#1 (permalink) |
![]() Join Date: Jun 2004
Member Number: 13066
well on the 13th I was on my way to get new tires on my car and the inevitable happened. The engine finally had all it could take
![]() I mean running a 30r @ 30psi on a stock block is a great idea , right ![]() when the engine let loose it put several holes in the block (front and back) and also took out the oil pan . It then sprayed oil on to , well everything, but the worst place possible my extremely hot turbo/manifold causing , which burnt the engine harness,alternator,coil/wires,fuel lines,and pretty much anything else that could burn between back of the engine and firewall.......SO I pulled the engine so insurance could inspect the fire damage ....AND they are now totaling my 42,xxx mile car that has NO structural damage ...I mean once I powerwash the engine bay it will just look as if I pulled the blown engine......So I am now going to buy my car back take the check and BUILD THE SHIT OUT OF IT I am even considering full cage and tube the front chasis..... Now here are some of the things I need help with: -finding a full CF front end(bumper ,hood,fenders) which will be painted so glass will work as well -sheetmetal intake manifold -turbo manifold , intercooler pipes , and downpipe so I can mount the turbo where the battery used to live. - and for all you HIGH HP guys ....which intercooler have you ran at high boost, 30 plus , and not had any problems.... -if anyone has the harness for the engine or any other harness under the hood under the hood hit me up with a pm Alright guess thats enough for this chapter of the book....Thanks for reading...any advice,help ,or opinions are apprecited
Malevolent Motorsports
Big Things on the way!! be afraid I am04 srt rebuild to commence gonna cage the beast 03 srt on the way <----- the street version but don' let that fool ya both silver,gonna look identical, both will be wicked |
| Sponsored Links | |||
Advertisement | |||
#3 (permalink) |
![]() Join Date: Aug 2005
Member Number: 32196
I wouldn't have posted this insurance wouldn't be happy.
You should lay low til you get your check then do your thing.
17x8 245/40/17 ST40 BBK Project TRAIN DONE!11/13/09
04 -E-85 Ported Stock Turbo,Stock cams&Head,Stock Motor,Safc Neo 329.69Hp, 395.77Tq STD 297Hp@6K 320.87Hp, 385.18Tq SAE WTB Locked DSP,Built 5speed,SCT Prp |
#4 (permalink) |
Thanks so much ...I was really bummed ,but decided to look at it this way......I can now do things to my car that I wouldnt have done before.....I was so meticulous and picky about everything trying to keep miles off of it and worrying about keeping all my stock parts just in case these things became rare ....but now its going to be a salvage title .....SO let the fun begin .....she's dead now but will be back with a vengance soon....well maybe not real soon , but as quickly as possible
#5 (permalink) |
You should lay low til you get your check then do your thing. naw they know the fire started because of the engine blowing up....I was straight with them off the bat...They are giving me 3g's less because they appraised it as it sits now , needing an engine.....they told me fire damage is fire damage no matter how it started...but idk good lookin out though
#6 (permalink) |
good lookin out though Well that's cool, Anytime Time to build then should be fun keep your budget $ goes fast.
#10 (permalink) |
![]() Join Date: Feb 2010
Member Number: 77818
this^^^i would like to specifically see the holes it put in the block also all of them please thanks
new setup for 2012:Bob at form and functions new stage 3 wheel stock motor from oil pan to valve cover shooting for 10s with lots of timing and boost on racegas!!!
#11 (permalink) |
![]() Join Date: Oct 2004
Member Number: 18564
its a come up but nothing more annoying than a salvage title.
It won't be a salvage title. That is only if insurance takes posession.
2005 Lotus Elise Stage II I/E
2002 Neon/Srt-4 swap Intake, DSP 12.6@107 |
#12 (permalink) |
![]() Join Date: Nov 2003
Member Number: 5369
If you can get them to cut a check without giving them or transferring the title it should stay clean in most states like just mentioned. If anyone runs a CarFax or other similar insurance industry report it will probably show as being flagged as a total loss so if you're concerned about that take a ton of picture now, print them, and document that damage for future reference.
It's too bad about the loss but at least you should come out okay. And a good reminder for anyone, especially those with a modified car, a big automotive fire extinguisher can be cheap insurance to carry mounted in the trunk. Some of the smaller ones fit pretty well right under the rear parcel shelf between the speakers.
Eric H. ---->- ----- '04 Neon SRT-4 (eBlue/S2)
'92 Dodge Daytona IROC R/T --- -- '91 Dodge Spirit R/T plus a couple other turbo Dodges, a Cobalt, a few Focus, and some other stuff... ![]() |
#14 (permalink) |
Member Number: 5369
Not always. If they don't request the title before releasing a check then in some states it will keep the clean title unless you turn it in to your motor vehicle department and have them issue a new one stating it was a total loss. If the insurance company requires the title before paying out then it will probably end up with a salvage title as they're required by law in most states when reselling the car (even to the same previous owner).
#15 (permalink) |
![]() Join Date: Dec 2005
Member Number: 36794
You should lay low til you get your check then do your thing. I agree with this statement. Insurance could say that you modified the vehicle and that caused the failure.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
