Old 06-26-2008, 07:32 PM   #1 (permalink)
Member Number: 64032
Default just a few questions, and some issues...
hey guys,
i just have a few questions... i've had my car for a little more than a year, and this summer i have started doing a few mods...
-agp wastegate
-aem short ram intake
-msd coil pack
-catch can
-1.9/2.1 drop
-yokahama tires
ok, my problems are as follows...
1. after lowering my car, the left front now makes this loud clunking sound when turning (sometimes) and when hitting even small bumps...
2. while the wheels were off i noticed some fluid on the strut/control arms? oil?
3 as of wednesday, when i drive down the road, and push the clutch in, the tac goes down to 1500, then to 2500 then back to 1500 then back to 2500...??? also, when i shift, the car stays reving at around 2000 then slowly drops down to normal...???
i tried searching, and i couldnt really find the answers i was looking for, so, if someone could possibly direct me in the right direction that would be great???
thanks guys...
cgalligan is offline   Reply With Quote
Old 06-26-2008, 07:44 PM   #2 (permalink)
Member Number: 9221
Trader Rating: (18)
I can help you with #3. Turn your car on and wiggle the TPS wires on the throttle boddy and see if it revs up, if so you will have to contact S&P for a fix. (its cheap)
GO FAST PARTS
Stage 1
FM E1 turbo
FM WGA
Dtec FC
AGP returnline
PTP 55mm TB
PTP check valve
ED hardpipes w/ HKS BOV
Maddog STS 72%
AGP motor mounts
Zeitronix ZT2 wideband
NGK v power plugs .040
8.5 MSD wires
Needswings DP (no cat)
Quickwhips direct fit FMIC
180 thermostat
Bwoody H-brace combo
Bwoody Trans mount
AnotherNeon is offline   Reply With Quote
Old 06-26-2008, 07:52 PM   #3 (permalink)
ok, dumb question, what is the tps wire?
haha, ima newb
Old 06-26-2008, 07:55 PM   #4 (permalink)
RTShadow's Avatar
Member Number: 11888
not to hijack your thread, but which yokohama tires do you have? S drive?
Quote: Originally Posted by Bella Lugrossi View Post
good thing this isn't a race to see who's smarter.
RTShadow is offline   Reply With Quote
Old 06-26-2008, 08:01 PM   #5 (permalink)
parada spec 2
Old 06-26-2008, 08:07 PM   #6 (permalink)
slickwillie's Avatar
Member Number: 47326
haha, ima newb
throttle position sensor harness. I had the same problem
slickwillie is offline   Reply With Quote
Old 06-26-2008, 08:07 PM   #7 (permalink)
RTShadow's Avatar
Ah, okay, I'm buying the S Drives and getting them installed this weekend, hopefully the Yokohamas are good tires.
Old 06-26-2008, 08:12 PM   #8 (permalink)
card00d85's Avatar
Member Number: 24249
Can't answer the questions, but I suggest you get rid of the msd coil
2004 E-Blue SRT-4:
Looks- Eibach prokit, 5% tint, 4300k HID's
Performance- Mopar performance wires, Mopar 2.5" catback
card00d85 is online now   Reply With Quote
Old 06-28-2008, 08:13 AM   #9 (permalink)
why do you suggest i get rid of the msd coil pack?
Old 07-02-2008, 03:09 AM   #10 (permalink)
G-rex's Avatar
Member Number: 64620
im wondering this myself...
G-rex is online now   Reply With Quote
Old 07-02-2008, 03:40 AM   #11 (permalink)
AdvanSRT-4's Avatar
Member Number: 12791
Trader Rating: (49)
It's junk. ^ known fact.
Alot of people have had problems with it. The stocker is all you need.
ASE Certified Automotive Technician
Old 07-02-2008, 05:07 AM   #12 (permalink)
RSchyns's Avatar
Member Number: 2019
Trader Rating: (17)
By lowering the car you have managed to prematurely wear the cv joint or tripod joint on one of your axles.
If your '04 was built before Jan '04 then you probably have the early design '03 axles. These have been redesigned
and the 04-05 part number is a direct swap. These axles failing is a common occurrence. I just replaced mine last week.
By lowering the car you have managed to blow a seal in one of your struts (not uncommon with the stock oem strut).
As mentioned above, you have the very common Throttle Position Sensor (broken wire) issue. Buy a repair kit, and have someone with some soldering skills help you out.
RSchyns is offline   Reply With Quote
Page generated in 0.18393 seconds with 11 queries
