Old 06-26-2008, 12:55 PM   #1 (permalink)
Member Number: 55267
Default Car problems
Alright my car is losing power at low rpms like ill step on the gas and nothing is happenin then ill put the pedal to the floor and it will temp fix itself and its bogging down and wanting to stall itself in neutral, i feel like the car is not getting enough gas any ideas what the problem is and how i can go about fixing it?
foodeater is offline   Reply With Quote
Old 06-26-2008, 03:48 PM   #2 (permalink)
SRT-4 Discussion Nazi
Jmhm17's Avatar
Member Number: 24437
are you throwing a code?
sounds liek the TPS issue
TPS: Bad Idle, High Idle, P0123 Code? We May Have a DIY Fix
* Disclaimer...The above post may or may not have misspelled words ...deal with it...
**Sold**
Best E/T 12.699 @ 108.97
Best MPH 12.856 @ 110.32
Jmhm17 is offline   Reply With Quote
Old 06-26-2008, 06:51 PM   #3 (permalink)
I was showing a o2 sensor code, power steering sensor and running to rich in bank 1.... ill be looking at the boost gauge when the problem happens and it keeps going from 20psi vacuum and like going up and the closer it gets to zero the car seems like its going to stall out all of this is happening while im in neutral.
Page generated in 0.12166 seconds with 11 queries
