Old 11-15-2009, 06:43 PM   #1 (permalink)
blackedsrt's Avatar
Member Number: 73370
Default car burning oil question
bout my 2003 srt-4 about 4 months ago. has 67,000 miles
when i received it everything appeared to be fine, on the way home from purchase i got on it an was in shock of how fast it was compared to my last srt.
i look down at the boost gauge(0psi-20psi srt gauge) and it was well passed the 20 mark. where the 30psi mark should be. i immediately let off and the car sounded pretty weird. no knock or tick. exhaust just had a different tone.
(don't remember what exactly the sound was like) lowered the boost to 14psi and drove it to this day. starting to burn oil and smoke alot out the exhaust. just changed the oil today and haven't noticed any smoke as of yet.
but i do still smell burnt oil. my buddy told me i probably fried my rings and im doing a compression test tomorrow. as well as checking for any shaft play in the turbo.
noticed today after i parked it that the return line on the turbo is leaking oil all over my charge pipe. yet the line snug and does not appear to be loose.
maybe blown turbo? rings? what numbers i should expect on compression?
your 2 cents please
mods are as follow
agp wga
dual stage controller low 14 high 17 (but theres a leak somewhere now and is only holding 11psi.) slow as balls
hks ssqv
big fmic hard pipes
turbo back exhaust
intake
thank you for reading and please let me know what it could be...
______________________________________________
what can i say i like to drive
blackedsrt is offline   Reply With Quote
Old 11-15-2009, 07:15 PM   #2 (permalink)
Hi N Mity's Avatar
Member Number: 33036
Trader Rating: (40)
also check/change your PCV valve while your in there
Old 11-15-2009, 07:21 PM   #3 (permalink)
blackedsrt's Avatar
gotta catch can on that so no recirculating oil. but ok
thanks
Old 11-15-2009, 07:26 PM   #4 (permalink)
Xx_R/T_xX's Avatar
Member Number: 18749
check for leaks around the drain tube area
Silver 300c SRT-8
Old 11-16-2009, 06:11 AM   #5 (permalink)
blackedsrt's Avatar
there are leaks around the return off the turbo
Old 11-16-2009, 06:53 AM   #6 (permalink)
blackedsrt's Avatar
pcv is good. and no shaft play.
return is still leaking, but not as bad since the oil change.
still havent noticed and smoke since the change.
compression numbers? anyone>?
Old 11-16-2009, 07:17 AM   #7 (permalink)
blackedsrt's Avatar
bearing is good, but seal could still be bad anyway of testing or checking the turbo seal?
havent confirmed if its the return line leaking oil i just know oil has saturated the line as well as my charge pipe. and the majority of the oil is on the middle, underside of the turbo.
none on the exhaust side or intake just the middle.
as i said before the return line is tight and does not appear to be loose
Old 11-16-2009, 07:26 AM   #8 (permalink)
Ragin_SRT's Avatar
Member Number: 42510
Trader Rating: (44)
do a leak down test also.....it could be your valve seals
Crane 14's
Ragin_SRT is offline   Reply With Quote
Old 11-16-2009, 07:32 AM   #9 (permalink)
blackedsrt's Avatar
good idea. but still what kinda numbers are ideal for the compression?
Old 11-16-2009, 07:46 AM   #10 (permalink)
Ragin_SRT's Avatar
Trader Rating: (44)
140-150 on each cylinder
Old 11-16-2009, 08:22 AM   #11 (permalink)
blackedsrt's Avatar
thanks man
Old 11-16-2009, 06:03 PM   #12 (permalink)
blackedsrt's Avatar
Reading 152 across the board. No valve tick. Idles normal. Mechanic says valves are fine. Only smokes at idle. Sat in my driveway at idle, smoked. Reved a Lil bit and It quit until it idle back down. Turbo blown?
Old 11-17-2009, 08:37 AM   #13 (permalink)
Ragin_SRT's Avatar
Trader Rating: (44)
do a leak down test......when doing the leak down if it leaks through the im then its ur intake VALVE SEALS if it is through the exhaust then its your EXHAUST SEALS.....or if it leaks through the oil cap, dip stick, valve cover then its your PISTON RINGS........if all comes out good then check your turbo
Old 11-17-2009, 03:39 PM   #14 (permalink)
blackedsrt's Avatar
When I di he compression test I let the conpression sit for 1 minute in each cylnder and no leaks so it's not my pistons. Any special way of doing a leak down test?
Old 11-17-2009, 03:43 PM   #15 (permalink)
AdvanSRT-4's Avatar
Member Number: 12791
Trader Rating: (57)
Leak down test and compression test are 2 diffrent things....You'll need to get a leak down tester, and a have a compressor, or access to a compressor.
Sounds like it could be valve seals....if it smokes in vacuum (IE downshifting, anytime in hard vacuum) it's more than likley a ring(s) What mines doing right now.
AdvanSRT-4 is online now   Reply With Quote
