Old 03-10-2009, 12:19 PM   #106 (permalink)
Chief's Avatar
Member Number: 61336
Quote: Originally Posted by Haloking365 View Post
If i remember correctly, the stock turbo whistles under high RPM's.
Yes they do, but this is not the normal stock turbo sound brotha.
And yes its the first part of piping off the turbocharger. Right against the firewall.
Built bottom end
strapped BC and CP
HTA 60
PTP when you fedex man gettin this block?
Chief is offline   Reply With Quote
Old 03-11-2009, 09:37 AM   #107 (permalink)
Member Number: 68646
trying this TONIGHT... will post thanks for the possible fix
neal.woodrow is offline   Reply With Quote
Old 03-11-2009, 10:20 AM   #108 (permalink)
Chief's Avatar
Work?
Old 03-11-2009, 11:09 AM   #109 (permalink)
Crazyced's Avatar
Member Number: 56385
Mine has the tea pot mod too, can't remember if it always did it though.
Very noticabe on a dyno run.
Car is basic:
-K&N CAI
-HKS BOV
-ED WUSS
Crazyced is offline   Reply With Quote
Old 03-11-2009, 01:20 PM   #110 (permalink)
Chief's Avatar
did you try to tighten up the charge pipe on the back of the turbo??? Can you guys try this and see if it works for everyone?!?!? I have not heard mine whistle since i did this, pretty sure i found the whistle problem for all!!! thank you thank you
Old 03-11-2009, 01:31 PM   #111 (permalink)
Crazyced's Avatar
Mine was very loose the 1st time I did a boost leak test. But when it went on the dyno my car was boost leak free (exept for the one on the TB shaft ).
Old 03-11-2009, 03:18 PM   #112 (permalink)
Member Number: 31038
Trader Rating: (50)
That noise is normal. People are making a big deal out of nothing.
raul-01 is offline   Reply With Quote
Old 03-11-2009, 04:01 PM   #113 (permalink)
hiebs915's Avatar
Member Number: 68976
Well, mynes being stored right now but I can still start it and everything. Myne used to do it if id let it idle and free rev it real quick I could hear the whistle. My charge pipe was loose and I did tighten it. From the couple of times I revved it up after It didn't do it! so thats good. I'll try agian when its not so cold out. I don't like revving it in cold weather
hiebs915 is offline   Reply With Quote
Old 03-11-2009, 04:13 PM   #114 (permalink)
Chief's Avatar
No its not "NORMAL" I know what the NORMAL sound of a stock turbo sounds like, This started only in the last couple months. And what are you talking about reving it at idle being cold? This sound is only when your under wot at full spool.
Old 03-11-2009, 09:42 PM   #115 (permalink)
hiebs915's Avatar
It does it then too but myne would also do it if I floored from an idle. It would make a quick weeeee sound. Anyway, I see what happens when I actually drive it and booost around a bit.
Old 03-11-2009, 10:20 PM   #116 (permalink)
brianbr's Avatar
Member Number: 50755
mine doesnt make the weeeeeeee sound anymore it just goes ssssssssssshhhhhhhhhhh lol. It used to though.
F&F ported ex manifold, ptp wga, 3" O2 housing and downpipe, custom 3" dump, pump rewire, 255 pump, S2 injectors, Dtec, BC stage 3 cams, fidanza gears, ported throttle body, aem cai. agp solid mounts and race fmic, ultimate racing uhp, Hks ssqv, aem wideband, aeroforce scanguage. Hotchkis springs, Prothane Lca's
brianbr is offline   Reply With Quote
Old 03-11-2009, 10:56 PM   #117 (permalink)
Trader Rating: (50)
Well that high pitched WEEEEEEEE noise during WOT at high RPM's is indeed normal on stock turbo stock vac lines stock WGA. There was a thread about it a couple years ago explaining it.
Old 03-11-2009, 11:21 PM   #118 (permalink)
hiebs915's Avatar
oh, well tightening the charge pipe did something. O well if anything I fixed a small leak probably.
Old 03-12-2009, 01:05 AM   #119 (permalink)
Chief's Avatar
What i tell ya bro!?!?!
Yeaa the Weeeee sound is normal, the loud ass screaming ballon high pitched whistle is not. lol Pretty sure it just loose charge pipes bros, tighten them up and post back. Finally!!!! No idea why they dont make this sound durning a boost leak test? Mine was quite......
Old 03-12-2009, 08:14 AM   #120 (permalink)
Crazyced's Avatar
Quote: Originally Posted by yellow_66 View Post
this is what mine sounds like, a little hard to hear but its there
YouTube - Srt-4 Sound 0-60
Mine sounds exactly like that from the inside. Sounds a bit different from the outside on a dyno though.
Page generated in 0.19155 seconds with 13 queries
