147 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
P0148 Fuel Delivery Error
P0149 Fuel Timing Error
P0150 O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162 O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
P0168 Fuel Temperature Too High
P0169 Fuel Composition Sensor
P0170 Fuel Trim Malfunction (Bank 1)
P0171 System too Lean (Bank 1)
P0172 System too Rich (Bank 1)
P0173 Fuel Trim Malfunction (Bank 2)
P0174 System too Lean (Bank 2)
P0175 System too Rich (Bank 2)
P0176 Fuel Composition Sensor Circuit Malfunction
P0177 Fuel Composition Sensor Circuit Range/Performance
P0178 Fuel Composition Sensor Circuit Low Input
P0179 Fuel Composition Sensor Circuit High Input
P0180 Fuel Temperature Sensor A Circuit Malfunction
P0181 Fuel Temperature Sensor A Circuit Range/Performance
P0182 Fuel Temperature Sensor A Circuit Low Input
P0183 Fuel Temperature Sensor A Circuit High Input
P0184 Fuel Temperature Sensor A Circuit Intermittent
P0185 Fuel Temperature Sensor B Circuit Malfunction
P0186 Fuel Temperature Sensor B Circuit Range/Performance
P0187 Fuel Temperature Sensor B Circuit Low Input
P0188 Fuel Temperature Sensor B Circuit High Input
P0189 Fuel Temperature Sensor B Circuit Intermittent
P0190 Fuel Rail Pressure Sensor Circuit Malfunction
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0194 Fuel Rail Pressure Sensor Circuit Intermittent
P0195 Engine Oil Temperature Sensor Malfunction
P0196 Engine Oil Temperature Sensor Range/Performance
P0197 Engine Oil Temperature Sensor Low
P0198 Engine Oil Temperature Sensor High
P0199 Engine Oil Temperature Sensor Intermittent
P0200 Injector Circuit Malfunction
P0201 Injector Circuit Malfunction - Cylinder 1
P0202 Injector Circuit Malfunction - Cylinder 2
P0203 Injector Circuit Malfunction - Cylinder 3
P0204 Injector Circuit Malfunction - Cylinder 4
P0205 Injector Circuit Malfunction - Cylinder 5
P0206 Injector Circuit Malfunction - Cylinder 6
P0207 Injector Circuit Malfunction - Cylinder 7
P0208 Injector Circuit Malfunction - Cylinder 8
P0209 Injector Circuit Malfunction - Cylinder 9
P0210 Injector Circuit Malfunction - Cylinder 10
P0211 Injector Circuit Malfunction - Cylinder 11
P0212 Injector Circuit Malfunction - Cylinder 12
P0213 Cold Start Injector 1 Malfunction
P0214 Cold Start Injector 2 Malfunction
P0215 Engine Shutoff Solenoid Malfunction
P0216 Injection Timing Control Circuit Malfunction
P0217 Engine Overtemp Condition
P0218 Transmission Over Temperature Condition
P0219 Engine Overspeed Condition
P0220 Throttle/Petal Position Sensor/Switch B Circuit Malfunction
P0221 Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem
P0222 Throttle/Petal Position Sensor/Switch B Circuit Low Input
P0223 Throttle/Petal Position Sensor/Switch B Circuit High Input
P0224 Throttle/Petal Position Sensor/Switch B Circuit Intermittent
P0225 Throttle/Petal Position Sensor/Switch C Circuit Malfunction
P0226 Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem
P0227 Throttle/Petal Position Sensor/Switch C Circuit Low Input
P0228 Throttle/Petal Position Sensor/Switch C Circuit High Input
P0229 Throttle/Petal Position Sensor/Switch C Circuit Intermittent
P0230 Fuel Pump Primary Circuit Malfunction
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit Intermittent
P0234 Engine Overboost Condition
P0235 Turbocharger Boost Sensor A Circuit Malfunction
P0236 Turbocharger Boost Sensor A Circuit Range/Performance
P0237 Turbocharger Boost Sensor A Circuit Low
P0238 Turbocharger Boost Sensor A Circuit High
P0239 Turbocharger Boost Sensor B Malfunction
P0240 Turbocharger Boost Sensor B Circuit Range/Performance
P0241 Turbocharger Boost Sensor B Circuit Low
P0242 Turbocharger Boost Sensor B Circuit High
P0243 Turbocharger Wastegate Solenoid A Malfunction
P0244 Turbocharger Wastegate Solenoid A Range/Performance
P0245 Turbocharger Wastegate Solenoid A Low
P0246 Turbocharger Wastegate Solenoid A High
