this is how i routed my catch can, this way it is absolutly imposible for one to leak boost
i also used fuel like instead of vac line because over time oil can cause a vac line to wear apart
in the pik i T'd both sides of the valve cover together and put that line on the "IN" and then on the "OUT" side i have an open breather filter.
after that i capped the nipple on the intake manifold. i am no longer getting boost leaks from this because boost does not go to the catch can at all! =)
