Old 07-03-2008, 08:06 PM   #1 (permalink)
gq4life's Avatar
Member Number: 10297
Default if oxygen sensor goes bad
car does throw the O2 code if oxygen sensor goes bad right???
2004 Dodge SRT-4
AGP 50trim Turbo
Old 07-03-2008, 08:08 PM   #2 (permalink)
DDogsrt461BLK 3.0's Avatar
Member Number: 32500
Trader Rating: (15)
yes, but that's not to say that other problems would cause a 02 cell. If you replace the sensor and there's still a code, could be injector or fuel pump issues too. Holla.
I got's a fuel cell......................what you got?
Don't call it a comeback..........Thug Life
DDogsrt461BLK 3.0 is online now   Reply With Quote
Old 07-03-2008, 08:34 PM   #3 (permalink)
gq4life's Avatar
well reason i ask is car running insanely rich throwing P0172..
i know my injector O-rings r leaking hoping that what cuzing code but dad sayin car shouldnt go rich like that.. he sayin my O2 might be bad..
doubt my injectors r dirty enough to make it not mist to combust fuel.. though only throws code at high vacum going to try raising fuel pressure to over 40psi and see what happens.. but Ive never seen injectors get dirty enough to do this.. they got 100K miles on them..
Old 07-03-2008, 08:44 PM   #4 (permalink)
Trader Rating: (15)
i know my injector O-rings r leaking hoping that what cuzing code but dad sayin car should go rich like that he sayin my O2 might be bad..
I would replace the faulty O rings, and see if it corrects the problem. Instead of having good vacuum and pulling air\fuel mix in from the intake runner. It's taking in air from the injector base, causing your problem.
Old 07-04-2008, 01:04 PM   #5 (permalink)
gq4life's Avatar
im hoping it fixes problem.. hoping its because less vacumm car spraying more fuel but not gettin more air in engine..
I'll find out July 8th when they come in.. just ordered stock size o-rings...
on july 9th I get cable to fix LM-1 wideband so I can actually monitor afr again..
Old 07-25-2008, 07:52 PM   #6 (permalink)
gq4life's Avatar
i replaced o-rings vacum good now but still runs rich at idle and will pop sometimes when i go from light cruise then let go of gas..
i think upstream O2 is $25 so I'm gonna buy new one i guess.. also going to spray brake/ carb cleaner about TB and intake manifold gasket see if there r any leaks there..
any help be great
Old 08-10-2008, 11:58 PM   #7 (permalink)
KeoSRT4sho's Avatar
Member Number: 48664
did anything change
JDM USDM SRT4
KeoSRT4sho is offline   Reply With Quote
Old 08-11-2008, 02:44 AM   #8 (permalink)
gq4life's Avatar
well i bought upstream O2 sensor but havent been able to put it in yet.. car gettin worse.. its smoking.. and smoking from Valve cover breather now.. not good..
Old 08-11-2008, 05:59 AM   #9 (permalink)
SRTMIAMI's Avatar
Member Number: 54645
when my upstream o2 sensor went bad i threw no codes and virtually changed everything out before i tried replacing the sensor and it took care of the problem...
SRTMIAMI is offline   Reply With Quote
Old 08-12-2008, 12:19 AM   #10 (permalink)
KeoSRT4sho's Avatar
the upstream is the o2 housing sensor??
Old 08-12-2008, 06:08 AM   #11 (permalink)
gq4life's Avatar
up.. upstream is the O2 in the O2 housing right after the turbo
Page generated in 0.20276 seconds with 11 queries
