» Tire Upgrade Garage
Old 01-15-2007, 06:05 PM   #61 (permalink)
Member Number: 46742
Default Srt 4 ACR
Old man's car (62 year old) Stage 3 & toys, fmic,3in tbe, fuel managment, pump gas. 410 ftlbs 339hp
Stanley Howe is offline   Reply With Quote
Old 02-17-2007, 03:12 PM   #62 (permalink)
Member Number: 51124
Default New Dyno Numbers - Stock Turbo 276.3/313.3
2004 SRT-4
Run 3 : 272.2HP/301.3 TQ @ 19psi (run in 3rd gear)
Mods for this run:
AEM CAI
AGP WGA
S1
MPX Large FMIC
THERMAL 3" TURBO BACK W/CAT
HKS BOV
ICEMAN 62mm TB
MSD wires w/ MPX heat shield
NKG plugs
Run 7: 276.3HP/313.3TQ @ 20psi (run in 3rd again)
Run 7 is after MPX 3" O2 housing install
More power and torque in the low-midrange, slight loss up top, quieter too
If someone can tell me how to attach an image I would be glad to add my dyno sheet here ......
FlyinE is offline   Reply With Quote
Old 03-02-2007, 01:29 PM   #63 (permalink)
peteblksrt4's Avatar
Member Number: 43767
Trader Rating: (62)
well i got to the dyno today i don't feel like scanning it b/c i am kind of mad at the numbers
mods
-agp bfmic
-agp wga 19/15
-maxxfab 3" 02 housing
-maxxfab 3" catless downpipe
-msd wires and ign coil
-borla exhaust
-mopar cai
-stg 1 pcm
-turbo xs rfl bov
-aem uego
-mapclamp
in a 4th gear pull on a dynojet superflow windyn V2.3 i had a 260.9 whp/293.6 wtq what u all think
http://groups.myspace.com/jacksonvillencsrt4s join if u are in jacksonville, nc area only
Best Trap - 1.79 60 FT 12.3090 at 114.53[/font]
ported stock turbo
peteblksrt4 is offline   Reply With Quote
Old 03-04-2007, 07:36 AM   #64 (permalink)
Member Number: 34575
2005 SRT-4
Stage 2 w/o Toys
Also, setting "smoothing" to zero upped the numbers to 249 / 280.
- Joshua
JoshuaBair is offline   Reply With Quote
Old 03-07-2007, 01:23 PM   #65 (permalink)
Member Number: 47694
I was freaking floored when I saw my dyno numbers, holy shit! Dodge seriouesly underrated these cars!
2005 Orage Blast
CAI
Stage 1
Spring Mod - holding 14-15 psi to redline
271hp and 322tq baby! How awesome is that for S1?
*EDIT* All pulls were in 3rd gear
Golikety is offline   Reply With Quote
Old 03-07-2007, 04:39 PM   #66 (permalink)
Trader Rating: (62)
^^^^^^how do u have more hp than me hahahhahahahaha look above like 3 posts i think the dyno i went to is bs
Old 03-16-2007, 01:01 PM   #67 (permalink)
Member Number: 49167
Default s3r dyno
I just dynoed my 03 s3r w/toys non HOM. I am very impressed with the numbers! They seem pretty high to me.
a/f around 12
348 hp and 329 torque
mods:
s3r w/toys
AGP s3 wga @ 22-19
Perrin turboback
Injen shortram
goldmachine is offline   Reply With Quote
Old 05-12-2007, 09:14 PM   #68 (permalink)
raul-01's Avatar
Member Number: 31038
Trader Rating: (30)
Boost leak I am guessing... Never did a test...
K&N Typhoon CAI.
raul-01 is offline   Reply With Quote
Old 05-21-2007, 08:50 PM   #69 (permalink)
perfectcircle's Avatar
Member Number: 38378
Trader Rating: (17)
engine mods: PTP wastegate, PTP mapclamp, 75 psi fpr mod, PTP checkvalve, PTP direct fit fmic, AEM wideband
261 whp & 315 wtq....
AGP 3147 w/some bolt ons
perfectcircle is offline   Reply With Quote
Old 05-22-2007, 10:21 AM   #70 (permalink)
BlueSRT4Trouble's Avatar
Member Number: 42999
Trader Rating: (13)
Not going to post graphs not real happy with the pulls, Kept getting kicked out of HOM, around 4400-4500 RMP. Even in Dab 3 Pump it stumbled at the same RPM's. I did alot of pulls. about 12 I think. My mods are
Stage 3 w/Toys, AEM CAI, Mopar/Borla exhaust, Quicktime downpipe w/cutout, JMB hardpipes, PTP Direct fit intercooler, coolingmist W/I, Ported intake manifold, NGK Iriduim plugs, Crane fire wires, Screamin Demon coil, DTEC fuel controller.
