Old 03-05-2008, 03:40 PM   #1 (permalink)
Member Number: 60162
Default Belt ques...
Well i got up this morning an started my car an my belt wouldnt stop squeaking so i figure ill jus pick up sum belt conditionor no biggie. So i spray it down an it stops but only for as long as i am sprayin it then begins squeakin again. Could this mean i need a new belt? Also how many belts do our cars have? Any info appreciated cuz its very annoying.
blksrt4Ny is offline   Reply With Quote
Old 03-05-2008, 03:44 PM   #2 (permalink)
Plan B's Avatar
Member Number: 43129
DO NOT USE BELT SPRAY! It's only a temporary fix and will get sticky crap all over your engine bay. it could be squeking for a number of reasons. There could be power steering fluid, coolant, or oil on it; your tensioner might be due for replacement; or the belt is just done. if you are going to spray anything on it try brake cleaner. Then you can use a wire brush to clean it. How many miles on the car?
Plan B is offline   Reply With Quote
Old 03-05-2008, 03:48 PM   #3 (permalink)
thx for reply....53k Maybe its time to change? Dunno if it was changed but i bought the car with 37k. How many are there (2)?
Old 03-05-2008, 09:06 PM   #4 (permalink)
Icecreamman's Avatar
Member Number: 39828
There are 2 belts, one for the accessories, one for the alternator. If its squeaking, just try changing the belt first, its easy and cheap (under 15min/$20). I got coolant on my belt by accident and almost swapped out the P/S pump because that's where I thought the squeak was coming from.
17" Kazera KZ-As, MPx Single Exit TBE, Mopar STS, AGP 50trim, AEM Wideband, AGP 3" CAI, MPx FMIC, Blitz TT, Apexi AVC-R, AGP Hard Pipes w/ HKS SSQ, BWoody Mounts, Plug Wires, NGK Iridium IX plugs, AGP return line, 625cc Inj., SAFCII, Walboro 255LPH Fuel Pump, HKS EBC, ACT 6-Pad High Performance Clutch
Icecreamman is offline   Reply With Quote
Old 03-06-2008, 12:41 PM   #5 (permalink)
srt4psi's Avatar
Member Number: 57379
my car was squealing and it was because the belts had to be changed
srt4psi is offline   Reply With Quote
Old 03-06-2008, 03:35 PM   #6 (permalink)
CHANCEKIRKSEY's Avatar
Member Number: 55174
Yea if your belt wasn't bad its bad now because you sprayed that crap on it, it will eat the belt and make it weak. Try atv the black one, trust me it will work. Put that on there till you change the belt.
CHANCEKIRKSEY is offline   Reply With Quote
Old 05-14-2008, 09:30 PM   #7 (permalink)
Member Number: 56991
BUMP every time I press the gas my belt goes crazy and wont stop sqeaking car has less then 20k on it just installed 50trim on it past weekend MAYBE coolant but its been 4 days??
::Stg 1 PCM::AEM S.R.I::Hallman MBC::Borla Dual Exhaust::NeedsWing v5 3" DP/Cuttout::Turbonetics Cold Side Pipe w/ Greddy Type S.BOV::Mpx Front Mount Intercooler::Tein-S Springs::AEM EUGO,OIL Pressure,Volts::Apexii TT::Apexii Neo/MSD Tach::Bwoody Motor Mounts::IP2 CF Hood::Carbon By Design Eyelids & Radiator Shroud::AGP Return Line::AGPBB50trim::RC750cc::Walbro255
13.0@108 1.86-60/ft (On Stock Turbo)
12.8@112 2.2-60/ft (50trim Stock Clutch)
RaiedZ is online now   Reply With Quote
Old 05-14-2008, 10:16 PM   #8 (permalink)
Member Number: 41861
change the belt and see if it stops. if it doesnt then check the ac condensor bolts that mount it to the motor and make sure they arent loose. if they are you wont be able to keep tension in the belt and it will sqeak
RUTHLESS
srtmike04 is offline   Reply With Quote
Old 05-14-2008, 10:28 PM   #9 (permalink)
p1llar's Avatar
Member Number: 59003
i made a thread about this the other day. I had the same issues, esp. after a car wash. I got it changed under warranty earlier today, it was the surpintaine (sp?) belt. It is $150 parts and labour if it's not under warranty.
edit- mine has 14K and the more gas the more it'll whine, you need a new belt forsure.
'05 SRT-4
13.16 @ 105.89 mph w/ a few goodies
p1llar is offline   Reply With Quote
Old 05-14-2008, 10:44 PM   #10 (permalink)
Coo im under warranty trying to stay away from them though there dicks once they see new Turbo setup theyll void that shit in a min
Old 05-14-2008, 10:47 PM   #11 (permalink)
p1llar's Avatar
I'm definatly not stock. I had one dealer tell me it's not warrantied, went to another dealer and they did it no questions asked. No matter what your mods are, it's not gonna make the belt whine...
Page generated in 0.23038 seconds with 11 queries