P0247 Turbocharger Wastegate Solenoid B Malfunction
P0248 Turbocharger Wastegate Solenoid B Range/Performance
P0249 Turbocharger Wastegate Solenoid B Low
P0250 Turbocharger Wastegate Solenoid B High
P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
P0257 Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
P0258 Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
P0259 Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
P0260 Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
P0261 Cylinder 1 Injector Circuit Low
P0262 Cylinder 1 Injector Circuit High
P0263 Cylinder 1 Contribution/Balance Fault
P0264 Cylinder 2 Injector Circuit Low
P0265 Cylinder 2 Injector Circuit High
P0266 Cylinder 2 Contribution/Balance Fault
P0267 Cylinder 3 Injector Circuit Low
P0268 Cylinder 3 Injector Circuit High
P0269 Cylinder 3 Contribution/Balance Fault
P0270 Cylinder 4 Injector Circuit Low
P0271 Cylinder 4 Injector Circuit High
P0272 Cylinder 4 Contribution/Balance Fault
P0273 Cylinder 5 Injector Circuit Low
P0274 Cylinder 5 Injector Circuit High
P0275 Cylinder 5 Contribution/Balance Fault
P0276 Cylinder 6 Injector Circuit Low
P0277 Cylinder 6 Injector Circuit High
P0278 Cylinder 6 Contribution/Balance Fault
P0279 Cylinder 7 Injector Circuit Low
P0280 Cylinder 7 Injector Circuit High
P0281 Cylinder 7 Contribution/Balance Fault
P0282 Cylinder 8 Injector Circuit Low
P0283 Cylinder 8 Injector Circuit High
P0284 Cylinder 8 Contribution/Balance Fault
P0285 Cylinder 9 Injector Circuit Low
P0286 Cylinder 9 Injector Circuit High
P0287 Cylinder 9 Contribution/Balance Fault
P0288 Cylinder 10 Injector Circuit Low
P0289 Cylinder 10 Injector Circuit High
P0290 Cylinder 10 Contribution/Balance Fault
P0291 Cylinder 11 Injector Circuit Low
P0292 Cylinder 11 Injector Circuit High
P0293 Cylinder 11 Contribution/Balance Fault
P0294 Cylinder 12 Injector Circuit Low
P0295 Cylinder 12 Injector Circuit High
P0296 Cylinder 12 Contribution/Range Fault
P0297 Vehicle Overspeed Condtion
P0298 Engine Oil Overtemperature Condition
P0299 Turbo/Super Charger Underboost
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
P0307 Cylinder 7 Misfire Detected
P0308 Cylinder 8 Misfire Detected
P0309 Cylinder 9 Misfire Detected
P0310 Cylinder 10 Misfire Detected
P0311 Cylinder 11 Misfire Detected
P0312 Cylinder 12 Misfire Detected
P0313 Misfire Detected with Low Fuel
P0314 Single Cylinder misfire (Cylinder not Specified)
P0315 Crankshaft Position System Variation Not Learned
P0316 Engine Misfire Detected on Startup (First 1000 Revolutions)
P0317 Rough Road Hardware Not Present
P0318 Rough Road Sensor A Signal Circuit
P0319 Rough Road Sensor B
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
P0324 Knock Control System Error
P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
P0333 Knock Sensor 2 Circuit High Input (Bank 2)
P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
P0335 Crankshaft Position Sensor A Circuit Malfunction
P0336 Crankshaft Position Sensor A Circuit Range/Performance
P0337 Crankshaft Position Sensor A Circuit Low Input
P0338 Crankshaft Position Sensor A Circuit High Input
P0339 Crankshaft Position Sensor A Circuit Intermittent
P0340 Camshaft Position Sensor Circuit Malfunction
P0341 Camshaft Position Sensor Circuit Range/Performance
P0342 Camshaft Position Sensor Circuit Low Input
P0343 Camshaft Position Sensor Circuit High Input
P0344 Camshaft Position Sensor Circuit Intermittent
P0345 Camshaft Position Sensor "A" Circuit Intermittent Bank 2
P0346 Camshaft Position Sensor "A" Circuit Range/Performance Bank 2
P0347 Camshaft Position Sensor "A" Circuit Low Bank 2
P0348 Camshaft Position Sensor "A" Circuit High Bank 2
P0349 Camshaft Position Sensor "A" Circuit Intermittent Bank 2
P0350 Ignition Coil Primary/Secondary Circuit Malfunction
P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
P0363 Misfire Detected - Fuel Disabled
P0364 -=- Not listed.
