Quote: Originally Posted by NeonWaSp
i'm not that interested :P
i was hoping someone who knew how to do the math would plug in the numbers.
If RC Engineering flowed our injectors with their test fluid @ 43 psi, they would rate the injectors as follows:
2003 Injectors - 343.3 g/min = 45.3 lb/hr = 498.3 cc/min
2004 Injectors - 377.6 g/min = 49.8 lb/hr = 547.8 cc/min
I posted this above. All you have to do is plug the 547.8 cc/min into the equation orignally posted and then you will have your number. The tools are here, put them to use.
