Old 10-25-2008, 12:57 PM   #1 (permalink)
Member Number: 33649
Trader Rating: (13)
Default is my new used stock boost guage broken??
ok I lpicked up a used stock boost guage. It sits VERY VERY close to vacuum when the car is off. If not sometimes it's in vacuum.
It also says I spike 11-13. And in 2nd at redline it's only around 7psi at top rpm. Is that normal for my stock 03??
grannycar is offline   Reply With Quote
Old 10-25-2008, 01:01 PM   #2 (permalink)
depwater12's Avatar
Member Number: 59402
Those stock boost gauges are crap. Buy a aftermarket one. Mines said the turbo was boosting 15psi and it would sit at 10vac with the engine off, when i installed a better one ( Blox racing) gauge it then read 18psi and read properly at 0 with the engine off
depwater12 is offline   Reply With Quote
Old 10-26-2008, 09:51 AM   #3 (permalink)
Trader Rating: (13)
were is a good place to get a quality gauge??
And what do stock srt4 Usally hold to redline boost in 2nd gear?
Old 10-26-2008, 11:06 AM   #4 (permalink)
my_little_srt's Avatar
Member Number: 41179
Trader Rating: (24)
If you guage sits anywhere other than zero when the car is off. Then it's broken.................
my_little_srt is offline   Reply With Quote
Old 10-26-2008, 11:09 AM   #5 (permalink)
SRTforums Junior Admin
Pete's Avatar
Member Number: 43767
Trader Rating: (89)
you can get an autometer 30/30 gauge brand new for about 50 dollars at an autozone type place.
ran a 12.11 at 111 on the stock ported turbo 1.68 60ft
NEW SECTION ****SRT OF THE MONTH CLICK ME*****
DRIVE A NISSAN SENTRA NOW SRT IS GONE
Quote: Originally Posted by peteswife View Post
Yes, because Peter takes the interwebs job oh so seriously... oh wait, a job that he doesn't even get paid for!!!
Pete is offline   Reply With Quote
Old 10-26-2008, 11:21 AM   #6 (permalink)
Trader Rating: (13)
It sorta sits at 0 in a way. Some days it sits in the gray 0 area but all the way towards the vacuum side. Should it sit right in the middle of the gray?
Old 10-26-2008, 11:23 AM   #7 (permalink)
A-Town SRT's Avatar
Member Number: 46710
Been through 3 of them: With the car off ...
1st. Needle sat directly in the middle of zero. A few months later it broke and read 10 vac.
2nd. Needle sat at 1 vac ... had it replaced
3rd. Needle sat at 1 vac again ... didn't bother having it replaced.
A-Town SRT is offline   Reply With Quote
Old 11-19-2008, 05:39 PM   #8 (permalink)
Trader Rating: (13)
just put another gauge in. lol. gauge now my gauge bounces in 2nd gear boost like my other 3 did? could this possibly be like a wga duty cycle?? "boost hunt"
like all the dsm'ers experince??
my gauge seems like its on crack! lol
'only does it sometimes though
Old 11-21-2008, 12:03 PM   #9 (permalink)
RSchyns's Avatar
Member Number: 2019
Trader Rating: (29)
Boost leak or wastegate.
RSchyns is offline   Reply With Quote
Old 11-21-2008, 01:18 PM   #10 (permalink)
Trader Rating: (13)
you say waste as in the wastegate itself going bad?? I would probally lean more towards wga do to the fact it doestnt do it all the time.
Old 11-21-2008, 03:20 PM   #11 (permalink)
RSchyns's Avatar
Member Number: 2019
Trader Rating: (29)
My motto - check the easy stuff first.
put a vacuum pump on the wastegate, see if it pulls.
then leak test.
Here is a combo brake bleed kit, and vacuum pump.
Old 11-21-2008, 06:19 PM   #12 (permalink)
Trader Rating: (13)
i already boost leak tested my car numerous times. the only place air is passing by around 20psi is my throttle body. but as soon as you open it, leak goes away. and your t/b is obiviously open when your WOT.
Waste gate opens under boost. like a weak wga should "around 4psi"
my brother keeps telling me its the waste gate duty cycle. common dsm problem...
Old 11-22-2008, 06:54 AM   #13 (permalink)
RSchyns's Avatar
Member Number: 2019
Trader Rating: (29)
Sorry about the post above. I think it is completely wrong. (bad day)
Do not put vacuum on the wastgate actuator. Boost is what will move the linkage.
I cant believe I did not get flamed for that one.
If you have an air compressor with a good regulator, you could put a couple of psi (slowly raise it) on the wga and see if it moves smoothly.
Anyone else out there????
Old 11-22-2008, 02:44 PM   #14 (permalink)
Neonderthal850's Avatar
Member Number: 67867
My stocker works like a champ!
Neonderthal850 is offline   Reply With Quote
Page generated in 0.17135 seconds with 13 queries