P0365 Camshaft Position Sensor "B" Circuit Bank 1
P0366 Camshaft Position Sensor "B" Circuit Range/Performance Bank 1
P0367 Camshaft Position Sensor "B" Circuit Low Bank 1
P0368 Camshaft Position Sensor "B" Circuit High Bank 1
P0369 Camshaft Position Sensor "B" Circuit Intermittent
P0370 Timing Reference High Resolution Signal A Malfunction
P0371 Timing Reference High Resolution Signal A Too Many Pulses
P0372 Timing Reference High Resolution Signal A Too Few Pulses
P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
P0374 Timing Reference High Resolution Signal A No Pulses
P0375 Timing Reference High Resolution Signal B Malfunction
P0376 Timing Reference High Resolution Signal B Too Many Pulses
P0377 Timing Reference High Resolution Signal B Too Few Pulses
P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
P0379 Timing Reference High Resolution Signal B No Pulses
P0380 Glow Plug/Heater Circuit "A" Malfunction
P0381 Glow Plug/Heater Indicator Circuit Malfunction
P0382 Exhaust Gas Recirculation Flow Malfunction
P0383 -=- Not listed.
P0384 -=- Not listed.
P0385 Crankshaft Position Sensor B Circuit Malfunction
P0386 Crankshaft Position Sensor B Circuit Range/Performance
P0387 Crankshaft Position Sensor B Circuit Low Input
P0388 Crankshaft Position Sensor B Circuit High Input
P0389 Crankshaft Position Sensor B Circuit Intermittent
P0390 -=- Not listed.
P0391 -=- Not listed.
P0392 -=- Not listed.
P0393 -=- Not listed.
P0394 -=- Not listed.
P0395 -=- Not listed.
P0396 -=- Not listed.
P0397 -=- Not listed.
P0398 -=- Not listed.
P0399 -=- Not listed.
P0400 Exhaust Gas Recirculation Flow Malfunction
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Circuit Malfunction
P0404 Exhaust Gas Recirculation Circuit Range/Performance
P0405 Exhaust Gas Recirculation Sensor A Circuit Low
P0406 Exhaust Gas Recirculation Sensor A Circuit High
P0407 Exhaust Gas Recirculation Sensor B Circuit Low
P0408 Exhaust Gas Recirculation Sensor B Circuit High
P0410 Secondary Air Injection System Malfunction
P0411 Secondary Air Injection System Incorrect Flow Detected
P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
P0413 Secondary Air Injection System Switching Valve A Circuit Open
P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
P0416 Secondary Air Injection System Switching Valve B Circuit Open
P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
P0418 Secondary Air Injection System Relay "A" Circuit Malfunction
P0419 Secondary Air Injection System Relay "B" Circuit Malfunction
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
P0425 Catalyst Temperature Sensor Bank 1
P0426 Catalyst Temperature Sensor Range/Performance (Bank1)
P0427 Catalyst Temperature Sensor Low Input (Bank 1)
P0428 Catalyst Temperature Sensor High Input (Bank 1)
P0429 Catalyst Heater Control Circuit Bank 1
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
P0435 Catalyst Temperature Sensor Bank 2
P0436 Catalyst Temperature Sensor Range/Performance (Bank2)
P0437 Catalyst Temperature Sensor Low Input (Bank 2)
P0438 Catalyst Temperature Sensor High Input (Bank 2)
P0439 Catalyst Heater Control Circuit Bank 2
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected (small leak)
P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
P0447 Evaporative Emission Control System Vent Control Circuit Open
P0448 Evaporative Emission Control System Vent Control Circuit Shorted
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0450 Evaporative Emission Control System Pressure Sensor Malfunction
P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
P0452 Evaporative Emission Control System Pressure Sensor Low Input
P0453 Evaporative Emission Control System Pressure Sensor High Input
P0454 Evaporative Emission Control System Pressure Sensor Intermittent
