Old 03-24-2008, 10:27 AM   #1 (permalink)
Member Number: 7941
Default Need 400HP Advice
I will be going 50 trim this summer and was wondering what mods I should do to ensure safety and give preperation for that kind of power to the engine. Besides the obvious. I have a w/b and scan gauge in the car. I also have a Walbro, and stage 2 injectors. Alot say the DCR oil mod is a smart choice. Any ideas?? I am looking for 350 for my pump gas set-up, and 400 with meth occasionally at the track. Also, is our stock internals strong enough to last a while with power like that. Keep in mind I will be running everything safe. Thanks.
AGP 50-trim, Stg 2 W/O, DW Stg 2's, SSA Front Mount, SSA turboback, JMB hard pipes and ultimate CAI, Raptor BOV, PTP 55 T/B, PTP clamp, PTP FPR mod, Walbro 255, Greddy Profec S, DCR Oil Kit, DCR Modifier, MSD 8.5's, NGK Iridiums, AEM Uego, Scan Gauge
jusyjus is offline   Reply With Quote
Old 03-24-2008, 10:31 AM   #2 (permalink)
lilmike0450's Avatar
Member Number: 56278
Internals should be good. DCR oil kit is always a good idea when going for big hp but I still havent gotten it. U already have a wideband so your good there. Are you going with PCM controlled everything???
05 White ACR
lilmike0450 is offline   Reply With Quote
Old 03-24-2008, 10:42 AM   #3 (permalink)
Member Number: 7941
not sure. which is the best route to go with a big turbo as far as stages go? I currently have the stage 2 PCM. also, at what PSI does stg 2 start pulling timing down?
Old 03-24-2008, 10:44 AM   #4 (permalink)
Member Number: 7941
is PCM controlled boost the way to go with the 50?
Old 03-24-2008, 10:46 AM   #5 (permalink)
no....thats why I asked. Should get an ebc.
Old 03-24-2008, 10:50 AM   #6 (permalink)
Member Number: 7941
forgot that in my sig. I have a Greddy EBC for the set-up
Old 03-24-2008, 10:54 AM   #7 (permalink)
ok......
Old 03-24-2008, 11:51 AM   #8 (permalink)
S2R0T044's Avatar
Member Number: 5620
My suggestion would be to do a search for all the other 50 trim builds. There are tons and after reading through, taking a look at their setups and so forth, you should have a good idea of what you'll need.
Josh - 2005 Black SRT-4
Drastic.
blazinsrt built.
S2R0T044 is online now   Reply With Quote
Old 03-24-2008, 01:17 PM   #9 (permalink)
Slow_spool's Avatar
Member Number: 50382
Personally i wouldnt worry about the DCR oil kit until 450hp, but to each their own and it is your motor, so its always better safe then sorry.
also deffinately atleast cut the balance shaft chain.
you can deffinately make more then 400hp even with a .48AR if you wanted to.
but as for mod suggestions:
return line
RC 750CC injectors
i like the greddy profec spec b boost controller
something to tune with, d-tec, s-afc2, SCT, EMS
3" exhaust
DCR oil modifier
hard pipes with BOV
A good clutch, SBC
3" intake of course
a ported intake mani, throttle body and spacer will be a good idea
that will be more then enough
Slow_spool is offline   Reply With Quote
Old 03-24-2008, 01:23 PM   #10 (permalink)
NoisufnoC's Avatar
Member Number: 136
lol...no.
the AGP SCT flash has worked well for me and others.
Old 03-24-2008, 01:29 PM   #11 (permalink)
miSRT4blk's Avatar
Member Number: 46920
I would def looking into getting the sct flash!
miSRT4blk is offline   Reply With Quote
Old 03-24-2008, 04:36 PM   #12 (permalink)
Member Number: 7941
already have a stage 3 south bend clutch going in this week. can I use the Stage 2 injectors or no? they are not mopar. they are 682's from deatchwerks? also how much does an sct flash cost?
Old 03-24-2008, 04:44 PM   #13 (permalink)
NoisufnoC's Avatar
Member Number: 136
if you were going to go with the flash i'd suggest getting some 750's just because theres more canned flashes out there for that size injector
AGP SCT Flash is $700 w/ the MAP and TIP sensors
Old 03-25-2008, 01:33 PM   #14 (permalink)
Member Number: 7941
i just don't understand why an upgraded oil pump wasn't included in the stage 3 kit if it was neccesary for over 300HP. the stg 3 in HOM makes 355hp. that is well above stock levels. the SRT engineers are not clueless when it came to making this car. so why would they miss something as important as lubrication from the oil pump?? the car has been around since 2003, and i'm sure they tested the hell out of the stage three b4 selling it to the public.
Old 03-25-2008, 01:44 PM   #15 (permalink)
Mr.srt-4's Avatar
Member Number: 52154
U can use stock pcm and use a piggy back system. Thats what I am doing. And I dont think u need to upgrade a new oil pump. Check out the AGP stage 4 kit. It has everything, but u can also just build it urself.
I wana Go fast......
ZIP TIES FTW!!!
Mr.srt-4 is offline   Reply With Quote
Page generated in 0.27909 seconds with 11 queries
