» Tire Upgrade Garage
Old 01-10-2007, 10:08 AM   #1 (permalink)
uberingram's Avatar
Member Number: 447
Default Differences in model years - STICKY REQUEST
2003:
Colors: Yellow, Red, Black, Silver
Power: Rated at 215hp/245tq
- SRS was an option in 03 however not very common.
- The instrument cluster gauge surrounds were chrome on some of the '03s (similar to what's also on the exports cars) vice painted silver. (Blackbird R/T)
- The very early '03 cars (~first month) supposedly got a "hotter" calibration similar to S1. (Blackbird R/T)
2004:
Colors: Yellow(Rare left over yellow bodies from 03), Red, Black, Silver, Blue (replaced Yellow)
Power: Rated at 230hp/250tq
Changes:
- Headlights now with a silver band instead of black
- Valve cover change with new PCV
- Axles strengthened sometime between Feb-March. Click here for picture.
- Coolant feed line fittings changed (see post 57 & 59)
- Larger injectors (S1 injectors)
- LSD standard
- New Venture T850 updates on the '04 trans to improve operation and address '03 concerns (internal part changes did not supersede to new numbers so without break-down and direct comparison can't say what exactly they changed/updated). (Blackbird R/T)
- Friction Modifier requirement for '04+ cars with LSD. (Blackbird R/T)
- Service supplement lowering trans fluid change interval to 18k-miles due to Friction Modifier eating ATF. (Blackbird R/T)
- Change in supplement/manuals regarding recommendation/use of M1. (Blackbird R/T)
- Tires changed from Michilen to BFGoodrich
- Sun roof optional (w/ 'oh-shit' handles)
- Kicker package optional
- Starter cables slightly different on where they mount (fried a starter when hooking it up like an 04 :P)
- Angled #4 spark plug wire started to become standard on newer 04's
- Standard neon foot pedals replaced with "bright" or metal pedals with rubber grommets.
- Test port with schrader valve removed from fuel rail. (note: some early 04's still had 03 style rails)
- windsheild washer squirter's spray pattern changed.
- Old style "slider" controls removed from radio sometime between 04 and 05
- VTA activation proceedures changed. Details can be viewed here.
- Sometime in either 04 or 05 the front emblem changed from a single piece to a two piece. RSchyns' 04 (build date Oct 03) is a one piece while this thread shows an 05 with a two piece front emblem.
- NGK plug info added to the emission decal on '04+. (Blackbird R/T)
2005:
Same changes as 04
Colors: Orange replaced Blue for first half of 05. Silver replaced with White in late 05
- ACR package
- Commemorative package
- 05 PCM's tend to be a bit more picky about PTB and overboost CEL's.
- Removed battery temp sensor
- Battery terminal covers. Rubber and hard plastic.
- Plastic shielding added to brake wire to prevent clutch pedal crushing the wire when fully depressed.
- warranty restricted to strictly 3 year 36000 mile power train / bumper to bumper.
- Some of the '05s have a slightly different gray printed background on the gauge face. (Blackbird R/T)
- WGA change to common Mitsu design in '05. (Blackbird R/T)
- Upper motor mount torque bracket changed (see picture).
  • Different color SRT-4 on the owner's manual for all three years.
I'm sure there are other things I've missed but that's just what I've seen and/or recalled at the moment.
If you see something that I forgot please PM me and I will edit my post as quick as I can. Lets try to keep this thread free of debris.
Chris ~ Janky '03
uberingram is offline   Reply With Quote
Old 01-10-2007, 11:56 AM   #2 (permalink)
RSchyns's Avatar
Member Number: 2019
'04 and '05 got the "bright" pedals
RSchyns is offline   Reply With Quote
Old 01-10-2007, 12:11 PM   #3 (permalink)
Super Moderator
stowaway's Avatar
Member Number: 3286
sorry, can't sticky it for ya.
OH OH OH. fuel rail changed in 04, removed schrader valve.
Old 01-10-2007, 08:31 PM   #4 (permalink)
master_1011's Avatar
Member Number: 3396
2003 has SRS seats, too.
First SRT-4 sold on Guam
master_1011 is offline   Reply With Quote
Old 01-11-2007, 09:32 AM   #5 (permalink)
uberingram's Avatar
Member Number: 447
Really? When I bought mine it wasn't an option. Did they add it later in 03?
Old 01-11-2007, 09:56 AM   #6 (permalink)
Super Moderator
stowaway's Avatar
Member Number: 3286
it was the only option for 03 cars.
Old 01-11-2007, 04:31 PM   #7 (permalink)
Member Number: 434
srs came out in 04 only viper seats in 03 sorry
lightened and knife edged crank/8500 rpms/crankscrapers.com setup/ragetek ported im70mmtb/dcr pro series head/crane18s/750s/returnline/unorthadox gears/dnp exh mani/gt2871r/aem ems/tial 44mm wg/cm twin disc/stoptech st40s/atp upp greddy type s/fmic/agp hotside/kinetic charge/bdj dump/lsd/bc coilovers 650 lbf 700 lbr pt front/perrin rear/pwerks style brace/8pt cage/bushings/manny z rear arms/strut braces/brake lines/hawk hp+/racing blue fluid
jinkly04 is offline   Reply With Quote
Old 01-11-2007, 04:58 PM   #8 (permalink)
Super Moderator
stowaway's Avatar
Member Number: 3286
http://www.caranddriver.com/comparis...thrillers.html
Dodge seeks $19,995 for the no-extras example pictured here. (Side airbags are the only option at $275.)
Old 01-12-2007, 12:07 AM   #9 (permalink)
Member Number: 3396
Dude....I have an 03 with SRS....sorry.
Like stowaway said, it was the ONLY option in 03.
Old 01-12-2007, 12:27 AM   #10 (permalink)
srt-4tony's Avatar
Member Number: 45022
anyone know if its true that some early 04 cars came with the weaker 03 axles? And if so how can i tell which ones i have?
srt-4tony is offline   Reply With Quote
Old 01-12-2007, 12:28 AM   #11 (permalink)
Tex
Tex's Avatar
Member Number: 3622
dont forget the kicker system in 04
Tex is offline   Reply With Quote
Old 01-12-2007, 12:41 AM   #12 (permalink)
Member Number: 3396
Honestly, the SRS seats were kinda rare in 03 and I think most of them got sent overseas to the military sales...hence why I got one with SRS when I was stationed on Guam. I bought it in June of 03.
Old 01-12-2007, 01:30 AM   #13 (permalink)
Member Number: 662
03 Wiper fluid spray is a stream pattern.
04+ Wiper fluid spray is a fan pattern.
Postal is offline   Reply With Quote
Old 01-12-2007, 06:52 AM   #14 (permalink)
Super Moderator
stowaway's Avatar
Member Number: 3286
they did come with the 03 axle design.
Old 01-12-2007, 06:58 AM   #15 (permalink)
uberingram's Avatar
Member Number: 447
It was already on there, Tex.
List edited with changes.