P0455 Evaporative Emission Control System Leak Detected (gross leak)
P0456 Evaporative Emission Control System Leak Detected (very small leak)
P0457 Evaporative Emission Leak Detected (fuel cap loose/off)
P0458 Evaporative Emission System Purge Control Valve Circuit Low
P0459 Evaporative Emission System Purge Control Valve Circuit High
P0460 Fuel Level Sensor Circuit Malfunction
P0461 Fuel Level Sensor Circuit Range/Performance
P0462 Fuel Level Sensor Circuit Low Input
P0463 Fuel Level Sensor Circuit High Input
P0464 Fuel Level Sensor Circuit Intermittent
P0465 Purge Flow Sensor Circuit Malfunction
P0466 Purge Flow Sensor Circuit Range/Performance
P0467 Purge Flow Sensor Circuit Low Input
P0468 Purge Flow Sensor Circuit High Input
P0469 Purge Flow Sensor Circuit Intermittent
P0470 Exhaust Pressure Sensor Malfunction
P0471 Exhaust Pressure Sensor Range/Performance
P0472 Exhaust Pressure Sensor Low
P0473 Exhaust Pressure Sensor High
P0474 Exhaust Pressure Sensor Intermittent
P0475 Exhaust Pressure Control Valve Malfunction
P0476 Exhaust Pressure Control Valve Range/Performance
P0477 Exhaust Pressure Control Valve Low
P0478 Exhaust Pressure Control Valve High
P0479 Exhaust Pressure Control Valve Intermittent
P0480 Cooling Fan 1 Control Circuit Malfunction
P0481 Cooling Fan 2 Control Circuit Malfunction
P0482 Cooling Fan 3 Control Circuit Malfunction
P0483 Cooling Fan Rationality Check Malfunction
P0484 Cooling Fan Circuit Over Current
P0485 Cooling Fan Power/Ground Circuit Malfunction
P0486 Exhaust Gas Recirculation Sensor "B" Circuit
P0487 Exhaust Gas Recirculation Throttle Position Control Circuit
P0488 Exhaust Gas Recirculation Throttle Position Control Range/Performnace
P0489 Exhaust Gas Recirculation Control Circuit Low
P0490 Exhaust Gas Recirculation Control Circuit High
P0491 Secondary Air Injection System Insuficient Flow Bank 1
P0492 Secondary Air Injection System Insufficient Flow Bank 2
P0493 Fan Overspeed
P0494 Fan Speed Low
P0495 Fan Speed High
P0496 Evaporative Emision System High Purge Flow
P0497 Evaporative Emission System Low Purge Flow
P0498 Evaporative Emission System Vent Valve Control Circuit Low
P0499 Evaporative Emission System Vent Valve Control Circuit High
P0500 Vehicle Speed Sensor Malfunction
P0501 Vehicle Speed Sensor Range/Performance
P0502 Vehicle Speed Sensor Low Input
P0503 Vehicle Speed Sensor Intermittent/Erratic/High
P0504 Brake Switch "A"/"B" Correlation
P0505 Idle Control System Malfunction
P0506 Idle Control System RPM Lower Than Expected
P0507 Idle Control System RPM Higher Than Expected
P0508 Idle Control System Circuit Low
P0509 Idle Control System Circuit High
P0510 Closed Throttle Position Switch Malfunction
P0511 Idle Air Control Circuit
P0512 Starter Request Circuit Performance
P0513 Incorrect Immobilizer Key
P0514 Battery Temperature Sensor Circuit Range/Performance
P0515 Battery Temperature Sensor Circuit
P0516 Battery Temperature Sensor Circuit Low
P0517 Battery Temperature Sensor Circuit High
P0518 Idle Air Control Circuit Intermittent
P0519 Idle Air Control System Performance
P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
P0524 Engine Oil Pressure Too Low
P0525 Cruise Control Servo Control Circuit Range/Performance
P0526 Fan Speed Sensor Circuit
P0527 Fan Speed Sensor Circuit Range/Performance
P0528 Fan Speed Sensor Circuit No Signal
P0529 Fan Speed Sensor Circuit Intermittent
P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor Circuit High Input
P0534 Air Conditioner Refrigerant Charge Loss
P0535 A/C Evaporator Temperature Sensor Circuit
P0536 A/C Evaporator Temperature Sensor Circuit Range/Perfomance
P0537 A/C Evaporator Temperature Sensor Circuit Low
P0538 A/C Evaporator Temperature Sensor Circuit High
P0539 -=- Not listed.
