HOAT coolant???? - Dodge SRT Forum
post #1 of 23 (permalink) Old 01-17-2005, 11:36 PM Thread Starter
19 psi's Avatar
Quoted: 4 Post(s)
HOAT coolant????
The manual says to use MOPAR PINK HOAT 5yr/100,000 coolant. So I go to the parts counter and pick up some PINK MOPAR 5yr/100000mile coolant...But knowhere on the $14 bottle of coolant does it say HOAT? Did I get the wrong coolant or is this HOAT and just does-not say it.
19 psi is offline
post #2 of 23 (permalink) Old 01-17-2005, 11:50 PM
Quoted: 3 Post(s)
gm dex cool is the same.
12.879@110.21, stage 0, no juice, stock fuel, stock o2 housing, stock bov, stock tb, stock intake mani.
jmihalchik is offline
post #3 of 23 (permalink) Old 01-17-2005, 11:55 PM
SRTFORUM Moderator
Advans's Avatar
Quoted: 71 Post(s)
Or you can use this gold stuff, safe for both kinds of antifreeze....but i forgot the name. :lol
Advans is offline
post #4 of 23 (permalink) Old 01-18-2005, 12:03 AM
Quoted: 3 Post(s)
just dont mix ne colors
post #5 of 23 (permalink) Old 01-18-2005, 12:12 AM Thread Starter
19 psi's Avatar
Quoted: 4 Post(s)
N E 1 know about this HOAT (Hybid Organic Additive Techknowledgy). ORGANIC makes it sound like you can drink the stuff..............
19 psi is offline
post #6 of 23 (permalink) Old 01-18-2005, 12:34 AM
SporkLover's Avatar
Quoted: 0 Post(s)
So what comes in the car from the factory?
SporkLover is offline
post #7 of 23 (permalink) Old 01-18-2005, 12:38 AM
DaZone's Avatar
Quoted: 0 Post(s)
Be like me and just grab some 50/50 at autozone. Looks the same to me.
Mods: S3w/toybox,CTI turboback,Iceman TB,AGP CAI,CCA Fmic, Mopar wires w/NGK Plugs. Turbonetics w/greddy type s bov. also: B&G Lowering Springs, Front&Rear Strut tower bar, Rex motor mount inserts, Progress Rear sway bar. AGP S3 Wg.
18" Verde Kaos Chrome wheels
18" Exel Chromes w/toyo proxes 4- gone
17" Nexo PX-5 w/ toyo proxes 4
Dynoed with HOM : 358hp and 359tq
DaZone is offline
post #8 of 23 (permalink) Old 01-18-2005, 01:24 AM
five-0's Avatar
Quoted: 0 Post(s)
crap.
i knew green and pink didnt look right.
do i need a coolant flush?.... i really doubt it... coolant is coolant right?
five-0 is offline
post #9 of 23 (permalink) Old 01-18-2005, 06:16 AM
neonsohc's Avatar
Quoted: 0 Post(s)
just grab some prestone 5yr/150,000 miles...its worked for me so far
neonsohc is offline
post #10 of 23 (permalink) Old 01-18-2005, 08:34 AM
Quoted: 0 Post(s)
GM DexCool is not the same. Besides DexCool sometimes turns into a thick muddy color. That's why the makers of DexCool are getting sued.
Coolant should be G05. Available at your local parts stores.
Blind Driver is offline
post #11 of 23 (permalink) Old 01-18-2005, 08:48 AM
matt4258's Avatar
Quoted: 0 Post(s)
Dont mix colors!!! I heard it can be very harmful to the block. Use only pink mopar stuff.
matt4258 is offline
post #12 of 23 (permalink) Old 01-18-2005, 08:53 AM
thepowertowin's Avatar
Quoted: 21 Post(s)
"The word from DCX"
DESCRIPTION - ENGINE COOLANT
WARNING: ANTIFREEZE IS AN ETHYLENE GLYCOL BASE COOLANT AND IS HARMFUL IF SWALLOWED OR INHALED. IF SWALLOWED, DRINK TWO GLASSES OF WATER AND INDUCE VOMITING. IF INHALED, MOVE TO FRESH AIR AREA. SEEK MEDICAL ATTENTION IMMEDIATELY. DO NOT STORE IN OPEN OR UNMARKED CONTAINERS. WASH SKIN AND CLOTHING THOROUGHLY AFTER COMING IN CONTACT WITH ETHYLENE GLYCOL. KEEP OUT OF REACH OF CHILDREN. DISPOSE OF GLYCOL BASE COOLANT PROPERLY, CONTACT YOUR DEALER OR GOVERNMENT AGENCY FOR LOCATION OF COLLECTION CENTER IN YOUR AREA. DO NOT OPEN A COOLING SYSTEM WHEN THE ENGINE IS AT OPERATING TEMPERATURE OR HOT UNDER PRESSURE, PERSONAL INJURY CAN RESULT. AVOID RADIATOR COOLING FAN WHEN ENGINE COMPARTMENT RELATED SERVICE IS PERFORMED, PERSONAL INJURY CAN RESULT.
CAUTION: Use of Propylene Glycol based coolants is not recommended, as they provide less freeze protection and less boiling protection.
The cooling system is designed around the coolant. The coolant must accept heat from engine metal, in the cylinder head area near the exhaust valves and engine block. Then coolant carries the heat to the radiator where the tube/fin radiator can transfer the heat to the air.
The use of aluminum cylinder blocks, cylinder heads, and water pumps requires special corrosion protection. MoparŪ Antifreeze/Coolant, 5 Year/100,000 Mile Formula (MS-9769), or the equivalent ethylene glycol base coolant with hybrid organic corrosion inhibitors (called HOAT, for Hybrid Organic Additive Technology) is recommended. This coolant offers the best engine cooling without corrosion when mixed with 50% Ethylene Glycol and 50% distilled water to obtain a freeze point of -37°C (-35°F). If it loses color or becomes contaminated, drain, flush, and replace with fresh properly mixed coolant solution.
The green coolant MUST NOT BE MIXED with the orange or magenta coolants. When replacing coolant the complete system flush must be performed before using the replacement coolant.
CAUTION: MoparŪ Antifreeze/Coolant, 5 Year/100,000 Mile Formula (MS-9769) may not be mixed with any other type of antifreeze. Doing so will reduce the corrosion protection and may result in premature water pump seal failure. If non-HOAT coolant is introduced into the cooling system in an emergency, it should be replaced with the specified coolant as soon as possible.
Need anything? Find me on facebook... facebook.com/thepowertowin
Thinking of starting a "scammed by" thread? If you sent the paypal as a "gift" don't even bother... no one feels sorry for you.
thepowertowin is offline
post #13 of 23 (permalink) Old 01-18-2005, 08:54 AM
Quoted: 21 Post(s)
Don't be cheap... buy the right stuff... fluid is cheap compared to repairs!
post #14 of 23 (permalink) Old 01-18-2005, 11:46 AM
zr8td2k's Avatar
Quoted: 0 Post(s)
so where does one get this HOAT...beings my dealer looked like i was from out space when i said HOAT coolant and even showed it to them in the owners manual....they said use dex cool..lol stupid idiots.
zr8td2k is offline
post #15 of 23 (permalink) Old 01-18-2005, 06:10 PM Thread Starter
19 psi's Avatar
Quoted: 4 Post(s)
Well.........................
is HOAT the pink
19 psi is offline
User Tag List
Linear Mode Linear Mode
