Old 05-25-2007, 12:17 AM   #1 (permalink)
Member Number: 52205
Default Looking for Opinions on potential new product
Well here it is.
Its not for sale nor am I trying to sell them at this time. (need to become vendor and properly test before release)
What do you guys/ gals think so far?
Sean Truax
Truax Motorsports
funky_monkey58 is offline   Reply With Quote
Old 05-25-2007, 12:18 AM   #2 (permalink)
Tex
Tex's Avatar
Member Number: 3622
pwerks already makes somthing similar
-Soren Kierkegaard
Tex is offline   Reply With Quote
Old 05-25-2007, 06:58 AM   #3 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (552)
I have never been comfortable with tieing into the sheet metal for the core support. Move those support beams up into the frame and you will have a winner.
Old 05-25-2007, 08:04 AM   #4 (permalink)
gt5oh's Avatar
Member Number: 40811
interesting
gt5oh is offline   Reply With Quote
Old 05-25-2007, 08:40 AM   #5 (permalink)
Pimpazzberetta's Avatar
Member Number: 29361
Trader Rating: (39)
Is it just me.. or does it look like there are just hardly any points that actually bolt to anything solid?
Mopar Stage 3R w Toys 388.8 WHP 425.5 WTQ
Mopar CAI,Mopar BOV,S3 C/O's,AGP S3 WGA
SBC 5X,TC BFMIC / t bolt clamps, 55 mm TB, Maxxfab 3" o2,3" catless DP,Injen 3" catback, FBM intake mani
NGK 4306 @ .033, Devils Own W/I w controller
UEGO, Greddy TT, Ultra Lite II 30/30,Scan Gauge
DC Sports STB, MM inserts, Boomba trans mount
LCA, strut tension, Booger bushings,CV,18" Konig's,TCS, D/S Rotors
Pimpazzberetta is online now   Reply With Quote
Old 05-25-2007, 09:10 AM   #6 (permalink)
SRT_Maniac's Avatar
Member Number: 17082
Looks cool but whats its purpose. is there only 2 bolts holding this on?
05 FLAME RED SRT-4 ACR!!!
MODS:
Prothane inserts-/-Mopar Rice Plate-/-Mopar Catback-/-NGK plugs gap .040-/-Autometer 30/30-/-Rear Strut Bar-/-Exhaust Depot Beast FMIC-/-SEyelids-/-Needswings V5 DP W/e-cutout!!
SRT_Maniac is offline   Reply With Quote
Old 05-25-2007, 11:01 AM   #7 (permalink)
zx2srt's Avatar
Member Number: 43315
Looks like alot of extra weight....Nice fab work though man,I give you props on that but what exactly is it supposed to do? I don't really get it.
"Line up and race or shut your face"
Stage 2
Port&polished,ceramic coated E1
Port&polish,ceramic coated "mamoth" manifold
Port&polish ITM,TB,Spacer
FULL bolt on
BFMIC
And alot of other stuffs
zx2srt is offline   Reply With Quote
Old 05-25-2007, 12:16 PM   #8 (permalink)
duster360's Avatar
Member Number: 45182
Trader Rating: (10)
Too much useless material:
90% of the members add little or nothing to the strength of the design. Everything foward of the sway bar needs to go. SAME or MORE strength to accomplish the same goals by going in the OPPOSITE direction with 85% less material by reinforcing to the frame which is only INCHES away btw and not several feet away. Extra material = more weight = more money.
Too labor intensive($$/time) to manufacture:
Too much extra time to hand mig-weld joints vs sheet metal and spot welding
Poor Design (if designed by an engineer, he's not a very good one) :
It looks like the assumption was made that the BOLTS that retain the strut bushing deflect more than the bushing itself. I don't this is entirely true, if it were, stories of failed bolts would all too common, personally I never of anyone failing bolts.. but i could be wrong. For the sake of argument lets say the bolt's deflection is the problem. When load is applied , the LCA should create a moment(close to parallel to the ground plane) around the front bushing. The reaction force needed to secure this moment is not consistant with the geometry of the design.
Old 05-25-2007, 12:27 PM   #9 (permalink)
duster360's Avatar
Trader Rating: (10)
I could go on about the lack of merit of the rocker panel reinforcement shown in the pic too, if you want.( the attempt to increase Moment of Inertia is all wrong)
Old 05-25-2007, 12:52 PM   #10 (permalink)
It has a total of six bolt in locations.
Old 05-25-2007, 06:02 PM   #11 (permalink)
gt5oh's Avatar
is it similar to pwerks?
thread here: SEMA show day 4 - New Products - Werks subframe braces!
Old 05-27-2007, 09:38 AM   #12 (permalink)
heres some pics of most everything I have made for the srt4 so far. Please bear in mind more products are going to be prototyped in the near future. The front piece is getting traction bars. Thanks duster360 for saying reinforcement for them is useless. And I'm making either aluminum or chromoly IRS bars to replace the factory stampers. I am going to try to bring as many track proven things onto your cars so please bear through the testing and prototyping with me.
Thanks for looking/commenting.
Sean
TMS
Old 05-27-2007, 10:11 AM   #13 (permalink)
SRToc Member
Member Number: 25892
Figure out a way to tie those 2 side pieces to the front at the 2 bolts at the lower firewall and i think you will see a huge difference, I was looking at that and really that is the only thing that connects the motor/tranny/suspension to the body, I think there is a ton of flex going on there with the factory rubber bushings, probably the leading cause of wheel hop. I think having something to brace that area alone would be some improvement.
www.bwoodyperformance.com
Mods: AGP GT3076R DBB Turbo
madwax is offline   Reply With Quote
Old 05-27-2007, 12:21 PM   #14 (permalink)
I dont think it would make too terribly much of a difference. Heres why. The weakest thing I found on the chassis setup of the srt4s was the section that runs from directly behind the front subframe and the first lateral sub brace. The said piece of factory subframe has holes stamped in all sides of it and lies directly underneath the vehicles occupants. By bracing that alone i think is what
makes the most noticeable difference due to the lack of integrity of the piece at hand. But thats just my $.02
Sean
TMS
Page generated in 0.24266 seconds with 11 queries