P0540 Intake Air Heater "A" Circuit
P0541 Intake Air Heater Circuit Low
P0542 Intake Air Heater Circuit High
P0543 Intake Air Heater "A" Circuit Open
P0544 Exhaust Gas Temperature Sensor Circuit Bank Sensor 1
P0545 Exhaust Gas Temperature Sensor Circuit Low Bank 1 Sensor 1
P0546 Exhaust Gas Temperature Sensor Circuit High Bank 1 Sensor 1
P0547 Exhaust Gas Temperature Sensor Circuit Bank 2 Sensor 1
P0548 Exhaust gas Temperature Sensor Circuit Low Bank 2 Sensor 1
P0549 Exhaust Gas Temperature Sensor Circuit High Bank 2 Sensor 1
P0550 Power Steering Pressure Sensor Circuit Malfunction
P0551 Power Steering Pressure Sensor Circuit Range/Performance
P0552 Power Steering Pressure Sensor Circuit Low Input
P0553 Power Steering Pressure Sensor Circuit High Input
P0554 Power Steering Pressure Sensor Circuit Intermittent
P0555 Brake Booster Pressure Sensor Circuit
P0556 Brake Booster Pressure Sensor Circuit Range/Performance
P0557 Brake Booster Pressure Sensor Circuit Low Input
P0558 Brake Booster Pressure Sensor Circuit High Input
P0559 -=- Not listed.
P0560 System Voltage Malfunction
P0561 System Voltage Unstable
P0562 System Voltage Low
P0563 System Voltage High
P0564 Cruise Control Multi-Function Input "A" Circuit
P0565 Cruise Control On Signal Malfunction
P0566 Cruise Control Off Signal Malfunction
P0567 Cruise Control Resume Signal Malfunction
P0568 Cruise Control Set Signal Malfunction
P0569 Cruise Control Coast Signal Malfunction
P0570 Cruise Control Accel Signal Malfunction
P0571 Cruise Control/Brake Switch A Circuit Malfunction
P0572 Cruise Control/Brake Switch A Circuit Low
P0573 Cruise Control/Brake Switch A Circuit High
P0574 Cruise Control System - Vehicle Speed Too High
P0575 Cruise Control Input Circuit
P0576 Cruise Control Input Circuit Low
P0577 Cruise Control Input Circuit High
P0578 Cruise Control Multi-Function Input "A" Circuit Stuck
P0579 Cruise Control Multi-Function Input "A" Circuit Range/Performance
P0580 Cruise Control Multi-Function "A" Circuit Low
P0581 Cruise Control Multi-Function Input "A" Circuit High
P0582 Cruise Control Vacuum Control Circuit/Open
P0583 Cruise Control Vacuum Control Circuit Low
P0584 Cruise Control Vacuum Control Circuit High
P0585 Cruise Control Multi-Function Input "A"/"B" Correlation
P0586 Cruise Control Vent Control Circuit/Open
P0587 Cruise Control Vent Control Circuit Low
P0588 Cruise Control Vent Control Circuit High
P0589 Cruise Control Multi-Function Input "B" Circuit
P0590 Cruise Control Multi-Function Input "B" Circuit Stuck
P0591 Cruse Control Multi-Function Input "B" Circuit Range/Performance
P0592 Cruise Control Multi-Function Input "B" Circuit Low
P0593 Cruise Control Multi-Function Input "B" Circuit High
P0594 Cruise Control Servo Control Circuit/Open
P0595 Cruise Control Servo Circuit Low
P0596 Cruise Control Servo Circuit High
P0597 Thermostat Heater Control Circuit/Open
P0598 Thermostat Heater Control Circuit Low
P0599 Thermostat Heater Control Circuit High
P0600 Serial Communication Link Malfunction
P0601 Internal Control Module Memory Check Sum Error
P0602 Control Module Programming Error
P0603 Internal Control Module Keep Alive Memory (KAM) Error
P0604 Internal Control Module Random Access Memory (RAM) Error
P0605 Internal Control Module Read Only Memory (ROM) Error
P0606 PCM Processor Fault
