Old 06-22-2009, 08:16 PM   #1 (permalink)
steveO9015's Avatar
Member Number: 72514
Default HID's
has anyone that has HIDs on the car ever heard of havein to use a relay kit with the HID kit due to the bulbs going off intermittently or not comeing on right away?
steveO9015 is offline   Reply With Quote
Old 06-22-2009, 08:18 PM   #2 (permalink)
silver_ek's Avatar
Member Number: 60962
its recommended to use a relay so it doesnt fry your wiring harness
silver_ek is offline   Reply With Quote
Old 06-22-2009, 08:23 PM   #3 (permalink)
Member Number: 40223
Trader Rating: (12)
i had them installed on mine for like 2-3 weeks without the relay with no issues, but your suppose to run the relay like stated above so you dont melt the stock wires.
2005 SRT4 stage 2, Tein H springs, AEM WB, Mpx BFMIC , 3" TBE , 3" 02, 55mm TB, N2MB WOT box , PTP fuel re wire, 2.5" Hot/charge pipe, AGP cold pipe, HKS SSQ bov, FMwga, E1turbo , DSP tuned .
95 Z28, Vortech Ttrim, few other mods....
2006stratus2.4 is offline   Reply With Quote
Old 06-22-2009, 08:31 PM   #4 (permalink)
steveO9015's Avatar
yeah i understand the concept of the relay kit, but not haveing one would this cause the bulbs not to come on, i have to like cycle the lights on and off to get them both to come on then after like 5mins. with them on one just goes out then i have to cycle the lights again to get it to come back on?
Old 06-28-2009, 02:56 PM   #5 (permalink)
silver_ek's Avatar
make sure all your connections are connected and secured...ive been told the ballast connections need to be upwards but not sure if its true...i had mine sideways and they worked...but just double check connections...
Old 06-28-2009, 08:57 PM   #6 (permalink)
Irish_Con's Avatar
Member Number: 44256
Ive had no real probs with my set up. Every once in awhile one of the bulbs wont come on... Just click em back off then on again. and all is well.
Irish_Con is offline   Reply With Quote
Old 06-29-2009, 01:14 AM   #7 (permalink)
srT4URBO's Avatar
Member Number: 37484
Trader Rating: (20)
i had this problem where one wouldnt come on....it was always my passenger one....it was getting worse and worse until the ballast finally went out....so i just got another one on ebay.....
Its modded
srT4URBO is online now   Reply With Quote
Old 07-04-2009, 12:02 AM   #8 (permalink)
steveO9015's Avatar
yeah idk mine are still actin up but another set is on the way hopefully i have better luck with this one
Page generated in 0.14371 seconds with 13 queries
