and it came with 2 o2 bungs (sweet! no asking for sombody to weld on another for wideband) and it also came with an EGT sensor. I was thinking, since its there, I might as well use it, right? Plus there's a wire running off of it. If i were to take it out, thats another hole to plug. Plus it might be a good thing to have later on down the road. It is an autometer sensor with a red and yellow wire insulated from each other and then insulated against heat.
What gauges do people use most often?
Am I stuck with autometer? Is this all I would have to hook up to make the gauge work?
A positive and ground and the red and yellow wire coming off the sensor? Should I buy another brand (if compatible)?
and finally... If i'm buying just a gauge, what price range should I stay under? I can get an autometer carbon fiber one online for 100 shipped. Why are they cheaper than the normal white faced? lol.
If it's an autometer, go ahead and buy a compatable autometer gauge if you can find one without the thermocoupler. The carbon fiber one you refer has a decent price. Most of the one's that are more money come with the thermocoupler.
why is there an EGT sensor in the cat? SHouldnt it be in the manifold?
GO FAST PARTS
Stage 1
FM E1 turbo
FM WGA
Dtec FC
AGP returnline
PTP 55mm TB
PTP check valve
ED hardpipes w/ HKS BOV
Maddog STS 72%
AGP motor mounts
Zeitronix ZT2 wideband
NGK v power plugs .040
8.5 MSD wires
Needswings DP (no cat)
Quickwhips direct fit FMIC
180 thermostat
Bwoody H-brace combo
Bwoody Trans mount
thats what i was thinking
AGP3147 TO COME SOON,QW BFMIC,Atp hard pipes,HKS bov,2.5 in maxfab dp without cat,greddy evo2 catback stage2,many other mods to come
FORSALE:Boomba STS & 8 stage2 injectors
Yeah my brother said wtf to that too. How inaccurate would it be since its not as close to the engine manifold? Well, its still going to be accurate just not the correct temperature. Maybe 50 degrees colder? Or is it so far away that it isn't worth putting in?
