ok so reading that i understand how it works, my question is, on a stage two WGA, what pressure does that spring take safley? ( attempting to fine tune my tru boost WGA Spring setting )
AEM said to set it at five, but then i'm only boosting to like 7 max, but i dont want to go some insane number like 20 0r 25 and blow up something.
the word vacuum should be replaced with pressure. there is never vacuum in the compressor housing/bc/wg.
you beat me to it. i was about to call him a dumbass and go back and change his posts to reflect what it should say as opposed to what was said. obviously he is still a newb though.
E1 turbo, PTP pnp e-mani, FM wga, 3" O2, 3" DP, 2.5 DP back exhaust, full 2.5" IC piping, Boomba BOV w/13psi spring, AEM SRI, NGK plugs, MSD 8.5mm wires, AEM uego WB, Spearco DFFMIC, race motor mount inserts, ACT 6 puck, Maddog 80% sts;
best dyno 307whp/301wtq @ 19psi
13.676 @ 106 on 20spike, 16-17 redline.stocker
13.45 @ 103 ~18psi spike, 16 hold. pcm boost/stock WG E1 at ~23psi 13.43 @ 111.65 w/non pcm boost(can't launch/no driver mod ftl)
why are you only boostin 7psi? you should be boosting at least 15 if you are stock.
well i was going by AEM's manual, so it had me set the the spring pressure at 5 so it doesnt seem to want to go over 7psi. so i went ahead and put the spring pressure to like 18 and so i was able to peak it higher. only issue i'm geting now is that i'm having sort of a sputtering sound while boosting. any ideas??
stage2 WGA is exactly the same WGA as the stock one, but with an adjustable spring
okay next question would be how do i adjust it, what is it safe to adjust to, and why am i getting a sputtering airsound that seems to be comming from around my turbo?
That sound is part throttle boost(PTB) or should I say, part throttle OVERboost.
What is happening is pretty much a compressor surge...
You are holding too much boost for your engine to manage at part throttle so the compressed air has no way to go but back through the compressor... and thus ensue a thug-a-war game between air coming in and air going out.
The minimum boost you can really run is the spring in the wastegate. If you have an adjustable wastegate and you have it too loose (you can usually tell if it is too loose because you can physically move the wastegate arm back and forth when it is installed) the flapper will just blow open with exhaust pressure and the turbo will never spool.
To answer another question, people upgrade their WGA's becuase the stock WGA's spring is too light, which will blow open from the exhaust pressure after a certain amount of boost. Ultimately the best combo is a boost controller and an aftermarket WGA, but most aftermarket WGA's are adjustable so you can preload the spring to make it open at a higher boost.
