alternator/charging issues - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Closed Thread
Old 11-02-2010, 01:10 AM   #1 (permalink)
1st gen srt's Avatar
Member Number: 64479
Default alternator/charging issues
so i replaced my alternator cause my old one was bad. It is still not charging the battery. I have double checked the connections to the alternator and all the grounds "battery included". I replaced my starter a couple months ago and everything works fine with that but i dont remember there being a big ground connected to it. but i was tracing wires and grounds and i found a ground that is underneath the intake manifold. Does it connect to the starter? I need help i cant figure this out. Does anyone have a wiring diagram? any help would be much appreciated. Thanks
1st gen srt is offline
Old 11-02-2010, 06:13 AM   #2 (permalink)
Merderates da formz
NorthNJSRT4's Avatar
Member Number: 57126
All of the wiring diagrams are in the service manual linked below in my sig.
NorthNJSRT4 is offline
Old 11-14-2010, 10:43 AM   #3 (permalink)
so come to figure out that ground was the power coming from the alternator...however its still not charging the battery...I am at a loss i have been trying everything and have no clue what it could be...any suggestions? There is the power wire that comes off the alternator to the starter...Check....then there is the two prong connector that plugs in to the alternator check....I have no clue what is going on..any ideas? Please I am tired of not being able to drive my baby. By the way it is a 03 if that matters
Old 11-14-2010, 11:37 AM   #4 (permalink)
Merderates da formz
Having them switched may have damaged the PCM, which is where the voltage regulator for the alternator is located. Remove the PCM connectors and see if the pins on the PCM are scorched.
Old 11-14-2010, 11:41 AM   #5 (permalink)
good point do you know which pins they are color code on the pcm connector so i dont have to refrence it int the service manual?
Old 11-14-2010, 12:27 PM   #6 (permalink)
_Nick_'s Avatar
Member Number: 8941
You may have ruined the battery. Get it tested after?
20G Stage 3 on E85: New data:384 hp 411 tq
"Maybe I should just stick to bolt-ons." -Hitler
I don't really want to wrench anymore. I'd rather detail.
_Nick_ is offline
Old 11-14-2010, 12:32 PM   #7 (permalink)
ya but the car should still be putting out 13+ volts. its only putting out 11.56 when i tested it at the battery and at the starter and fuse box...I could try a new battery but i dont think that is the issue. I tested the battery when the car is off and key off and it was putting out 12.04 volts and was not dropping.
Old 11-14-2010, 12:40 PM   #8 (permalink)
_Nick_'s Avatar
Member Number: 8941
I say get it tested at a store like Autozone. My battery was putting out 12 volts, and even passed the test where the coil heats up in the hand held test thing. (Old ass technology) Autozone showed me it wasn't accepting a charge like it should, but it was releasing power fine.
I see you are in Germany, maybe they have the German Autozone there, "Achtun-o-zone."
_Nick_ is offline
Old 11-14-2010, 12:43 PM   #9 (permalink)
well i wish i could get it tested at autozone lol...however i am in germany lol oh well. If i am not mistaken if the cars alternator is fine shouldnt you be able to pull the battery cables off the battery and it would still run? cause if it is true i tried it and it stalled.....
Old 11-14-2010, 12:45 PM   #10 (permalink)
_Nick_'s Avatar
Member Number: 8941
You are correct. It should run for a while. Hm????
_Nick_ is offline
Old 11-14-2010, 12:57 PM   #11 (permalink)
Merderates da formz
I vote PCM.
Service manual pages 572 and 573. On the PCM it's connector #2, pin 19 and connector #1 pin 29.
Of note, the battery temp sensor or ambient air temp sensor (depending on year of the car) also play a role in the voltage out the PCM decides on.
Old 11-15-2010, 09:24 AM   #12 (permalink)
Quote: Originally Posted by NorthNJSRT4 View Post
I vote PCM.
thanks i really appreciate it. going to have to find a used pcm i guess and have it reflashed...i will look at those pins tomorrow hopefully they are good. If not guess i found the source. Its raining like hell right now. wish i could work on my car but I cant
Old 11-15-2010, 12:58 PM   #13 (permalink)
DoodEdge's Avatar
Member Number: 69186
Yeah, if the alternators good once it's running you can disconnect the battery. If it stalled when you did that there is def an alternator problem.
DoodEdge is offline
Old 01-28-2013, 11:54 AM   #14 (permalink)
Member Number: 69906
Default found somethin
Hey I thought i'd just post this to help others in the future.
I had my charge wire chaffing against my dump at first.
so I fixed that and wouldn't get a charge to battery still. I did some more digging and found the same charge wire at the starter had burned through as well.
My ride AKA "DUCES"
Snyphor24 is offline
Closed Thread
