Quote: Originally Posted by
96max5sp
I have 2 questions probrably easy but i can't figure it out.
1 - The dashboard, i wanted to make one to save or download the one that is in the sticky so i can log and have the view i want before starting. I can't seem to open up the dashboard file in the viewer or after i save one i can't reopen it in the viewer either. Something I am missing?
2 - I do not see this parameter in the viewer
INJECTOR--->
AVG TOTAL WORKING PW
Where is it?
thanks!!
You need to connect to the ecu by the little "lighten bolt"(not a ? mark), 3rd icon from the left, then select the proper PIDs
Yes TPS raw doesn't work. you need:
Throttle Sensor Input-->
THR POSN
Chrysler SCI is normal. Its the com bus being used.
