Old 03-27-2008, 08:51 PM   #19 (permalink)
DRASTIC.
Member Number: 58932
Trader Rating: (23)
Quote: Originally Posted by SpeedEuphoria View Post
you can cut fuel before that, basically just below warm idle vac. Like mine idles at 18 or so and cuts fuel at 20 or so, its a different computer but same idea. You should get better MPG also with a new computer because you can normally set cruise and low throttle/loads to mid 15's A/F(or as lean as it will go without lean misfiring)
yep thats what i plan on doing.
i gotta figure out whats wrong w/ my turbo setup before i install the ems tho. im not getting full boost (20psi) until 4300. and i Should be making it around 3600.
no manifold/wg leaks. everything ziptied. clamps tight.
its buggin me the hell out.
» Sponsor Links
»Garage Storage and Cabinets
Page generated in 0.14247 seconds with 12 queries
