Guys, I am leaking a small amount of oil fairly often. My dad and I looked under the car, and it appears to be coming from the bottom of the IC hose that connects the IC to the Intake manifold.
Is this the reason that catch cans get installed? It's on my list and if it will solve the problem it will need to get moved up on the list
Mods are K&N Intake and Mopar BOV - stock otherwise
Thoughts?
totally normal, every srt4 I've seen does it. It's because the PCV was never designed to run a on boosted application. It allows oil to pushed into the intake tract from the pressure from the turbo.
goodnews is a catch can is about 90% effective at catching all the oil. You still might get alittle oil in the coldside intercooler piping.
Stg3 toys, ported head & intake, NX 4nozzle, progresser, wide ban, egt, fuel pressure, injen, samco, Mpx3", Maxxfab02,Greddy CC, Boomba's, AIS intercooler, STS, billet SS, .020 8-1 JE's, Eagle 4340 H beam rods, UDP, you name it I've done it Mopar Clutch
Thats what i figured, but I was nervous - when the Supra starting doing something similar I started having serious problems with it. I'll just have to get that catch can
Thoughts?
Here is what the SRT Engineers had to say in a Q&A session.
You dont need a catch can.
Quote: Originally Posted by SRTEngineers
Here is a trick, remove the hose, clean the hose and the tube with an appropiate solvent, apply a small amount of RTV on the intercooler, put the intercooler hose back on and apply sufficient torque to the clamp. Good luck. Works at 22 psi at the top of Pikes Peak.
