Old 06-25-2008, 07:56 PM   #1 (permalink)
Member Number: 55138
Default I think I gots a lemon
As my many threads in the last few days the dealer is STUMPED, they are saying they might have to change the dash again because fuses keep blowing he claims he has tried everything and he is baffled. The service advisor told me that she has seen cases with dodge that they have needed to change the dash more then 3 times.
Is my car a lemon or are dodge techs idiots and lazy?
[center]
Myspace
Dirtysrt4 is offline   Reply With Quote
Old 06-26-2008, 03:17 AM   #2 (permalink)
lphooper03's Avatar
Member Number: 37050
They are idiots and lazy....over voltage and bad grounds are killers in anything that has a fuse. Check your grounds and make sure you aren't shorting in any wires...One good investment is a multimeter also. Saves you time from having to pull out fuses. You can then verify which fuses are blown and should be able to narrow down the source of the short. (if that is indeed what it is) (keep in mind this is only one suggestion, not the solution)
Also, I feel your pain. I just bought another SRT and I seem to be having a lot of problems with it as well. I.E. Oil leak, bad clutch, bad install, missing bolts, missing splash shields, cracks in couplers, broken pipe clamps, Check Engine light, Power steering sensor, shit fuel pump, popped grease boot on tie rod. Atleast I know that it's all getting fixed right.
2003 Solar Yellow
Mods: AGP Ceramic BB 50 Trim .48, BFMIC ,Walbro 255, Stg 1 Inj, AGP UHP w/Greddy Type-S, MBC, Wingless, AGP CC, Centerforce Dual-Friction clutch, Perrin Short Shifter, Springs, Blitz TT, MPx Turboback Exhaust, Dumped WG pipe, SAFC II, UEGO.
Page generated in 0.15659 seconds with 11 queries
