» Tire Upgrade Garage
Old 06-12-2006, 02:02 PM   #46 (permalink)
Name Already In Use's Avatar
Member Number: 33170
Nikon D70s
Nikkor 18-70mm f/3.5-4.5
Nikkor 50mm f/1.8
Nikkor 80-200mm f/2.8
Nikon SB-800
flickr
Name Already In Use is offline   Reply With Quote
Old 08-08-2006, 08:38 AM   #47 (permalink)
terboneon's Avatar
Member Number: 8891
2004 SRT-4
MODS
Mopar Stage II no toys
Needswings open downpipe
CCA FMIC
Injen short ram intake
Apex'i S-AFC II
Greddy Profec B
Boost
18 spike 15 redline
Fuel
93 Octane pump gas
Turbo
Stock SRT-4
terboneon is offline   Reply With Quote
Old 08-15-2006, 09:47 AM   #48 (permalink)
underSRTarmor's Avatar
Member Number: 32888
Trader Rating: (66)
2005 SRT-4
MODS
intake
ported turbo
st motorsports map clamp
mm inserts
s1 pcm
s2 wg 20 spike 15 hold
w/i 70 meth 30 water
down pipe
stock intercooler and stock exhaust
jmb hard pipe with hks bov.
Boost
20 spike 15 redline
Fuel
91 Octane pump gas
Turbo
FBM ported turbo
Dodge Cummins 5.9L 325 hp 610 tq
Chevy duraless 6.6L 300 hp 520 tq
Ford PowerJoke 7.3L 300 hp 570 tq
underSRTarmor is offline   Reply With Quote
Old 08-15-2006, 07:36 PM   #49 (permalink)
xavier4life504's Avatar
Member Number: 43159
Shit I Wish My Car Was Pushing That Much
xavier4life504 is offline   Reply With Quote
Old 08-16-2006, 05:28 PM   #50 (permalink)
Trader Rating: (66)
no u dont.. more power = more money = more problems = more money... haha.. its all good tho...
Old 08-25-2006, 12:22 PM   #51 (permalink)
DaZone's Avatar
Member Number: 1799
Might as well put it here aswell.
Stage 3 -High Octane Mode. Dab 3,2,1
Mods: S3w/toybox,CTI turboback,Iceman TB,AGP CAI,CCA Fmic, Mopar wires w/NGK Plugs. Turbonetics w/greddy type s bov. also: B&G Lowering Springs, Front&Rear Strut tower bar, Rex motor mount inserts, Progress Rear sway bar. dynotune digital boost guage.
18" Exel Chromes w/toyo proxes 4
17" Nexo PX-5 w/ toyo proxes 4
DaZone is offline   Reply With Quote
Old 08-26-2006, 11:56 PM   #52 (permalink)
cybr's Avatar
Member Number: 31841
Trader Rating: (34)
Just won unlimited class in mtn region with this dyno today!
Sponsored By: ClutchMasters, SnowPerformance, MadDog, 475hp, 468ftlb, 24psi on SAFC/Profec.
Now on the SCT - Waiting to Dyno with RaceGas + 25psi
http://myspace.com/cybr
cybr is offline   Reply With Quote
Old 08-29-2006, 10:25 AM   #53 (permalink)
acancelledczech's Avatar
Member Number: 35576
Swift Motorsports, Dyno Dynamics, about 90 degrees outside:
297hp / 352tor
Mods:
Stage 1 PCM
Kinetic WGA
Quickwhips Direct Fit FMIC
Devils own water injection
JMB UPP and HKS BOV
AGP return Line
Needswings E-Cutout Downpipe 3"
Homemade map clamp
The lowest redline was the last time I dyno'd
Sony A700 ~ SRT-less
acancelledczech is offline   Reply With Quote
Old 09-13-2006, 07:26 PM   #54 (permalink)
Mean9reenMachine's Avatar
Member Number: 41055
Trader Rating: (35)
Model/year of SRT:
2005 SRT-4
Please specific power adders (at the time)
K&N drop in filter
Mopar BOV
682cc injectors
Forge WGA
MSD Coil pack
NGK Iridium plugs
Please specify Actual boost seen (SRT-4):
21 spike/17 hold
Please specify Fuel (mix content if a mix is used)
Pump Gas 91 octane
Please specify Turbo kit and size/trim of turbo (SRT-4)
Stock Turbo
279HP 345 TQ
Mean9reenMachine is offline   Reply With Quote
Old 09-16-2006, 08:07 PM   #55 (permalink)
Slack-Axe's Avatar
Member Number: 27238
Default First Dyno Run
This was the first dyno run on my '04. I think I nailed the gas too early in the RPM range since there is a drop in torque around 2300 RPM -- I'm guessing the PCM saw something it didn't like and pulled timing....that probably cost me a few HP/TQ numbers.
