Old 06-10-2008, 02:10 PM   #1 (permalink)
Member Number: 63144
Default coldside pipe wont go back on.!!!!!
I was going to install a HKS BOV today but had some things come up, Now I am trying to Put the stock cold side pipe back on and it seems like it doesnt fit onto the intercooler, it seems everything i try the F*cker wont go back on....HELP please I have to drive to work tomorrow
jasonro26 is offline   Reply With Quote
Old 06-10-2008, 02:13 PM   #2 (permalink)
Member Number: 2255
Trader Rating: (41)
Lube it up with something. That should help it slide back on. Hit it with some dishsoap or something that you have laying around.
Phins711 is offline   Reply With Quote
Old 06-10-2008, 02:51 PM   #3 (permalink)
[vu]juan's Avatar
Member Number: 33153
Trader Rating: (38)
Not sure how much help this will be but you might be able to figure something out: Snail Motorsports - SRT-4 Articles, Tutorials, and Guides - PTP Intercooler Cold-Side Pipe Installation
Try removing the clamps and starting with the bottom pipe, get that one then slide the clamp through the top or open it all the way. Then worry about the rest... Good luck.
"Been in a palace, been in a jail, I just don't want to be reborn a snail
Just want to spend eternity, Right where I am, on the sunnyside of the street"
- The Pogues
Powder Coating FTW!
[vu]juan is offline   Reply With Quote
Old 06-10-2008, 04:52 PM   #4 (permalink)
lphooper03's Avatar
Member Number: 37050
I honestly can't remember if there are couplers connecting the cold pipe on or if they are built onto it....Anyway....here's my story.
I have a AGP cold pipe and it took be about 30-45 minutes to get that little fucker on. An oil soaked t-shirt and two screwdriver stab wounds later, it went on.
I found that if you tighten the couplers to the intercooler and throttle body first....it's a little easier to get the pipe to slide in both at the same time...rather than going from bottom to top. (gives you more room to wiggle the pipe around)
50 Trim + Diablosport =
Old 06-10-2008, 05:08 PM   #5 (permalink)
tamadx's Avatar
Member Number: 26290
Trader Rating: (19)
takes ten min if you have done it a bunch...bottom to top and slide the bottom of the coupler on the tb then use some force and a screw driver if you must to get it on the tb..... just keep trying.
And its the stock one right? should be the easiest cold side pipe to put on. just an fyi when your putting on your hard pipes.
sold for an Srt-6
tamadx is offline   Reply With Quote
Old 06-10-2008, 05:24 PM   #6 (permalink)
ziggo0's Avatar
Member Number: 63759
Even when you get it on...how can you tighten a T-Clamp without it slipping its self off since its all lubed up?
Old 06-11-2008, 11:04 AM   #7 (permalink)
tamadx's Avatar
Trader Rating: (19)
it shouldnt be slipping off when you get it on...and if it is somethings wrong.... its the stock pipe it should be easy....
hold it in place and use one hand to start tightning if you need to.
Old 06-11-2008, 02:31 PM   #8 (permalink)
lphooper03's Avatar
You almost have to turn into the hulk in order to get it on. I looked over and started turning green and told my dog, "you wouldn't like me when i'm angry", then the coldside pipe went on nice and easy.
Page generated in 0.14793 seconds with 13 queries