P0608 Control Module VSS Output "A" Malfunction
P0609 Control Module VSS Output "B" Malfunction
P0610 Control Module Vehicle Options Error
P0611 Fuel Injector Control Module Performance
P0612 Fuel Injector Control Module Relay
P0613 TCM Processor
P0614 ECM/TCM Incompatible
P0615 Starter Relay Circuit / Control Circuit
P0616 Starter Relay Circuit Low
P0617 Starter Relay Circuit High
P0618 Alternative Fuel Control Module KAM Error
P0619 Alternative Fuel Control Module KAM/ROM Error
P0620 Generator Control Circuit Malfunction
P0621 Generator Lamp "L" Control Circuit Malfunction
P0622 Generator Field "F" Control Circuit Malfunction
P0623 Generator Lamp Control Circuit
P0624 Fuel Cap Lamp Control Circuit
P0625 Generator Field/F Terminal Circuit Low
P0626 Generator Field/F Terminal Circuit High
P0627 Fuel Pump "A" Control Circuit Open
P0628 Fuel Pump "A" Control Circuit Low
P0629 Fuel Pump "A" Control Circuit High
P0630 VIN Not Programmed or Incompatible - ECM/PCM
P0631 VIN Not Programmed or Incompatible -TCM
P0632 Odometer Not Programmed - ECM/PCM
P0633 Security Key Not Programmed - ECM/TCM (SKIM KEY for dodge)
P0634 PCM/ECM/TCM Internal Temperature Too High
P0635 Power Steering Control Circuit
P0636 Power Steering Control Circuit Low
P0637 Power Steering Control Circuit High
P0638 Throttle Actuator Control Range/Performance Bank 1
P0639 Throttle Actualtor Control Range/Performance Bank 2
P0640 Intake Air Heater Control Circuit
P0641 -=- Not listed.
P0642 -=- Not listed.
P0643 -=- Not listed.
P0644 -=- Not listed.
P0645 A/C Clutch Relay Control Circuit
P0646 A/C Clutch Relay Circuit Low Voltage
P0647 A/C Clutch Relay Circuit High Voltage
P0648 Immobilizer Lamp Control Circuit
P0649 Speed Control Lamp Control Circuit
P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
P0651 Sensor Reference Voltage "B" Circuit/Open
P0652 Sensor Reference Voltage "B" Low
P0653 Sensor Reference Voltage "B" High
P0654 Engine RPM Output Circuit Malfunction
P0655 Engine Hot Lamp Output Control Circuit Malfucntion
P0656 Fuel Level Output Circuit Malfunction
P0657 -=- Not listed.
P0658 Actuator Supply Voltage "A" Circuit Low
P0659 Actuator Supply Voltage "A" Circuit High
P0660 Intake Manifold Tuning Valve Control Circuit - Bank 1
P0661 Intake Manifold Tuning Valve Control Circuit Low - Bank 1
P0662 Intake Manifold Tuning Valve Control Circuit High - Bank 1
P0663 Intake Manifold Tuning Valve Control Circuit Open
P0664 Intake Manifold Tuning Valve Control Circuit Low
P0665 Intake Manifold Tuning Valve Control Circuit High
P0666 PCM ERROR <-----------------I find this one slightly funny given the number reference
P0667 PCM/ECM/TCM internal Temperature Sensor Range/Performance
P0668 PCM/ECM/TCM internal Temperature Sensor Circuit Low
P0669 PCM/ECM/TCM internal Temperature Sensor Circuit High
P0670 Glow Plug Module Control Circuit
P0671 Cylinder 1 Glow Plug Circuit
P0672 Cylinder 2 Glow Plug Circuit
P0673 Cylinder 3 Glow Plug Circuit
P0674 Cylinder 4 Glow Plug Circuit
P0675 Cylinder 5 Glow Plug Circuit
P0676 Cylinder 6 Glow Plug Circuit
P0677 Cylinder 7 Glow Plug Circuit
P0678 Cylinder 8 Glow Plug Circuit
P0679 Cylinder 8 Glow Plug Circuit
P0680 Cylinder 10 Glow Plug Circuit
P0681 Cylinder 11 Glow Plug Circuit
P0682 Cylinder 12 Glow Plug Circuit
P0683 Glow Plug Control Module to PCM Communication Circuit