#1 332.08 HP 340.62 TQ
#2 330.53 HP 351.46 Tq
#3 333.06 Hp 348.96 TQ
#4 329.32 HP 354.37 TQ
HOM DAB 3
#5 349.76 HP 414.42 TQ kicked out at 4200 RPM
#12 HOM DAB 1 did not kick out. 355.58 HP 404.27 TQ
#13 HOM DAB 3 357.99 HP 432.89 TQ Kicked out at 4750 RPM.
I know it has alot more. Like I said it stumbled in DAB 3 NON HOM at about 4600 RPM's
Not real happy with the HP numbers, Really happy with the TQ numbers though. Looks as if the Knock sensor is to sensitive. Did not see over 3 volts knock.
Mopar Stage 3R, and a LOT more
The only easy day was yesterday.
BlueSRT4Trouble is offline   Reply With Quote
Old 05-23-2007, 02:52 AM   #71 (permalink)
blab10's Avatar
Member Number: 6648
Trader Rating: (12)
2005 Orage Blast
CAI
Stage 1
I see those are uncorrected, do you have the corrected numbers or know the correct correction factor?
310hp/324tq - SAE
blab10 is offline   Reply With Quote
Old 06-03-2007, 04:15 PM   #72 (permalink)
YoNkErZsRt4's Avatar
Member Number: 43878
Default shitty numbers
my mods: s1,agp wga, mbc hallman, mpx large fmic, injen sri, ngk one step colder plugs gapped at .40, msd wires , hot and cold side pipes with hks bov......runs were done on a dynopack dyno......first run was 245 hp 276 tq...from there it got worse....it was hot in ny yesterday....but i think i should of run better ....very unhappy....17 psi falling at redline
YoNkErZsRt4 is offline   Reply With Quote
Old 10-20-2007, 11:59 PM   #73 (permalink)
Hi N Mity's Avatar
Member Number: 33036
Trader Rating: (38)
AEM SRI
S2 WGA 16-17psi spike
QW's Direct Fit IC
pTp Hard pipes
245/270
Anyone know how to get corrected numbers?
Old 12-15-2007, 12:10 AM   #74 (permalink)
solis1479's Avatar
Member Number: 11963
Trader Rating: (12)
just re-dynoed tonite
mods:
mopar stage 3
phrozen's toybox
60mm tb
agp stage 3 wga 24/20
apexi safc 2
mopar intake
ebay intercooler (bar & plate)
dogbone's
mopar full exhaust & dp w/ cats
act clutch w/street disc
ngk iridiums gapped .32
pump gas 93 oct: 366hp/374tq
hom mode 110 oct: 400hp/435tq
there will be a few modifications done by the end of the year goal is 430hp on hom.
hom off - 93 oct gas
hom on - 110oct gas
not stage 3 anymore...
BUY MY STAGE 3 KIT
http://www.srtforums.com/forums/f27/...toybox-432202/
solis1479 is offline   Reply With Quote
Old 12-15-2007, 03:30 PM   #75 (permalink)
N0sferatU's Avatar
Member Number: 9266
factory freak
Shortram + AGP WGA (17psi fade to 13psi) + Exhaust Depot Hardpipes w/Greddy Type-S BOV netted me 273.5whp / 287.0wtq
This is WITHOUT a tune and WITHOUT a map clamp on factory ECU
I did redyno it (tho I don't have the sheet) and the car made 271whp/300wtq with a pig rich 9.8 AFR fading up to 10.9 AFR @ redline.
Now add in 18/19psi fade to 13psi
Clutch that isn't slipping
3" Downpipe + cutout and who knows
What I do know is the reason I can see the numbers as being so high for the little mods is the TQ curve stays solid to 5000rpms (doesn't drop off like most others do at a much lower RPM).
Ignore the AFR I redyno'ed it and it was faulty there
Click the stupid resizing bar to see the TQ curve better and overall the entire graph.
2004 Dodge Silver SRT-4
The Important Mods: AGP WGA, AEM SRI, 3" downpipe+cutout, Stage 3 SBC Clutch, 180 T-stat, Greddy Type-S BOV, Exhaust Depot Hard Pipes,stock fuel system, no map clamp, stock FMIC, STAGE 0
13.56 @ 105.91 on a 2.31 60'
...best 60' was 2.09 on lesser mods (and slower ET)
ALL RUNS on Kumho STREET TIRES
N0sferatU is offline   Reply With Quote