Nothing like doing something for the first time and getting pwned
S0
Mopar 7.5 wires
Mopar drop-in filter
Mopar Catback
Slack-Axe is offline   Reply With Quote
Old 12-08-2006, 11:11 AM   #56 (permalink)
SRTullio's Avatar
Member Number: 1239
Mods:
S2 with toys (all runs done on DAB 3, HOM on.)
Ported Turbo, intake mani, ex mani, TB, and spacer
AGP CAI
3 inch 02
Mopar cat delete
GReddy Catback.
QW BIG FMIC
-Tullio
SRTullio is offline   Reply With Quote
Old 12-09-2006, 09:13 PM   #57 (permalink)
Member Number: 39154
run with mods in sig
scott
12.77 @ 110 1.9 60' slicks and 75 shot
SRT-4_I_SWEAR is offline   Reply With Quote
Old 12-16-2006, 09:57 AM   #58 (permalink)
SRToc Member
manic_mopar's Avatar
Member Number: 25488
Trader Rating: (31)
2004 SRT-4 Blue
Contributing Mods:
Stage 1
AEM CAI
AGP WGA
Turbosmart single stage MBC
JMB hardpipes
Greddy Type-s
UMS BFMIC
NGK plugs
MSD wires
3" O2 housing/exhaust Maxxfab Side Exit
Coolingmist Varicool W/I
Emanage-Pablo/Lujan tuned
Aaronneon Returnline
Walbro 255 pump
Zero porting work
L3TZ xXx HUGx3: are u a rapist too
HoTSaUZe310: im a jack of all trades
L3TZ xXx HUGx3: i got to go peace
Pablo Tuned
298WHP/354WTQ I'm a meth addict...
...you know you want to hear them....
manic_mopar is offline   Reply With Quote
Old 12-16-2006, 10:19 PM   #59 (permalink)
Hi N Mity's Avatar
Member Number: 33036
Trader Rating: (38)
2005 Srt-4
AEM Short Ram with K&N cone filter.
Quick Whips Direct Fit IC
Insulated Intake Manifold Gasket
MSD Coil
MSD Wires
NGK 4306's .050 gap
wheels, tires, rotors = 8.6lbs lighter than stock(front)
Reset ECU before 1st run
Spiked at 16ish PSI
Old 01-07-2007, 11:22 AM   #60 (permalink)
blab10's Avatar
Member Number: 6648
Trader Rating: (12)
2004 SRT-4
3 seperate runs:
281.71hp/300.86tq
280.55hp/304.97tq
282.41hp/298.67tq
Mods are:
Stage 2 no toys
Iceman CAI
Maxxfab 3" DP with hi-flow cat
Borla catback
FBM Ported stock TB
QW Large FMIC
PTP check valve
MSD wires
NGK Iridiums gapped at .035
Best mods of all were the "boost leak test mod" and "Mopar rice plate removal mod"
All done with wonderful 91 octane in the tank.
All on computer controlled boost. Was spiking about 16-17 and it holds around 14 til about 5800rpm then falls really hard to 12 psi til the 6500rpm redline. I will try and get a scan of the graph up later.
310hp/324tq - SAE
blab10 is offline   Reply With Quote