P0684 Glow Plug Control Module to PCM Communication Circuit Range/Performance
P0685 ECM/PCM Power Relay Control Circuit Open
P0686 ECM/PCM Power Relay Control Circuit Low
P0687 ECM/PCM Power Relay Control Circuit High
P0688 ECM/PCM Power Relay Sense Circuit Open
P0689 ECM/PCM Power Relay Sense Circuit Low
P0690 ECM/PCM Power Relay Sense Circuit High
P0691 Fan 1 Control Circuit Low
P0692 Fan 1 Control Circuit High
P0693 Fan 2 Control Circuit Low
P0694 Fan 2 Control Circuit High
P0695 Fan 3 Control Circuit Low
P0696 Fan 3 Control Circuit High
P0697 Sensor Reference Voltage "C" Circuit Open
P0698 Sensor Reference Voltage "C" Circuit Low
P0699 Sensor Reference Voltage "C" Circuit High
TRANSMISSION Specific Codes
P0700 Transmission Control System Malfunction
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System Electrical
P0703 Torque Converter/Brake Switch B Circuit Malfunction
P0704 Clutch Switch Input Circuit Malfunction
P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
P0706 Transmission Range Sensor Circuit Range/Performance
P0707 Transmission Range Sensor Circuit Low Input
P0708 Transmission Range Sensor Circuit High Input
P0709 Transmission Range Sensor Circuit Intermittent
P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low Input
P0713 Transmission Fluid Temperature Sensor Circuit High Input
P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
P0715 Input/Turbine Speed Sensor Circuit Malfunction
P0716 Input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/Brake Switch B Circuit Low
P0720 Output Speed Sensor Circuit Malfunction
P0721 Output Speed Sensor Range/Performance
P0722 Output Speed Sensor No Signal
P0723 Output Speed Sensor Intermittent
P0724 Torque Converter/Brake Switch B Circuit High
P0725 Engine Speed input Circuit Malfunction
P0726 Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Input Circuit No Signal
P0728 Engine Speed Input Circuit Intermittent
P0730 Incorrect Gear Ratio
P0731 Gear 1 Incorrect ratio
P0732 Gear 2 Incorrect ratio
P0733 Gear 3 Incorrect ratio
P0734 Gear 4 Incorrect ratio
P0735 Gear 5 Incorrect ratio
P0736 Reverse incorrect gear ratio
P0737
P0738
P0739
P0740 Torque Converter Clutch Circuit Malfuction
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P0742 Torque Converter Clutch Circuit Stuck On
P0743 Torque Converter Clutch Circuit Electrical
P0744 Torque Converter Clutch Circuit Intermittent
P0745 Pressure Control Solenoid Malfunction
P0746 Pressure Control Solenoid Performance or Stuck Off
P0747 Pressure Control Solenoid Stuck On
P0748 Pressure Control Solenoid Electrical
P0749 Pressure Control Solenoid Intermittent
P0750 Shift Solenoid A Malfunction
P0751 Shift Solenoid A Performance or Stuck Off
P0752 Shift Solenoid A Stuck On
P0753 Shift Solenoid A Electrical
P0754 Shift Solenoid A Intermittent
P0755 Shift Solenoid B Malfunction
P0756 Shift Solenoid B Performance or Stuck Off
P0757 Shift Solenoid B Stuck On
P0758 Shift Solenoid B Electrical
P0759 Shift Solenoid B Intermittent
P0760 Shift Solenoid C Malfunction
P0761 Shift Solenoid C Performance or Stuck Off
P0762 Shift Solenoid C Stuck On
P0763 Shift Solenoid C Electrical
P0764 Shift Solenoid C Intermittent
P0765 Shift Solenoid D Malfunction
P0766 Shift Solenoid D Performance or Stuck Off
P0767 Shift Solenoid D Stuck On
P0768 Shift Solenoid D Electrical
