Old 11-02-2009, 01:00 AM   #1 (permalink)
milkman102299's Avatar
Member Number: 25193
Trader Rating: (15)
Default knock question's
I know most of my prob is the SAFC. I am at 18psi without meth and run 28* of timing. I see 2 degree's of knock on 91 octane where I live. Reading dusters thread this is nothing to worry about. Now on 22psi 91 octane at 11.6-11.9 afr with meth 50/50 mix, the car get up to 8kr at 5500 then I back off. Timing drops below 20* with the kr that high. I through in some c16 and went to the track with the same kr problems. I cant seem to figue out what is causing the knock. The MAP voltage is correct. After a hard pull where I see higher KR, I then notice part throttle KR of 2 in third and 4th gears. Any idea's what my problem is. I am going to re'tq the knock sensor tomorrow and see if this does anything.
P.S. One day an actual tuning solution will happen. My concern is at the track I have only been able to acheive a trap of 119 at best in the 1/4 with is only 4mph more than my best on the stock turbo setup. Something just seems way off for my mods.
Wiseco 8.0-1 pistons over-eagle H beam rods
agp standard 50 trim
Greddy Profec B. SAFC II
PTP charge pipe
PTP 750cc-exhaust depot cold side pipe w/hks ssq
3inch intake-accel coil-stg 2 CPU
side exit
Boomba Fuel Rail/AGP return line
Walbro 255-Dynotune 105 shot.
DCR powershift 2-balance shafts removed
coolingmist meth kit. BC3 cams.
N2MB WOT BOX (BEST MOD SO FAR)
milkman102299 is offline   Reply With Quote
Old 11-02-2009, 05:33 PM   #2 (permalink)
Trader Rating: (15)
noone huh
Old 11-03-2009, 02:12 AM   #3 (permalink)
Trader Rating: (15)
bump bump
Old 11-03-2009, 02:45 AM   #4 (permalink)
Adionik's Avatar
Member Number: 51197
Trader Rating: (25)
What plugs you running? Very weird that the race gas didn't fix the KR. I'd say it's time to start looking at hardware
Quote: Originally Posted by KoldKill View Post
E1 is ethanol fuel (corn based) you need mucho larger injectors and a tune (I think?) to run it...
Old 11-04-2009, 01:26 AM   #5 (permalink)
Trader Rating: (15)
yea I have a feeling its the knock sensor. been on the car through 2 engine rebuilds. And is the original sensor.
Old 11-04-2009, 01:33 AM   #6 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (92)
have you tested your meth kit to see if its coming on
AGP S256 FS
Old 11-04-2009, 06:14 PM   #7 (permalink)
Trader Rating: (15)
Meth kit turns on with no problem. The Knock sensor was only tq'd to 120 inch pounds. thats abot 76 short. so I got it on there a little tighter with my tq wrench. havent drove it yet. Will update when I take her out.
Old 11-04-2009, 06:42 PM   #8 (permalink)
Trader Rating: (15)
That was it. not tq'd properly. took it on the road and got 0KR on 18psi with 91 octane. At 22psi with meth again 0 KR. Now time to retune the car for the good knock reading and get my power back.
Old 11-04-2009, 07:27 PM   #9 (permalink)
Adionik's Avatar
Trader Rating: (25)
Wow that's crazy.. What did you torque it to?
Old 11-04-2009, 07:31 PM   #10 (permalink)
Trader Rating: (15)
196 inch lbs
Old 11-04-2009, 07:35 PM   #11 (permalink)
Adionik's Avatar
Trader Rating: (25)
IM manifold has to come off right? FUuuuuuuuuuu....mehhhhhhhh
Old 11-04-2009, 07:36 PM   #12 (permalink)
lyncoo's Avatar
Trader Rating: (92)
good deal milkman
Old 11-04-2009, 07:40 PM   #13 (permalink)
Chief's Avatar
Member Number: 61336
you can kinda get in there with a swivel but may not be RIGHT on 196 in lbs being its at a angle alittle bit??? but you can get in there.
Built bottom end
strapped BC and CP
HTA 60
PTP when you fedex man gettin this block?
Chief is offline   Reply With Quote
Old 11-04-2009, 09:27 PM   #14 (permalink)
Trader Rating: (15)
yea I used a swivel. but no KR any more and got roughly 8-10 degrees more timing.
Old 11-04-2009, 09:38 PM   #15 (permalink)
Chief's Avatar
nice..
Page generated in 0.17667 seconds with 13 queries
