Old 05-07-2008, 06:53 PM   #1 (permalink)
Member Number: 51941
Default exhaust leak symtoms?
car idles fine but as soon as i give it gas between 2300-3200 revs, i notice like it misses and kinda sounds like bad lifters, after 3200ish its fine, also at times either when shifting at that rpm range or just coming out of a stop i give it gas and its like if i didn't and all of the sudden it catches on.. any inputs?
turboblacksrt is offline   Reply With Quote
Old 05-07-2008, 07:08 PM   #2 (permalink)
kmarko06's Avatar
Member Number: 41969
first you shouldnt walk on it while under 2800-3000 rpm, its def not a exhaust leak you would hear a difference in the tone of the car, all the time if it was, and sorta sounds like maybe your clutch could be slippin, how many miles/kilometers you have on it?
Mods: Stage 2 w/o Toys, Maxxfab/Borla Exhaust, Injen CAI, Mopar BOV, Prothane MMI's, Centerforce DF Clutch, MSD Wires, PTP Check Valve, AGP oil accumulator
To install: Maddog 80%,
kmarko06 is offline   Reply With Quote
Old 05-07-2008, 07:29 PM   #3 (permalink)
Well maybe then its not an exhaust leak, it does idles fine its just around that rpm range that it's noisy and the other issue, also exhaust "farts" a lot more now, clutch is fine is fairly new
Old 05-07-2008, 07:47 PM   #4 (permalink)
when pressing gas pedal at times, theres a delay for 1 sec or 2 , like if the car its running extremely rich or lean and then it catches back to normal, i might start to think its ignition related, i pour'd a bottle of stp complete fuel system cleaner to see if would help, thinking it was a clogged inj or whatnot but nah it didn't help a bit
Old 05-07-2008, 07:54 PM   #5 (permalink)
Member Number: 53402
Could be a bad ignition coil BUT since you don't list your mods and give anymore additional details it's hard to pin point it.
orangesrt-4 is offline   Reply With Quote
Old 05-07-2008, 08:03 PM   #6 (permalink)
60trim, e-cutout, stock catback, ragetek fuel rail and fpr,750rc's, msd 8.5 wires, safc2, etc
Old 05-08-2008, 06:02 PM   #7 (permalink)
anyone else?
Old 05-08-2008, 07:00 PM   #8 (permalink)
anyone else?
Slipping clutch?
Old 05-08-2008, 07:12 PM   #9 (permalink)
nah, i know for sure thats not it
Old 05-08-2008, 07:50 PM   #10 (permalink)
bitts's Avatar
Member Number: 29842
Trader Rating: (48)
To be sure its NOT an exhaust least, use some sea foam and look for leaks, thats what I did.
Former Tn. red-neck
bitts is offline   Reply With Quote
Old 05-09-2008, 05:50 PM   #11 (permalink)
just tried a new ignition coil and issue still there so ignition coil is scratched out,
Old 05-09-2008, 08:00 PM   #12 (permalink)
car kinda stumbles, missfires during light-medium acceleration, what gives?
Old 05-09-2008, 08:04 PM   #13 (permalink)
CIVICEATER's Avatar
Member Number: 16703
I have the same problem it almost feels like you lost 75% of your power for a second on take off. I narrowed it down to the tps wiring using the scanguage. The tps voltage would not move when I gave it gas during the time it was doing that or something along those lines. Havent had time to do the rewire kit, but this is most likely your problem.
2003 Solar Yellow SRT-4
E1 Turbo
Kinetic WGA
Devils Own W/I with Progressive Controller
MPx 3" Exhaust with Cat
MPx Intercooler
AGP CAI
Stage 3 ECU
Walbro 255lph Fuel Pump
Stage 2 Injectors
Perrin Fuel Rail
AEM Wideband
Aeroforce Scan Guage
Greddy Type RS BOV
Mopar STS
Exhaust Depot Hardpipes
DCR Oil Mod
DCR 5 Layer Headgasket
299hp - 324ft-lbs tq
13.1 - 110mph<----- Traction Ownz Me
CIVICEATER is offline   Reply With Quote
Old 05-09-2008, 08:07 PM   #14 (permalink)
surprised i dont get any cel codes, prob trying that you said^^^, and plugs and msd wires
Old 05-09-2008, 08:09 PM   #15 (permalink)
CIVICEATER's Avatar
Nope I didnt get a codes either. If you have a scanguage or anykind of datalogger look at tps voltage when this is happening it does not match where your foot is on the gas pedal if you know what I mean in a 0-5v sensor say you give it a little gas where youd get 1.2v it will all of a sudden shoot to like 3.3v and then back down to the 1.2v without you foot pushing the pedal down any further.
Page generated in 0.27698 seconds with 11 queries
