Old 10-13-2009, 01:14 PM   #1 (permalink)
7angofragger's Avatar
Member Number: 73392
Default All my axle boots are green.. Factory axles?
I was checking out under my car, and i noticed that all of my axle boots are bright green... do the factory axles have a green boot? or are these aftermarket? any way to tell?
2003 Dodge SRT-4
Tein Superstreet Coilovers
Hotchkis Front and Rear Sway Bars
PWerks TriPoint Front and Rear Strut Bars
3" CAI
TurboXS RFL BOV
Solid MM
7angofragger is online now   Reply With Quote
Old 10-13-2009, 01:23 PM   #2 (permalink)
SRTforums Admin
stowaway's Avatar
Member Number: 3286
def. not stock.
Old 10-13-2009, 01:40 PM   #3 (permalink)
Silverbullet114's Avatar
Member Number: 47454
Reconditioned axles that have been sent out and repaired usally when in an accident or broken are green.
"Money Talks"
Silverbullet114 is offline   Reply With Quote
Old 11-13-2009, 08:04 AM   #4 (permalink)
pduvert's Avatar
Member Number: 45438
My DSS stage 3 axles have green boots.
Mopar Stage 2 w/toys, Tein Basic coilovers, , Injen SRI, AGP WGA w PTP spring @ 22 psi, boomba BOV, 180 stat, Solid MM's, polly bushing kit, B-Woody 85% STS, Lorenzo 60mm TB, Check Valve, Boomba IM Spacer, Mopar catback,Maxxfab 3 inch DP,PTP O2 , Dasmopar mapclamp, Aem Wideband ,PTP rewire,DSS stg 3 Axles, PTP Coil Shield, ED Wuss IC, BWoody CC, FBM Ported E1 ,PTP econo manifold, PTP Chargepipe
pduvert is offline   Reply With Quote
Old 11-13-2009, 08:54 AM   #5 (permalink)
planetb's Avatar
Member Number: 4909
I've had 4 sets of axles now. All seemed to have different color boots on them.
1. on car from factory : black I had the weak 03 axles on my 04
2. replaced by dealer @ 35,000 miles : blue boot (had mopar part # label on it.. took almost 2 weeks to get them) one was throwing grease right away and dealer broke control bushings installing axles. had about 1500 miles on them when replaced. Axles on Nat back order at this time. was lucky to get the first set..
3. replaced by dealer : green (took 3 weeks to get them)
4. replaced by dealer : black (had mopar part # label) green boots lasted about 25k. Started to get a wobble like original factory axles did.
Dealer covered rental each time even with my car having a $175 limit on rental coverage
Pentax K10D - AF-S/C Pentax SMC DA 18-55mm
2004 Flame Red SRT-4 - K&N,Kicker,Maddog 58%, 10MM wires/Denso Plugs, SSW Inferno(hyper Black) wheels, SuperBeast IC
2007 Dodge Nitro Silver
1999 Ram 2500 Cummins.
1987 Shelby Lancer #382 - 88 T2/s60,Konis,Alum Fly
planetb is online now   Reply With Quote
Old 11-15-2009, 03:50 PM   #6 (permalink)
srt4banger123's Avatar
Member Number: 69435
take a pic of them
srt4banger123 is offline   Reply With Quote
Old 11-15-2009, 03:53 PM   #7 (permalink)
conroy9940's Avatar
Member Number: 46401
Trader Rating: (120)
dss....
Pittsburgh Penguins 35-22-2 72 points
Old 11-15-2009, 05:10 PM   #8 (permalink)
lil_hub_cap's Avatar
Member Number: 75014
picture?
lil_hub_cap is offline   Reply With Quote
Old 11-15-2009, 05:26 PM   #9 (permalink)
SlowSilvr05's Avatar
Member Number: 59686
Trader Rating: (31)
I bought DSS replacements before and they all have been green.
SlowSilvr05 is offline   Reply With Quote
Old 11-18-2009, 10:51 AM   #10 (permalink)
modernceo's Avatar
Member Number: 313
Trader Rating: (213)
We posted photos in our blog comparing the DSS axles to the factory axles for the 95-99 Dodge Neon.
Take a look at our blog post and then look at your axles to see if they are painted gray on the shafts like the DSS ones pictured in our blog. That will help you identify if they are the DSS aftermarket axles.
Comparison of stock style axle to DSS Stage 3 axle for 1995-1999 Dodge Neon Modern Performance’s Blog
I may decide to do a SRT4 stock axle versus DSS axle today to post in our blog....
Cory Haines
Operations Manager
Modern Performance Racing Products
www.modernperformance.com
Have a question about a product, or order? For fastest response call us at 1-877-247-6366 or email us at info@modernperformance.com (PM is slowest method of response)
modernceo is online now   Reply With Quote
Old 11-19-2009, 01:02 PM   #11 (permalink)
modernceo's Avatar
Member Number: 313
UPDATE:
For kicks, we took photos showing the difference between the factory SRT4 axles and the DSS axles for the SRT4.
We've posted the photos in our blog here:
SRT4 stock axles versus SRT4 DSS Axles comparison Modern Performance’s Blog
One of the photos here:
