Old 05-18-2004, 02:57 PM   #10 (permalink)
RoostBoost
RoostBoost's Avatar
Member Number: 7368
Trader Rating: (72)
Pap...thanks!! I have the IN/OUT set wrong...how would that affect driveability if I had it set to 5IN/OUT?? right now I'm adding a lot of fuel above 4400 rpms w/stage 1 because I was leaning out w/the T3/T4...so 10 IN/10 OUT is ok?
would you still recommend those percentages if running higher boost on a T3/T4 turbo??
I don't have the grey wire hooked up (from the SAFC) right now...I would just splice it into the map sensor wire (yellow/white and white)...what wires would I have to switch?
Pap...thanks again!
RoostBoost is offline   Reply With Quote
Page generated in 0.08927 seconds with 10 queries
