Old 10-16-2008, 06:41 PM   #1 (permalink)
1srt4_2nv's Avatar
Member Number: 62580
Default HELP! whistle while WOT
like it says, it drive great, but then i hit it WOT it give a small whistle like weeeee (not the turbo) am thinkin that it's a boost leak but can you guys help me out, holds 16psi perfect no spikes
2004 Neon *you know, the unmentionable kind* SRT4\
FOR SALE!!!!!
skittles is one hell of a drug
1srt4_2nv is offline   Reply With Quote
Old 10-16-2008, 08:15 PM   #2 (permalink)
Member Number: 9221
Trader Rating: (19)
run a boost leak test. Does it sound like a super charger?
GO FAST PARTS
Stock PCM
AGP 44# delta
Diablo predator
Dtec FC
FIC 625cc injectors
AGP returnline
PTP 55mm TB
PTP check valve
ED hardpipes w/ HKS BOV
Maddog STS 72%
AGP motor mounts
Zeitronix ZT2 wideband
Needswings DP (no cat)
180 thermostat
Bwoody H-brace combo
Bwoody Trans mount
AnotherNeon is offline   Reply With Quote
Old 10-16-2008, 08:23 PM   #3 (permalink)
card00d85's Avatar
Member Number: 24249
Trader Rating: (27)
When I'm accelerating normal I can hear a faint whine like a supercharger (when I have the radio off and windows rolled up I can hear it). Is this normal?
card00d85 is offline   Reply With Quote
Old 10-16-2008, 08:49 PM   #4 (permalink)
Manford's Avatar
Member Number: 54707
do you guys have stock airboxes?
Manford is offline   Reply With Quote
Old 10-16-2008, 09:27 PM   #5 (permalink)
BI_SRT-4's Avatar
Member Number: 45892
Its probably your factory EBC working.
Srt-4 04 E-Blue, R/C 750cc Injectors, Walbro 255 lph, Devils Own M/I M5 Nozzle, 3" Turbo back Side exit exhaust, AEM wideband, Apexi S-AFC NEO, CCA FMIC 12"x24"x3", AGP hard pipes. Upper and Lower W/ Greddy Type-S BOV
Turbonetics 54-Trim
Tial 38 MM Wastegate
Xtreme Boost Manifold
20 psi
???WHP/???WTQ
Bad Influence Auto Squad
BI_SRT-4 is offline   Reply With Quote
Old 10-16-2008, 09:38 PM   #6 (permalink)
04RedSrt-4's Avatar
Member Number: 56795
Trader Rating: (79)
I get this wine sound also sometimes when accelerating from first or second?
04RedSrt-4 is offline   Reply With Quote
Old 10-16-2008, 09:49 PM   #7 (permalink)
yellow_66's Avatar
Member Number: 62675
My ride does the same thing, It squels on the dyno past 4500 rpm.
Its my supercharger mod lol, If you figure something out let me know
yellow_66 is offline   Reply With Quote
Old 10-16-2008, 09:50 PM   #8 (permalink)
flomoloko's Avatar
Member Number: 38703
I've got it too. I removed stock surge valve/rice plate (replaced with HKS BOV), got a boost leak test done, switched out my stock air box for K&N CAI, and then back again, sound is still there, sort of like a tea pot whistle at WOT. It doesn't seem to affect performance so I just ignore it. It started doing it out of the blue about 8 months ago.
flomoloko is offline   Reply With Quote
Old 10-17-2008, 01:03 AM   #9 (permalink)
grandpa-srt4's Avatar
Member Number: 27812
Check all your vacuum lines and vacuum fittings.
grandpa-srt4 is offline   Reply With Quote
Old 10-17-2008, 01:29 AM   #10 (permalink)
Monster's Avatar
Member Number: 48761
Trader Rating: (68)
Mine did that when it ate something... probably just a boost leak tho
www.pt-performance.com
Tunes send your request to tunes@pt-performance.com
Old 10-17-2008, 01:45 AM   #11 (permalink)
Ragin_SRT's Avatar
Member Number: 42510
Trader Rating: (42)
do a boost leak & the use sea foam to see for any leaks on the exhaust mani
Crane 14's
Ragin_SRT is offline   Reply With Quote
Old 10-17-2008, 02:03 AM   #12 (permalink)
C-130Man's Avatar
Member Number: 67766
mine does this to i think it sounds sexy with the exhaust going first then the turbo spool then the teapot whistle then the WHAAAPPSSSSSSSSS.......SEXY!!!
C-130Man is offline   Reply With Quote
Old 10-17-2008, 01:03 PM   #13 (permalink)
sti_zee's Avatar
Member Number: 40201
mine does it also. no boost leaks. doesn't appear to hurt performance. sounds weird, though. and yes, a teapot-like noise at wot.
sti_zee is offline   Reply With Quote
Old 10-17-2008, 02:10 PM   #14 (permalink)
1srt4_2nv's Avatar
yes,that's what it sound it (tea pot)
does nobody really know what it is? boost leak check coming soon, i think that it but it drive fine so i might just leave it that way
Old 10-17-2008, 02:15 PM   #15 (permalink)
Tony35's Avatar
Member Number: 61633
Trader Rating: (23)
R u guys running stock turbo because i got a 50 trim and it makes the tea pot sound. Not immediatly but it takes a second or two for it to start. I actually took a video of it and im trying to get it on here so maybe someone could tell me what it is. Im actually gonna check for boost leaks on sunday.
AGP .50 Trim w/ Supporting mods.
Tony35 is offline   Reply With Quote
Page generated in 0.16585 seconds with 13 queries
