Old 06-18-2008, 11:28 PM   #1 (permalink)
fentress24's Avatar
Member Number: 28357
Default 5.7l Gto
friend has a 5.7L GTO with a cat back and i have a 2005 Srt-4 with tb no cat, and a kinetic wga 18/15. well we did a few runs and its pretty even from a roll until about fourth. In fourth i was expecting to pull about half a car beacause our fourth gear is so long, but he pulled half a car. all he has is a cat-back. i was alittle confused, i knew it would be close, but thought it would be the other way around. im asking because im starting to think i might be pulling timing. thanks
-Fentress
fentress24 is offline   Reply With Quote
Old 06-18-2008, 11:34 PM   #2 (permalink)
rolla4now's Avatar
Member Number: 2195
at 18 psi you more than likely are... lower it to 17 and you should see a difference.
with those mods thats just about where both cars should be running.
rolla4now is online now   Reply With Quote
Old 06-18-2008, 11:36 PM   #3 (permalink)
fentress24's Avatar
alright thanks just wanted to check, also i was speed shifting and almost positive he was not, couldn't hear over my car.
Old 06-18-2008, 11:38 PM   #4 (permalink)
FunWheelDrive's Avatar
Member Number: 34041
You thought you would pull on an LSX car at top end? Lolz.
FunWheelDrive is online now   Reply With Quote
Old 06-19-2008, 06:58 AM   #5 (permalink)
Member Number: 24039
map clamp, more boost and some meth/water injection would do it.
Mods: Driving Light remove-cold air intake/ ram, Prothane MMI (race), K&N Drop-In, AGP WGA,3" EZR Downpipe, HP design 18x8 w/ 235 Sumo's, AEM UEGO, map clamp, check valve
Madrex is offline   Reply With Quote
Old 06-19-2008, 01:48 PM   #6 (permalink)
Member Number: 55735
ive seen srt 4 on fully bolt ons take down 6.0 gto's but its true about thinking of taking down an lsxcar at top en. i have a friend with a srt 4 taking down c6's till top of 3rd when the c6 obviously pulls a little
alexanderig is offline   Reply With Quote
Old 06-19-2008, 01:55 PM   #7 (permalink)
Member Number: 64335
Most of the LS1 Goats run mid to higher 13's and trap a drop less then the fbodies...I have seen a few dip into the lower 13's w/ a good driver
Antz97znj is offline   Reply With Quote
Old 06-19-2008, 03:02 PM   #8 (permalink)
fentress24's Avatar
thanks guys i obviously didnt know too much about what the goats ran. thanks for the feedback. it was a good race with a good friend of mine
Old 06-19-2008, 06:19 PM   #9 (permalink)
RTShadow's Avatar
Member Number: 11888
Most LS1 GTO's run 13.8 to 14.2 at the track, basically same as the SRT-4 with a good driver. I've never seen one run under a 13.7 stock, ever.
Quote: Originally Posted by Bella Lugrossi View Post
good thing this isn't a race to see who's smarter.
RTShadow is online now   Reply With Quote
Old 06-20-2008, 07:18 AM   #10 (permalink)
YouTube - SRT4 vs. GTO 6.0L
check his mods
Page generated in 0.16596 seconds with 11 queries