P0769 Shift Solenoid D Intermittent
P0770 Shift Solenoid E Malfunction
P0771 Shift Solenoid E Performance or Stuck Off
P0772 Shift Solenoid E Stuck On
P0773 Shift Solenoid E Electrical
P0774 Shift Solenoid E Intermittent
P0775
P0776
P0777
P0778
P0779
P0780 Shift Malfunction
P0781 1-2 Shift Malfunction
P0782 2-3 Shift Malfunction
P0783 3-4 Shift Malfunction
P0784 4-5 Shift Malfunction
P0785 Shift/Timing Solenoid Malfunction
P0786 Shift/Timing Solenoid Range/Performance
P0787 Shift/Timing Solenoid Low
P0788 Shift/Timing Solenoid High
P0789 Shift/Timing Solenoid Intermittent
P0790 Normal/Performance Switch Circuit Malfunction
P0791
P0792
P0793
P0794
P0795
P0796
P0797
P0798
P0799
P0801 Reverse Inhibit Control Circuit Malfunction
P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
P0833 CLUTCH RELEASED SWITCH CIRCUIT
P0850 PARK/NEUTRAL SWITCH PERFORMANCE
MISC Specific Codes
P1105 TIP SENSOR SOLENOID CIRCUIT
P1115 GENERAL TEMP SENSOR PERFORMANCE
P1189 TIP SENSOR CIRCUIT LOW
P1190 TIP SENSOR CIRCUIT HIGH
P1593 SPEED CONTROL SWITCH STUCK
P1602 PCM NOT PROGRAMMED
P1603 PCM INTERNAL DUAL-PORT RAM COMMUNICATION
P1604 PCM INTERNAL DUAL-PORT RAM READ/WRITE INTEGRITY FAILURE
P1607 PCM INTERNAL SHUTDOWN TIMER RATIONALITY
P1696 EEPROM MEMORY WRITE DENIED/INVALID
P1697 EMR (SRI) MILEAGE NOT STORED
P1854 TIP BARO OUT OF RANGE
P2074 MANIFOLD PRESSURE/THROTTLE POSITION CORRELATION - HIGH
FLOW/VACUUM LEAK
P2096 DOWN STREAM FUEL SYSTEM 1/2 LEAN
P2097 DOWN STREAM FUEL SYSTEM 1/2 RICH
P2302 IGNITION COIL #1 SECONDARY CIRCUIT-INSUFFICIENT IONIZATION
P2305 IGNITION COIL #2 SECONDARY CIRCUIT-INSUFFICIENT IONIZATION
P2503 CHARGING SYSTEM VOLTAGE LOW
U0101 NO TRANSMISSION BUS MESSAGE
U0155 NO CLUSTER BUS MESSAGE
U0168 NO SKIM BUS MESSAGES
U110C NO FUEL LEVEL BUS MESSAGE
Old 07-29-2005, 07:35 AM   #12 (permalink)
iball's Avatar
Member Number: 8613
Excellent! Into the FAQ it went...
That's right. I hit him so hard he fell off the internet.
Quote: Originally Posted by noTe
Yo man. I put some 36 inch wheels on mine a month ago for the new 50 cent video. It was fsckin' baller.
iball is offline   Reply With Quote
Old 07-31-2005, 02:52 AM   #13 (permalink)
White Heat's Avatar
Member Number: 512
Trader Rating: (10)
Great info. I wondered what that rattling noise at low rpm's in 1st and 2nd gears was. Was so concerned I went back to the dealer a couple of days later and took another '05 for a test drive. That one made the same noise so I figured it was normal though I still didn't feel comfortable with it. Now I know it is normal.
'05 Stone White SRT 4
Mods - Yes
Web Page
http://qt.ptenthusiasts.net/
White Heat is offline   Reply With Quote
Old 08-03-2005, 10:16 AM   #14 (permalink)
hercfe's Avatar
Member Number: 19255
WOT below 3200-3500rpms causes compressor surge (loud flutter noise), which is bad. I'd like to ad this because I personally have told 5-10 newbs about this, and I'm tired of writing about it.
hercfe is offline   Reply With Quote
Old 08-03-2005, 10:22 AM   #15 (permalink)
Bacardi 151's Avatar
Member Number: 14061
Trader Rating: (34)
I think to add to mainly 7, but maybe also 12 that our boost gauges suck and the psi it displays may not be the actually psi...
Former 295hp/344tq owner
Bacardi 151 is offline   Reply With Quote
Page generated in 0.56792 seconds with 13 queries
