Old 10-21-2008, 10:57 AM   #31 (permalink)
Tony35's Avatar
Member Number: 61633
Trader Rating: (23)
some are saying that its just the intake sucking in air and others are saying maybe a vac leak. Im about to make a boost leak tester and let u know what happens.
AGP .50 Trim w/ Supporting mods.
Tony35 is offline   Reply With Quote
Old 10-21-2008, 04:12 PM   #32 (permalink)
1srt4_2nv's Avatar
Member Number: 62580
alright cool let me know what happens
2004 Neon *you know, the unmentionable kind* SRT4\
FOR SALE!!!!!
skittles is one hell of a drug
1srt4_2nv is offline   Reply With Quote
Old 10-21-2008, 08:07 PM   #33 (permalink)
yellow_66's Avatar
Member Number: 62675
Did a boost leak test and i only came up with a loose cold side pipe.
Tea Pot mod is still in place. =(
yellow_66 is offline   Reply With Quote
Old 10-21-2008, 11:57 PM   #34 (permalink)
REDSRT4AZ's Avatar
Member Number: 64785
Mine has the Tea Pot mod too. Sounds like it comes from the dash/boost gage almost like it's telling me to shift!
FM WGA - 17PSI, Drop In Air Filter, 3" Cat Back, Race MM Inserts, GodSpeed BFMIC, S1 PCM & MAP Clamp on the way.
REDSRT4AZ is offline   Reply With Quote
Old 10-22-2008, 12:29 AM   #35 (permalink)
yellow_66's Avatar
^^^ Well its cheaper than a shift light, and you dont have to look at the rpm's
Old 10-22-2008, 03:12 AM   #36 (permalink)
Novak94's Avatar
Member Number: 45523
wow well after see this thread a few days ago and thinking nothing of it i got that strange whistle happen to me tonight. I already checked everything and its all fine im just wondering if it had something to do with the colder weather tonight. If i figure anything out i let u guys know, im S3 btw.
Old 10-22-2008, 04:03 AM   #37 (permalink)
kagekun's Avatar
Member Number: 57941
Mine is from my cai. The very edge of pipe right before the attachment to the turbo is bent putting a | <-- kinda thing right in front of the turbo.
I figure the rush of air passing over this cause a very audiable whisltle, I removed it to verify and its deff because of the intake
Meth Addict & CM is my dealer
http://www.cardomain.com/ride/3219131
kagekun is online now   Reply With Quote
Old 10-22-2008, 05:08 AM   #38 (permalink)
Member Number: 25892
Minw whistles too, always has even when I was stock turbo, it's the intake, JMB with K&N, just think how much air is being sucked into the motor during a WOT run! Aldo i am thinking with all the vacuum ports sticking out here and there with that level of air blowing by over the openings that it makes the noise, like blowing over the top of a soda bottle.......
Mods: AGP GT3076R DBB Turbo
madwax is offline   Reply With Quote
Old 10-22-2008, 08:16 AM   #39 (permalink)
sti_zee's Avatar
Member Number: 40201
holy moly, i think that may be it!
sti_zee is offline   Reply With Quote
Old 10-22-2008, 11:54 AM   #40 (permalink)
Tony35's Avatar
Trader Rating: (23)
I was thinkin its the intake too. Im gonna do the same thing as u and remove it for a pull and see what happens. Did a boost leak testand everything was ok.
Old 10-22-2008, 02:38 PM   #41 (permalink)
1srt4_2nv's Avatar
i think we are getting closer but still can't find the problem
Old 10-23-2008, 06:25 AM   #42 (permalink)
pavendort's Avatar
Member Number: 24487
OK, it sounds like the wastegate. Not the WGA, but the actual internal flapper. The part where the shaft comes thru the mani makes a whistle sound when the gate opens to limit boost. External wastegates sound the same, but vent with a tube, instead of back into the mani. Mines done it since day one. Heard it on a few SRTs...
May be wrong, but thats what I am thinking. Any shaft like that is gonna have a bit of leakage, and thats about the right sound. Especially gonna leak after a few thousand miles as that area will wear a bit and leak more. Like the bleed air valves on F-15s.
Thats cool tho, makes the skittle sound like an externally gated turbo!
2005 SRT4 Traded
2005 Mercedes-Benz C230 Kompressor
pavendort is offline   Reply With Quote
Old 10-23-2008, 06:28 AM   #43 (permalink)
planetb's Avatar
Member Number: 4909
Its just the car having a lot of fun! its going "WEEEEEEEEEEEEEEEEEEEEEEE!!!!" same sound i make when I'm on it hard _
Pentax K10D - AF-S/C Pentax SMC DA 18-55mm
2004 Flame Red SRT-4 - K&N,Kicker,Maddog 58%, 10MM wires and Denso Plugs, SSW Inferno(hyper Black) wheels, SuperBeast IC
2007 Dodge Nitro Silver
1999 Ram 2500 Cummins.
1987 Shelby Lancer #382 - 88 T2/s60,Koni's,Alum Fly
planetb is offline   Reply With Quote
Old 10-23-2008, 06:57 AM   #44 (permalink)
pavendort's Avatar
Ladies and gentlemen, we have the answer! I make the same damned sound!
Old 10-23-2008, 11:39 AM   #45 (permalink)
Tony35's Avatar
Trader Rating: (23)
I dont have a stock turbo i have a 50 trim and my wastegate doesnt sound anything like a whistle its like a second exhuast.
Page generated in 0.19080 seconds with 13 queries
