Old 10-01-2008, 03:25 PM   #16 (permalink)
blacksin's Avatar
Member Number: 39845
Trader Rating: (18)
Quote: Originally Posted by 7055 View Post
Heres a picture of the stock wastegate, that big thing connected to your turbo isn't the wastegate, just the wastegate actuator. That door is the actual wastegate which opens and closes via the WGA arm which is in turn controlled by boost pressure.
Thats an internal wastegate. An external one is the same but routes it to the atmosphere instead of back into the exhaust right before the o2.
This post helped me understand it a lot more... WGA as wastegate actuator, while the wastegate is actually internal... VERY interesting...
Custom CAI + MOPAR: Stage 2 w/ toys, Borla Cat-back exhaust, STS w/ boogers, S1 springs, RB1 w/ IPOD kit N2MB: Toybox 2.0, Code Scrubber Aeroforce Technology: Scan Gauge MaxxFab: 3" downpipe Forward Motion: E1, wga
blacksin is offline   Reply With Quote
Old 10-01-2008, 03:52 PM   #17 (permalink)
Member Number: 62791
Exactly, Some vendors will remove that door, weld it closed and smooth out that flow area. Then slap an external wastegate door on the other side of the turbofold. If you want to see an external one go look at the site of a vendor that offers that, I don't remember what vendor does it, I think realtune. External is far superior though.
Anybody have a picture of an external wastegate that used to be an internal wastegate?
Carentan'44 is offline   Reply With Quote
Old 10-01-2008, 05:16 PM   #18 (permalink)
Pomz23's Avatar
Member Number: 64878
Trader Rating: (19)
Thanx all. I really understand how it works now. Im glade other people we able to learn a thing or two as well. The only part im still confused about is, how a adjustable WGA will help to increase/hold boost. does it put more or less tension on the WGA spring?
So the pressure in the exhaust has nothing to do with when the WG opens right? If anything it would look like the more pressure in the exhaust will help keep it closed. or no?
Metal Werkz - For Sale: New Custom Aluminum Door Sills and Radiator Shrouds!!!!!! Click here for my site.
Pomz23 is online now   Reply With Quote
Old 10-01-2008, 05:38 PM   #19 (permalink)
Member Number: 52407
Theoretically yeah. Its only boost pressure that controls the wastegate actuator.
I think you're looking at it wrong, if anything pressure in the exhaust would try to push the door open.
7055 is offline   Reply With Quote
Old 10-06-2008, 02:10 PM   #20 (permalink)
FDSleEpeR's Avatar
Member Number: 61348
So would it be ideal to get a adjustable WGA or just stick with the stock one and go with EBC or just use both in conjunction with eachother for optimised boost control. Is there a benefit to having both or just a failsafe. Or does it just depend on the tuner? BTW great thread very informative.
P.s. Sorry if i rose this thread from the grave.
-Greg
Never thought Id drive a Dodge, but look at me Now!
FDSleEpeR is offline   Reply With Quote
Old 10-06-2008, 03:02 PM   #21 (permalink)
SRTrent's Avatar
Member Number: 65861
so when you floor it and the turbo spools the wastegaste is closed to allow the boost and when you let off it opens to stop the boost?
SRTrent is online now   Reply With Quote
Old 10-06-2008, 03:21 PM   #22 (permalink)
Member Number: 41740
How do know if you wga is working properly. I can adjust agp wga but it doesnt seem to adjust the boost any.
dm_rep is offline   Reply With Quote
Old 10-06-2008, 03:22 PM   #23 (permalink)
NoisufnoC's Avatar
Member Number: 136
close, but not exactly correct.
when the target boost pressure is met, the wastegate opens to release exhaust gasses. on an external, dumped wastegate car its really obvious when the gate is open and closed.
Keeping the tire companies in business...
...one WOT shift at a time™
|| Mod List Coming Soon ||
***Forum Rules***
Old 10-06-2008, 08:28 PM   #24 (permalink)
Pomz23's Avatar
Trader Rating: (19)
Quote: Originally Posted by dm_rep View Post
so when you floor it and the turbo spools the wastegaste is closed to allow the boost and when you let off it opens to stop the boost?.
it opens when the spring inside the waste gate experiences the same amount of pound rating that the spring is made to. (if that makes anysence) its like having a 200 lbs person holding a door shut, then comes along a 201 lbs person and pushes it open. the 200 lbs person can no longer keep the door shut because it is just not strong enough. the 200 lbs person is the what the WGA spring would be. the door is the waste gate and the 201 lbs person is like the amount of boost your running.
correct me if i am wrong
Old 10-07-2008, 09:49 AM   #25 (permalink)
NoisufnoC's Avatar
Member Number: 136
essentially yes. thats how spring boost works.
when you use a boost controller, you're bleeding off boost that goes to the wastegate. so it might take 25 psi of pressure to equal 20 at the wastegate, if that makes sense.
Old 10-07-2008, 11:53 AM   #26 (permalink)
quiXilver's Avatar
Member Number: 30722
Trader Rating: (18)
What makes an external so much better, just cleaning up the flow of the exhaust?
Nikon D300
12.28 @ 111 Stock Turbo w/50 shot Untuned.
quiXilver is offline   Reply With Quote
Old 10-07-2008, 12:11 PM   #27 (permalink)
Pomz23's Avatar
Trader Rating: (19)
Question
that makes perfect sence. but looking at the pic of a bc in the first page, how does it bleed the extra boost out?
Old 10-07-2008, 02:46 PM   #28 (permalink)
NoisufnoC's Avatar
Member Number: 136
that picture describes a ball-spring manual boost controller.
a bleed type will vent some pressure to adjust how much the wastegate sees. think of it this way...drink some soda through a straw, no pop a small hole in the straw (a "bleed"), it takes more work to accomplish the same task. the turbo must create more pressure to overcome the "leak" and obtain the spring pressure of the wastegate.
Old 10-07-2008, 03:56 PM   #29 (permalink)
reemizzle's Avatar
Member Number: 40880
well its all clear now haha makes everything a whole lot easier
reemizzle is offline   Reply With Quote
Old 12-06-2008, 11:35 AM   #30 (permalink)
When the exhaust flow through the wastegate meets up with the rest of the exhaust flow it creates a lot of turbulence. You can control your boost pressuree alot better with an external gate too, no massive spikes and more boost to redline.
Page generated in 0.21135 seconds with 13 queries
