Old 06-24-2008, 11:54 PM   #1 (permalink)
Member Number: 62825
Angry damn srt-4
so i put in a new intakemanifold with new map, idle controll valve, and tps sensors all vac lines are hooked up right so theres NO VAC OR BOOST LEAKS its been tested already. so with that said he my prob. is my cars after buying all this shit is still sitting at 1,500 rpms does anyone here know what the hell is my cars prob. oh and my turbo is sucking "yes I said it" alot up air if that helps at all.my car needs to be fixed it soon so i can give it to my friend if anyone here can help on anything please do im almost broke and lost on what to do next
khaoSrt4 is offline   Reply With Quote
Old 06-25-2008, 12:08 AM   #2 (permalink)
Member Number: 45523
so from the sounds of it u boost leak tested the entire system?
S3R
Old 06-25-2008, 12:14 AM   #3 (permalink)
shane0008's Avatar
Member Number: 3685
Have you checked the PCV valve & hoses, and catch can/check valve if applicable for leaks? That gave me a 1,500 rpm idle before.
shane0008 is offline   Reply With Quote
Old 06-25-2008, 02:57 AM   #4 (permalink)
Outlawnick's Avatar
Member Number: 38675
Trader Rating: (86)
It sounds like you have a leak somewhere between the TB and the head. Grab a spray bottle and fill it with water. One at a time, spray all mating surfaces, starting where the IAC mounts to the TB. If the engine bogs down while spraying then you have found a leak. You said that the turbo is sucking a lot of air? Usually with a leak after the TB the compressor will surge, blowing air out through the inlet instead of sucking like normal.
Click for mods & pics
2004 NSRT-4 (Toy) AGP DBB 50 Trim
2005 NSRT-4 (Daily driver)
Outlawnick is offline   Reply With Quote
Old 06-25-2008, 03:15 AM   #5 (permalink)
VanillaXtract's Avatar
Member Number: 27205
Trader Rating: (19)
Didn't install the sensors correctly? When I put in my TB, I had the TPS in wrong and that gave me a high idle. Pull it out and put it in again (hehe).
ANTI-SWEETS CLUB MEMBER # 6
If life was easy, it'd be called "your mom"
VanillaXtract is offline   Reply With Quote
Old 06-25-2008, 05:36 AM   #6 (permalink)
Outlawnick's Avatar
Trader Rating: (86)
Old 06-25-2008, 08:20 AM   #7 (permalink)
SRT-4 Discussion Moderator
Jmhm17's Avatar
Member Number: 24437
could be your IAT sensor or wires.. it happend to me.. drove me crazy i finaly found the problem a day before i sold the car lol
* Disclaimer...The above post may or may not have misspelled words ...deal with it...
**Sold**
Best E/T 12.699 @ 108.97
Best MPH 12.856 @ 110.32
Jmhm17 is offline   Reply With Quote
Old 06-25-2008, 08:24 AM   #8 (permalink)
Member Number: 30867
Trader Rating: (10)
jake the lines going to the brake booster spcially on the back
No one believed when I pushed the idea of 300whp on the stock turbo now look.when I said the stock motor could handle 400whp now look.when I stood by the idea that a piggy back could get you 400whp let alone 500whp now look.that you could run anything above a dry 35 shot on the motor, and then they went all the way to pushing 75.
Caric is offline   Reply With Quote
Old 06-25-2008, 08:31 AM   #9 (permalink)
wannasupra's Avatar
Member Number: 32741
make sure the pcv and brake booster are done right bro. some ass hat fucked mine up in florida, took me 6 months to track that shit down.
"Scoff not at my vile remarks horny fiend"
Quote: Originally Posted by unnecessary View Post
Son Of A Bitch!@#!#@@#! You made me hit my Knee on the desk!
wannasupra is online now   Reply With Quote
Page generated in 0.21757 seconds with 11 queries
