Old 04-28-2008, 09:40 AM   #1 (permalink)
Member Number: 63629
Default check valve not necessary
I was just perusing the agp section when i came across the check valve sticky.
AGP specifies using the 3/8" mcmaster-carr instead of the 1/4" valve.
I argued this to no avail a while back.
For what it's worth, I'm starting to wonder if their's really any need for a check valve if one's running 20ish or less psig.
The pcv valve, which in itself is a check valve, may leak a bit, but it shouldn't make a significant difference in boost level.
Plus, two check valves in line (pcv + aftermarket) can cause air flow issues.
It's also questionable whether a catch can is necessary.
Shouldn't cause issues, but only so much oil vapor flows thru the line, and most of it is harmlessly sucked thru the engine.
The oil that accumulates is on the output side of the ic, so it doesn't really do any harm.
Food for thought.
<edited for my_little_srt - didn't stop hitting enter but used capitalization which might help. thanks>
betternyou is offline   Reply With Quote
Old 04-28-2008, 03:40 PM   #2 (permalink)
my_little_srt's Avatar
Member Number: 41179
why
do
you
keep
hitting
enter
after
every
sentence,
makes
it
hard
to
understand
what
your
saying
my_little_srt is online now   Reply With Quote
Old 04-28-2008, 05:42 PM   #3 (permalink)
faceyournation's Avatar
Member Number: 42545
i never even bothered with a check valve either...
2004 E Blue.
koyorad, spearco monster intercooler, dc sports strut bar, 3" o2 housing & duel tip turbo back (maxxfab), msd coil and granatelli wires, K&N CAI, greddy type s, agp wastegate MM's and trans mount, boomba CC, misc appearance mods.
faceyournation is offline   Reply With Quote
Old 04-28-2008, 09:16 PM   #4 (permalink)
Member Number: 51815
i just intalled a catchcan without a check valve and in a week and a half of driving everyday i havn't collected anything. could this mean the pcv is no good? or am i just lucky and dont get much blowby?
moparx12 is offline   Reply With Quote
Old 04-29-2008, 10:37 PM   #5 (permalink)
kagekun's Avatar
Member Number: 57941
I guess you dont NEED a check valve...but why would you want to trust the plastic pcv with holding boost if you dont have to, guess worse come to worse, its just another boost leak fix
kagekun is offline   Reply With Quote
Old 04-29-2008, 10:39 PM   #6 (permalink)
lilmike0450's Avatar
Member Number: 56278
If you like boost leaks go ahead.
05 White ACR
lilmike0450 is offline   Reply With Quote
Old 04-29-2008, 10:45 PM   #7 (permalink)
Big D's Blue 04's Avatar
Member Number: 32123
They are definitely worth it! As I have tried to explain many times in the past, under boost the boost pressure will go back into the pcv track and into the valve cover since the factor PCV valve is a joke! this added crank case pressure will cause oil blow by from the fresh air line on the intake and its not good on the rest of the internal parts to have built up pressure like this.
Check Valve = Good!! If you need to know how to get one RFR sells them at a very nice price. Ramsey Family Racing
Big D's Blue 04 is offline   Reply With Quote
Old 04-29-2008, 10:48 PM   #8 (permalink)
yuppers...
Old 04-29-2008, 10:59 PM   #9 (permalink)
Member Number: 62791
A checkvalve isn't to stop a boost leak. A check valve is to keep pressure out of your crankcase which is bad, so put a damn $15 check valve on there.
Carentan'44 is offline   Reply With Quote
Old 04-30-2008, 12:47 AM   #10 (permalink)
Epic's Avatar
Member Number: 32348
Thats the check valve i have. i bough it off of ebay the only complaint i have is that the shipping took forever!
Epic is offline   Reply With Quote
Old 04-30-2008, 11:08 AM   #11 (permalink)
kagekun's Avatar
The stock pcv valve is a pos, it leaks under boost. Weather that is leaks boost into the crankcase or leaks it atmo...still a leak you do not want
Old 05-01-2008, 12:48 PM   #12 (permalink)
sti_zee's Avatar
Member Number: 40201
the stock pcv leaks very little (tested it myself)
certainly not a significant boost leak.
'sti_zee' is neither a reference the wrx sti nor the 350z
sti_zee is offline   Reply With Quote
Old 05-01-2008, 12:52 PM   #13 (permalink)
Philth's Avatar
Member Number: 46647
Trader Rating: (24)
FWIW, I had a PTP check valve set up. Was having lots of blow by, as noticed in the coupler for my intake just before the turbo. Took the check valve out, cleaned the coupler, and it's tons cleaner after driving hard/going to the track.
Old 05-01-2008, 02:26 PM   #14 (permalink)
SRT-4s come with a factory boost leak, the point of a checkvalve isn't just to stop a boost leak. Fact is the PCV valve is a POS and you don't want any pressure in your crankcase, infact you want vacuum in there so put a checkvalve on.
BTW my pcv valve leaked 100%
Old 05-02-2008, 08:06 AM   #15 (permalink)
sti_zee's Avatar
If your check valve leaked 100%, you'd get almost no boost.
Solution - buy a new one.
Also, you'll get better 'ventilation' from a slightly leaking pcv valve than a tightly shut check valve.
goes out the other side of the cam cover. no 'pressure.'
